Search disabled
The Search function of this forum has been disabled, as it is currently the target of abuse. We apologize for the inconvenience.
  Issue Generating Java Code Programmatically from Ecore Model Using Gen Model
By: Adiel Tuyishime on Mon, 24 June 2024
6 1169 Mon, 15 July 2024 11:42
By: Ed Willink
  [CDO] Configure release conditions for cached objects
By: Robert Schulk on Mon, 08 July 2024
1 13698 Thu, 11 July 2024 19:25
By: Eike Stepper
  Generating EMOF from XMI vs Ecore
Generating a EMOF from an ecore or xmi results in different representations of the emof that are not compatible for import by other modeling software.
By: Jason K on Thu, 20 June 2024
2 747 Sat, 22 June 2024 16:06
By: Ed Willink
  Setting unchangeable features at object creation
By: Kaan B. Y. on Mon, 10 June 2024
3 1241 Thu, 20 June 2024 08:27
By: Ed Willink
  EEnum value serialization in xml file
By: Mishal Tripathi on Wed, 05 June 2024
2 1147 Thu, 06 June 2024 09:17
By: Mishal Tripathi
  How to get a localized name of EEnumLiteral
By: Denis Nikiforov on Sat, 11 May 2024
2 443 Sat, 11 May 2024 18:34
By: Denis Nikiforov
  UI Issue with using Modeling Nature
By: Carsten Wesp on Tue, 16 April 2024
2 1338 Thu, 09 May 2024 08:44
By: Ed Willink
  Order of multi-inheritance is not deterministic?
By: Janek Schumann on Sun, 14 April 2024
2 1659 Thu, 09 May 2024 08:34
By: Ed Willink
  CDO attributes and references
By: Klarise Hund on Mon, 29 April 2024
1 1145 Sat, 04 May 2024 04:35
By: Eike Stepper
  Dynamic enum literal/caption for editor
How to load the caption for enum values from other files than the prlugin.properties
By: Thomas Barth on Fri, 19 April 2024
2 1688 Mon, 22 April 2024 10:07
By: Thomas Barth
  Library Upgrade Issues
Facing issue when upgrading the xtext , guice libs
By: Aditya Sharma on Thu, 18 April 2024
1 1087 Fri, 19 April 2024 05:43
By: Ed Merks
  [CDO] EmbeddedRepositoryExample is not working
By: Antoine rrrrr on Tue, 12 March 2024
1 2261 Tue, 19 March 2024 08:41
By: Eike Stepper
  Track change notifications
By: Klarise Hund on Fri, 08 March 2024
6 914 Fri, 08 March 2024 13:23
By: Klarise Hund
  Why Enumerators save the Literal into the file
Literal change with language but the name does not, therefore the name should be saved
By: Yigal Spinner on Wed, 06 March 2024
4 1321 Fri, 08 March 2024 06:48
By: Ed Merks
  Instance level permissions
By: Klarise Hund on Thu, 07 March 2024
3 1039 Fri, 08 March 2024 06:44
By: Ed Merks
  Other/Custom names for objects in EMF-Plugin
By: Joris Lückenga on Tue, 30 April 2013
3 3300 Tue, 05 March 2024 09:35
By: Sachin Goyal
  How to change name of multiple objects by changing the name of only one
By: Sachin Goyal on Mon, 04 March 2024
1 926 Mon, 04 March 2024 08:33
By: Ed Merks
  [CDO] Commit Exception on the second commit after thread interruption
By: Robert Schulk on Mon, 12 February 2024
1 2944 Mon, 04 March 2024 08:32
By: Robert Schulk
  How to change the name at the runtime in eclipse emf
By: Sachin Goyal on Fri, 01 March 2024
1 498 Fri, 01 March 2024 10:41
By: Ed Merks
  Tree view on Xtext model file on the first run not working (crosspost)
By: Francesco Bedini on Wed, 28 February 2024
2 2142 Wed, 28 February 2024 13:25
  What happens when an object is deleted?
By: Sachin Goyal on Wed, 21 February 2024
1 2370 Wed, 21 February 2024 11:49
By: Ed Merks
  How to get an Object from it's uri path
1 2573 Wed, 21 February 2024 08:37
By: Ed Merks
  Multiple editors
By: Klarise Hund on Sun, 19 November 2023
3 1251 Fri, 26 January 2024 08:22
By: Ed Merks
  Access Ecore class Attribute with multiplicity 0..1 (Optional parameter)
Ecore/xtext/xtend treats optional EString attrribute as String.
By: Anders Ishoey on Thu, 25 January 2024
1 936 Fri, 26 January 2024 08:15
By: Ed Merks
  Genmodel code generation via Maven build
Genmode code generation via Maven build
By: Max Kratz on Sun, 31 December 2023
3 830 Mon, 01 January 2024 15:01
By: Ed Merks
  Changed behavior of Undo/Redo menu's entries?
By: Lorenzo Bettini on Thu, 16 November 2023
7 1106 Mon, 20 November 2023 08:02
By: Lorenzo Bettini
  Incomplete EPackage from ecore file
By: Máté Földiák on Mon, 30 October 2023
5 999 Tue, 31 October 2023 11:05
By: Ed Merks
  Models partially loaded with jUnit
Making jUnit tests on EMF Diff/Merge bridge but the imported model seems to be partially loaded
By: Clément Peyrou on Mon, 30 October 2023
1 716 Tue, 31 October 2023 09:06
By: Ed Merks
  Problem with interaction between list sorting and recording commands
By: Louis Detweiler on Mon, 23 October 2023
1 730 Tue, 24 October 2023 05:41
By: Ed Merks
  Obtaining a permission to quote the EMF book in Ecore documentation
I'm working on a generated Ecore documentation and would like to leverage content from the EMF book in descriptions
By: Pavel Vlasov on Thu, 14 September 2023
1 886 Fri, 15 September 2023 08:09
By: Ed Merks
  Import EMF metamodel in jet template
By: John Henbergs on Mon, 11 September 2023
7 1432 Thu, 14 September 2023 12:09
By: Ed Merks
  Runtime editor
By: John Henbergs on Wed, 13 September 2023
1 486 Wed, 13 September 2023 16:37
By: Ed Merks
  Create Ecore Modelling Project programmatically
By: John Henbergs on Tue, 05 September 2023
9 1709 Mon, 11 September 2023 13:06
By: Ed Merks
  Relation doesn't exists when executing CDOServerUtil.addRepository()
By: I S on Thu, 07 September 2023
4 1270 Fri, 08 September 2023 00:12
By: I S
  Forbid users from creating and deleting EClasses
By: John Henbergs on Thu, 24 August 2023
3 1425 Mon, 04 September 2023 12:30
By: Ed Merks
  How to use tycho plugin
encountering issues with dependency management while using the Tycho plugin in my Eclipse project
By: sumegh thale on Wed, 30 August 2023
2 811 Sat, 02 September 2023 06:29
By: Ed Willink
  AbstractCDOIDLong is no longer available
By: I S on Mon, 28 August 2023
2 821 Tue, 29 August 2023 05:02
By: Eike Stepper
  How can you change properties of attributes at runtime?
By: Milan Cornelis on Mon, 21 August 2023
1 765 Mon, 21 August 2023 12:27
By: Ed Merks
  Notification on any eContainer change
By: Frank Benoit on Wed, 02 August 2023
2 1553 Sun, 06 August 2023 17:09
By: Ed Willink
  [CDO] Managing async view invalidation
By: Alain Picard on Mon, 31 July 2023
2 874 Tue, 01 August 2023 08:02
By: Alain Picard
  [CDO] Efficiently moving a large containment structure
By: Robert Schulk on Mon, 10 July 2023
2 1004 Wed, 26 July 2023 13:08
By: Robert Schulk
  Using dynamic templates in Xcore
Problems with dynamic templates in xcore model lead to empty generated files
By: Nis Wechselberg on Tue, 27 June 2023
5 986 Tue, 27 June 2023 13:11
By: Ed Merks
  CDO Migrated to GitHub
By: Eike Stepper on Sat, 24 June 2023
0 1222 Sat, 24 June 2023 15:29
By: Eike Stepper
  cdo_commit_infos table cleanup
By: I S on Fri, 23 June 2023
3 1383 Sat, 24 June 2023 07:46
By: Eike Stepper
  Stereotype in ecore model
By: Hind Hamrouni on Mon, 01 May 2023
2 1291 Wed, 07 June 2023 21:16
By: Hind Hamrouni
  EMF build to maven central issue ?
By: Stephane fournier on Mon, 05 June 2023
1 740 Mon, 05 June 2023 17:48
By: Ed Merks
  Load EObject from xs:any or FeatureMap
Is it possible to read arbitrary EObject defined as xs:any in XML?
By: Michael Relby on Fri, 02 June 2023
5 1671 Mon, 05 June 2023 13:44
By: Ed Merks
  CDO and H2 compatibility
By: Jay Graham on Thu, 01 June 2023
5 1252 Fri, 02 June 2023 21:41
By: Jay Graham
  [CDO] Release schedule
By: Olga Secerov on Thu, 25 May 2023
2 830 Thu, 25 May 2023 15:40
By: Eike Stepper
  Hierarchical constraint categories in plugin.xml
How to make constraint categories hierarchical?
By: Thomas M on Tue, 16 May 2023
2 1133 Tue, 23 May 2023 15:28
By: Thomas M
  Diagnostician Validation only enforce unique Ids after saving the model
The validation method of the Diagnostician is not behaving in an expected way.
By: Maxens Destiné on Fri, 19 May 2023
5 1033 Sat, 20 May 2023 20:50
By: Maxens Destiné
  Interplay of XML_MAP and XML_EXTENDED
Definition of behaviour
By: Jörn Guy Süß on Tue, 16 May 2023
4 1513 Fri, 19 May 2023 05:13
By: Jörn Guy Süß
  EMF forms with ComboBox
EMF forms with Multiselect combobox
By: Tejamurthy Shivakumar on Fri, 12 May 2023
2 1136 Wed, 17 May 2023 15:53
By: Eugen Neufeld
  EMF generates to the wrong directory
By: Geoffry Roberts on Tue, 16 May 2023
2 901 Wed, 17 May 2023 03:47
By: Ed Merks
  Unable to dynamically call an EOperation of a generated type
By: Matei Gabriel Anita on Wed, 10 May 2023
2 879 Thu, 11 May 2023 10:06
  removing "Run As", "Debug As" ... popup menu items
By: John Yotka on Sat, 02 December 2006
2 1936 Sat, 06 May 2023 02:49
By: motein Xor
  [CDO] Building with Tycho
By: Alain Picard on Wed, 19 April 2023
3 1025 Thu, 20 April 2023 13:18
By: Eike Stepper
  [CDO] Delete EObjects and BLOBs
Problemens and Error during delete of large objects
By: Alexander Stenzer on Fri, 17 February 2023
6 2688 Fri, 31 March 2023 14:56
  Load Resources
By: John Henbergs on Sun, 26 March 2023
1 673 Sun, 26 March 2023 16:15
By: Ed Merks
  Best practice for metamodels under development
Using computePlatformURIMap() via a user interface
By: Jörn Guy Süß on Wed, 15 March 2023
3 1227 Fri, 17 March 2023 09:53
By: Ed Willink
  API-level facility for dynamic models
Does a project have to implement dynamic ePackage registration?
By: Jörn Guy Süß on Sat, 11 March 2023
11 5172 Tue, 14 March 2023 07:29
By: Ed Merks
  [CDO] Should a CDORevision already have changes of RevisionDelta applied?
By: Linuxhippy Mising name on Wed, 01 March 2023
1 1663 Mon, 06 March 2023 08:26
By: Eike Stepper
  Location of Containment Proxy Objects
Beginners question
By: Jörn Guy Süß on Fri, 03 March 2023
3 1167 Sat, 04 March 2023 23:04
By: Jörn Guy Süß
  [CDO] ConcurrentHashMap NPE.
NPE when releasing a read lock.
By: Jay Graham on Sun, 26 February 2023
3 1061 Mon, 27 February 2023 13:51
By: Jay Graham
  [CDO] Database mapping: explicitly specify nullable columns
The default null/not-null is not consistent among every database engine
By: Robert Schulk on Mon, 07 November 2022
4 2173 Fri, 17 February 2023 18:42
  [CDO] Idiomatic way to install dynamic MM (i.e. Ecore file)
How to define schemata on the server
By: Jörn Guy Süß on Tue, 13 December 2022
1 3257 Sat, 04 February 2023 10:07
By: Eike Stepper
  [CDO] DevOps installation
How to build a container with CDO server
By: Jörn Guy Süß on Fri, 09 December 2022
1 2325 Sat, 04 February 2023 10:02
By: Eike Stepper
  XSD2GenModel: set package name for java generated code
By: Missing name Mising name on Fri, 27 January 2023
7 1768 Mon, 30 January 2023 13:39
  Documentation generator for Ecore models
Generating static HTML documentation sites for Ecore models with Maven
By: Pavel Vlasov on Tue, 05 April 2022
2 3939 Wed, 18 January 2023 14:40
  modifying xmi model file
Adding assets model from metamodel xmi file
By: wld blm on Tue, 13 December 2022
5 1736 Wed, 14 December 2022 13:33
By: Ed Merks
  failed to read genmodel
By: Eclipse User on Mon, 29 November 2004
5 2834 Wed, 14 December 2022 10:34
By: Arnault Bonafos
  load model from xmi file
By: wld blm on Mon, 12 December 2022
2 1926 Tue, 13 December 2022 15:48
By: wld blm
  [CDO] Release 4.21 Is Now Available
By: Eike Stepper on Thu, 08 December 2022
0 2079 Thu, 08 December 2022 10:04
By: Eike Stepper
  [Compare] GregorianCalendar values displayed incorrectly
By: Eike Stepper on Tue, 15 November 2022
4 2017 Mon, 28 November 2022 14:04
By: Eike Stepper
  [CDO] CDOStaleReferencePolicy & EMap
By: Alain Picard on Thu, 17 November 2022
3 1794 Mon, 21 November 2022 17:26
By: Eike Stepper
  [CDO] net4j reconnect session timeout exception, no reconnect
By: thomas huster on Thu, 20 October 2022
10 3584 Fri, 18 November 2022 18:33
By: Eike Stepper
  Xcore validation fails in Maven Release Build
By: Nis Wechselberg on Tue, 15 November 2022
2 1214 Wed, 16 November 2022 17:16
By: Christian Dietrich
  Memory disposal during unload()
Intended control for garbage collection
By: Jörn Guy Süß on Wed, 09 November 2022
8 2324 Thu, 10 November 2022 05:31
By: Jörn Guy Süß
  Problems to open a XMI file using the Sample Reflective Ecore Model Editor
By: Jose Alejandro Concepcion Alvarez on Wed, 09 November 2022
3 1587 Wed, 09 November 2022 14:25
By: Ed Merks
  Cycle detection in URIConverter prefix expansion
Does EMF crash when the URI maps are poorly configured?
By: Jörn Guy Süß on Sun, 06 November 2022
8 3211 Wed, 09 November 2022 00:15
By: Jörn Guy Süß
  Compatible versions of emf/eclipse/hibernate with Teneo 2.2.3
[Teneo]
By: zx qu on Tue, 08 November 2022
6 1301 Tue, 08 November 2022 23:39
By: zx qu
  [CDO] Outdated lock state when releasing a durable lock
By: Robert Schulk on Tue, 06 September 2022
5 3318 Tue, 08 November 2022 17:06
By: Eike Stepper
  [CDO] ChangedInTargetAndDetachedInSourceConflict resolution
By: Vincent Sennedot on Mon, 24 October 2022
4 3974 Tue, 08 November 2022 10:21
  [CDO] Sporadic IOException: String ID unknown
By: Alain Picard on Thu, 27 October 2022
4 3561 Mon, 07 November 2022 17:40
By: Alain Picard
  [CDO] Reject change in conflict
Getting my hands wet
By: Wilbert Alberts on Tue, 13 September 2022
2 3431 Fri, 04 November 2022 10:27
By: Wilbert Alberts
  Export ECore to XSD
By: Jonas Strehle on Wed, 02 November 2022
1 787 Wed, 02 November 2022 12:03
By: Ed Merks
  Why is the Ecore iD attribute scoped to the resource?
EMF resource semantics
By: Jörn Guy Süß on Sun, 23 October 2022
8 2296 Mon, 24 October 2022 07:11
By: Ed Merks
  Handling of very large model instances
By: Robert Enyedi on Mon, 02 July 2007
3 2265 Thu, 20 October 2022 06:15
By: Rajesh Chandrasekar
  CDO commit change procedure
By: Rauno Ots on Wed, 05 October 2022
3 1654 Mon, 17 October 2022 07:42
By: Eike Stepper
  [EMF] Dedicated editing domain for each model element editor in RCP?
By: Roman Zimmer on Mon, 31 July 2017
10 11179 Sun, 16 October 2022 06:41
By: Ed Merks
  Generating errors in java class from an xsd file that contains special character like "µ"
my java classes doesn't understand the µ and ° character and replace them with "?".
By: Junior Developpeur04 on Thu, 13 October 2022
1 1289 Fri, 14 October 2022 06:14
By: Ed Merks
  Proper way to store and save EObjects
Design
By: Frank Conover on Thu, 06 October 2022
8 1755 Tue, 11 October 2022 16:21
By: Frank Conover
  Problem with Features of Type Class
Inconsistent implementation in EcoreFactoryImpl
By: Thomas Kohler on Wed, 05 October 2022
4 2002 Fri, 07 October 2022 08:39
By: Ed Willink
  Model not shown properly in Model Explorer
By: Avi Shaked on Thu, 06 October 2022
0 1821 Thu, 06 October 2022 08:47
By: Avi Shaked
  [CDO][NET4J] SSL and negotiator type="challenge"
SSL and negotiator type="challenge" not working
By: Alexander Stenzer on Tue, 20 September 2022
3 2900 Wed, 21 September 2022 02:46
By: Eike Stepper
  Create ecore annotation model and use it in another ecore model
By: Steve Peters on Mon, 12 September 2022
5 2526 Wed, 14 September 2022 06:07
By: Ed Merks
  EMF Combo Box in GenericEditor
By: ilke Muhtar on Fri, 02 September 2022
1 1942 Fri, 02 September 2022 13:41
By: Ed Merks
  Question wrt EMF Services
By: Geoffry Roberts on Sat, 20 August 2022
7 2928 Thu, 25 August 2022 06:55
By: Pierre-Charles David
  [CDO] Prevent timeout of custom long-running CDOQuery
By: Robert Schulk on Thu, 18 August 2022
2 1341 Fri, 19 August 2022 07:47
By: Robert Schulk
  Derived Attributes are validated
Derived attribute is a computed attribute and should not be validated
By: Yigal Spinner on Mon, 15 August 2022
0 2230 Mon, 15 August 2022 17:24
By: Yigal Spinner
  a registered resource factory is needed" outside the generated editor
a registered resource factory is needed - Will not read ???
By: Thoybur Rohman on Sat, 30 July 2022
2 2820 Mon, 01 August 2022 22:38
By: Thoybur Rohman
  Fomratting won't work correctly when save xtext resource programmatically AbstractFormatter2
By: Nagaraj Kandoor on Mon, 01 August 2022
3 1549 Mon, 01 August 2022 15:07
By: Ed Merks
  EMF.edit gestString multiple editors & cross references
NullPointerException because "delegateResourceLocators[i]" is null
By: Eric Jeunieaux on Thu, 28 July 2022
1 1243 Thu, 28 July 2022 10:09
By: Ed Merks
  [CDO] Performance issues while migrating to java 11 ?
By: Cyril Chevé on Thu, 30 June 2022
4 3009 Thu, 28 July 2022 06:28
By: Eike Stepper
  Problems with adding new child during the creation of a model instance
Creation of a model instance starting from metamodel
By: Federico Paolone on Wed, 27 July 2022
1 954 Wed, 27 July 2022 15:54
By: Ed Merks
  [CDO] Offline Master/Clone example throws NPE
CDO offline example
By: Jay Graham on Sat, 23 July 2022
2 1580 Mon, 25 July 2022 10:13
By: Jay Graham
  How can I see the exact query EMF executes?
By: I S on Sat, 16 July 2022
6 3413 Thu, 21 July 2022 04:54
By: I S
  Problems using Ecore OCL for derived
New problem when Generating an Ecore project with OCL used for derived attributes
By: Avi Shaked on Mon, 18 July 2022
2 2072 Tue, 19 July 2022 07:42
By: Avi Shaked
  [CDO] Duplicating a branch
By: Alain Picard on Tue, 12 July 2022
3 2408 Wed, 13 July 2022 12:51
By: Eike Stepper
  [CDO]Error while prefetch lock state
By: fang li on Mon, 20 June 2022
1 1686 Mon, 20 June 2022 08:54
By: Eike Stepper
  [CDO] conflict merge
How to merge conflicts manually
By: fang li on Fri, 17 June 2022
0 14428 Fri, 17 June 2022 06:43
By: fang li
  [CDO] Issue with closing view
By: Ewoud Werkman on Thu, 16 June 2022
1 1738 Thu, 16 June 2022 15:12
By: Eike Stepper
  BPMN model with multiple diagrams
By: Ra Coon on Tue, 14 June 2022
1 1551 Tue, 14 June 2022 13:35
By: Ed Merks
  Problem starting wizard in generated editor plugin. Unable to instantiate
By: Eclipse User on Sat, 10 November 2007
9 8492 Tue, 14 June 2022 07:56
By: Ed Merks
  EmfModel creation from a Resource object?
By: James Harbin on Tue, 07 June 2022
2 3251 Wed, 08 June 2022 04:27
By: Ed Merks
  Mixing UUIDs and positional identifiers in one model
By: Jan-Philipp Steghöfer on Mon, 30 May 2022
8 4171 Tue, 31 May 2022 11:39
  How to get a column with CDO
By: I S on Tue, 17 May 2022
1 4933 Sun, 22 May 2022 10:28
By: Eike Stepper
  Binary serialization to existing OutputStream
By: mila borans on Sat, 21 May 2022
1 2139 Sun, 22 May 2022 07:38
By: Ed Merks
  Why refresh call in PlatformResourceURIHandlerImpl.WorkbenchHelper.createPlatformResourceInputStream
By: Christian Dietrich on Thu, 19 May 2022
4 1850 Thu, 19 May 2022 18:22
  xsd to Ecore: Trouble with xsd:Extension
Trouble with loading an XML against ecore with an extension
By: Anne Hermann on Mon, 16 May 2022
5 2677 Tue, 17 May 2022 09:23
By: Ed Merks
  EMF compare post processor for multiple files
By: Daniel Soell on Mon, 16 May 2022
0 3694 Mon, 16 May 2022 12:06
By: Daniel Soell
  Embed BPMN2 Modeler eclipse to another eclipse project
embeding an eclipse plugin to another eclipse project
By: Zenith Arnejo on Wed, 04 May 2022
3 2050 Thu, 05 May 2022 07:45
By: Zenith Arnejo
  [CDO] [ERROR] Buffer@6,443[RELEASED]
Server fails after running
By: Alexander Stenzer on Thu, 28 April 2022
4 3580 Mon, 02 May 2022 07:26
  How to avoid the output of an element path instead of its ID?
By: Ralph Soika on Tue, 26 April 2022
2 2153 Thu, 28 April 2022 07:15
By: Ed Merks
  how to load other project's ecore resource
how to load other project‘s ecore resource
By: fang li on Mon, 25 April 2022
2 1886 Tue, 26 April 2022 00:59
By: fang li
  How to keep the namespace prefix when saving a new model
By: Ralph Soika on Mon, 25 April 2022
2 950 Mon, 25 April 2022 19:43
By: Ralph Soika
  Weird maven-dependency-plugin copy problem with emf.common.2.19
By: Brandon Lewis on Sun, 20 March 2022
4 3634 Mon, 25 April 2022 19:17
By: Ewoud Werkman
  Generate EMF from XSD failed with BPMN 2.0
By: Ralph Soika on Sun, 24 April 2022
1 1564 Mon, 25 April 2022 07:38
By: Ed Merks
  Unable to define multiple child creation extenders
Unable to extend metamodel by creating other metamodels importing it and defining subclasses, it works fine once, but not twice
By: Bruno Curzi-Laliberté on Fri, 22 April 2022
3 1297 Fri, 22 April 2022 15:51
  [CDO] list=>database mapping: internal index is wrong in rare cases
By: Robert Schulk on Tue, 19 April 2022
0 3680 Tue, 19 April 2022 13:43
By: Robert Schulk
  [CDO] Thread blocked on CDOIDUtil.createLong
By: Gabe Colburn on Tue, 15 March 2022
3 2093 Mon, 18 April 2022 22:57
By: Gabe Colburn
  Eclipse Indigo 3.7.2 Proxy Problem
Eclipse
By: Dragos Vlasceanu on Thu, 29 January 2015
3 5312 Fri, 15 April 2022 04:56
By: Ed Merks
  [CDO] How can we prevent TimeoutRuntimeException for large commits
By: Robert Schulk on Thu, 31 March 2022
3 1788 Fri, 01 April 2022 09:32
By: Eike Stepper
  What Font Does Sample Ecore Editor Use?
By: Brandon Lewis on Mon, 28 March 2022
3 1464 Tue, 29 March 2022 12:35
By: Brandon Lewis
  xtext some .dsl files shall not be checked from grammar
By: Dennis Untiet on Fri, 25 March 2022
1 1565 Fri, 25 March 2022 15:06
By: Ed Merks
  xtend src-gen folder relative to dsl file
1 1462 Fri, 25 March 2022 15:06
By: Ed Merks
  How to create UMLPackage object using ResourceSet?Or how to convert EPackage object to UMLPackage?
EMF
By: qiaosen liu on Tue, 22 March 2022
1 1580 Tue, 22 March 2022 15:00
By: Ed Merks
  Binary compatibility of EMF models
Extending an EMF model which comes from another binary w.r.t. feature id.
By: Marcus Höpfner on Tue, 15 March 2022
5 2840 Thu, 17 March 2022 10:19
By: Marcus Höpfner
  Generating updated feature description
By: Alain Picard on Tue, 15 March 2022
6 2255 Wed, 16 March 2022 14:28
By: Alain Picard
  Set-accessor Body?
Set-accessor Body?
By: Antonio Garmendia on Tue, 08 March 2022
5 2492 Thu, 10 March 2022 10:40
  Optimizing AuditListTableMappingWithRages.moveUp/Down
By: Linuxhippy Mising name on Wed, 02 March 2022
2 1933 Thu, 03 March 2022 09:29
  [CDO] NPE in AbstractQueryIterator.close(AbstractQueryIterator.java:88)
By: Linuxhippy Mising name on Wed, 16 February 2022
2 2244 Wed, 02 March 2022 10:27
  [CDO] Remote unlocking mechanism changed
By: Robert Schulk on Wed, 23 February 2022
2 3661 Wed, 02 March 2022 08:44
By: Robert Schulk
  [CDO] Standalone CDO client
CDO standalone
By: Yvan Lussaud on Mon, 28 February 2022
6 2175 Tue, 01 March 2022 12:28
By: Eike Stepper
  CDO - different protocol versions
different protocol versions of server and client
By: Stefan Ey on Thu, 24 February 2022
1 2146 Sat, 26 February 2022 03:19
By: Eike Stepper
  refreshing view after delete
By: Olivier BISSON on Fri, 25 February 2022
1 1111 Fri, 25 February 2022 21:28
By: Ed Merks
  Custom icon for project in model explorer
By: Thomas Barth on Thu, 24 February 2022
1 1383 Thu, 24 February 2022 12:05
By: Ed Merks
  Proto-project for UML in EMF
Create a simple ready-to-use project for UML browsing in Eclispe
By: Edouard R. Batot on Wed, 23 February 2022
2 1604 Wed, 23 February 2022 14:41
  Find the path between two classes
By: John Henbergs on Mon, 21 February 2022
7 2444 Tue, 22 February 2022 11:04
By: Ed Merks
  Create a runtime model using EMF
By: atepheh kh on Fri, 04 February 2022
3 2092 Sun, 13 February 2022 09:27
By: Ed Merks
  Searching for a guide for Maven/Gradle builds and EMF(-based) frameworks
Do a comprehesive guide to use EMF outside Eclipse exists?
By: Ricardo \\\"CaWal\\\" Cacheta Waldemarin on Thu, 10 February 2022
2 2123 Thu, 10 February 2022 13:28
By: Pavel Vlasov
  how to make a ComboView not selectable
comboviewer emf parsley
By: Olivier BISSON on Wed, 09 February 2022
1 1393 Thu, 10 February 2022 05:59
By: Ed Merks
  Suspected inconsistencies in URIHandler.exist
By: Sebastian Zarnekow on Thu, 03 February 2022
4 4310 Mon, 07 February 2022 12:13
  [CDO] Rare problem in permission cache
NoPermissionException when modifying a writable object
By: Robert Schulk on Thu, 03 February 2022
7 4704 Fri, 04 February 2022 07:54
By: Robert Schulk
  Short Survey About Requirements Engineering
By: Etem Çetin Toptani on Sun, 30 January 2022
0 3474 Sun, 30 January 2022 12:14
  EMF Edit localization in a stand-alone application
By: Denis Nikiforov on Thu, 20 January 2022
2 1618 Fri, 21 January 2022 15:26
By: Denis Nikiforov
  Genmodel Shorting Names for Edit Plugin
By: Simon BBBBBBB on Fri, 21 January 2022
1 1192 Fri, 21 January 2022 13:35
By: Ed Merks
  [CDO] CDOTransactionImpl: System.out.println()
By: Cyril Chevé on Thu, 20 January 2022
2 1641 Thu, 20 January 2022 14:23
By: Eike Stepper
  [CDO] [Announce] Hotfix Release 4.17 Is Now Available
This release fixes a database connection leak that was introduced with 4.16.
By: Eike Stepper on Mon, 17 January 2022
0 3292 Mon, 17 January 2022 05:57
By: Eike Stepper
  Display Icon from platform: instead of plugin:
Displaying icons from workspace images works, but editing tree view gets slower and slower
By: Bof Self on Fri, 07 January 2022
5 3100 Sun, 09 January 2022 19:53
By: Bof Self
  Model and meta model
By: jo ber on Fri, 07 January 2022
1 985 Fri, 07 January 2022 16:07
By: Ed Merks
  How could I fully get EMF models from an XML resource?
By: Weixing Zhang on Mon, 20 December 2021
1 1154 Mon, 20 December 2021 11:31
By: Ed Merks
  [CDO] Increasing prefetch performance
By: Robert Schulk on Mon, 22 November 2021
4 3353 Mon, 06 December 2021 12:50
By: Robert Schulk
  Generate Tests for Non-plugin Projects
By: Christian Damus on Tue, 30 November 2021
3 1644 Wed, 01 December 2021 19:39
By: Ed Willink
  Automatically set the value of a property
By: Jan Crkvic on Sun, 28 November 2021
1 1252 Mon, 29 November 2021 05:45
By: Ed Willink
  Access EMF object in Xtend
By: Jan Crkvic on Wed, 24 November 2021
14 3864 Sat, 27 November 2021 17:42
By: Ed Willink
  Copy&Paste between maps fails in Sample Ecore Editor
By: Harald Mackamul on Thu, 25 November 2021
2 2324 Fri, 26 November 2021 09:23
By: Harald Mackamul
  [CDO] Startup error on linux getConfig().getBufferProvider() == null
By: Thorsten Schlathölter on Wed, 28 October 2015
4 3259 Tue, 23 November 2021 08:56
By: Eike Stepper
  Modeling Servlet in EMF
By: Joel Craig on Thu, 18 November 2021
3 1580 Sun, 21 November 2021 23:08
By: Joel Craig
  [CDO] Documentation is unavailable
By: Oleg Kleshchev on Thu, 18 November 2021
10 2678 Fri, 19 November 2021 14:06
By: Ed Willink
  Large containment reference performance
By: Denis Nikiforov on Tue, 09 November 2021
4 1909 Thu, 18 November 2021 07:55
  UML/XMI resource loader connects to www.eclipse.org
During maven build, build gets stuck for minutes behind firewall
By: Mudi Obada on Tue, 16 November 2021
3 1274 Wed, 17 November 2021 15:10
By: Mudi Obada
  Reference elements from other Ecore models
By: John Henbergs on Mon, 27 September 2021
20 5964 Wed, 17 November 2021 14:57
By: Jan Crkvic
  General question about connection between model and "real world"
By: René Hilgemann on Mon, 01 November 2021
2 1171 Mon, 01 November 2021 17:30
By: René Hilgemann
  [CDO] Error saving an EByteArray
How does CDO map an EByteArray to a database
By: Ewoud Werkman on Tue, 13 April 2021
7 2575 Mon, 01 November 2021 14:03
By: Ewoud Werkman
  [CDO] Prefetch policy
By: Sorour Jahanbin on Sat, 05 June 2021
2 1668 Wed, 27 October 2021 14:50
By: Sorour Jahanbin
  EMF Pluggin
EMF Pluggin C , C++
By: granados peñate on Thu, 21 October 2021
3 2908 Tue, 26 October 2021 03:15
By: granados peñate
  Show diagrams in a graphical manner
By: Matthieu Hattab on Mon, 25 October 2021
2 1175 Mon, 25 October 2021 19:09
By: Matthieu Hattab
  EMF XML Serialization - change xsi:type to another attribute
By: Daniel Winkels on Sun, 17 October 2021
3 1703 Tue, 19 October 2021 15:36
By: Daniel Winkels
  XCore: Bundle 'org.eclipse.emf.ecore.xcore.lib' cannot be resolved
A newly created Xcore project has an invalid manifest.mf
By: Simon Cockx on Fri, 01 October 2021
4 2591 Wed, 13 October 2021 08:56
By: Simon Cockx
  [CDO] Best way to force unlocking view/locking manager
By: Alain Picard on Tue, 12 October 2021
1 1289 Tue, 12 October 2021 14:29
By: Eike Stepper
  Improving containment list performance in CDO/EMF
By: Alain Picard on Mon, 11 October 2021
10 2523 Tue, 12 October 2021 10:21
By: Alain Picard
  Reason for: A containment or bidirectional reference must be unique if its upper bound is different
0 3043 Mon, 11 October 2021 14:52
By: Alain Picard
  Object name instead of eProxyURI
By: John Henbergs on Sun, 10 October 2021
7 2305 Mon, 11 October 2021 05:03
By: Ed Merks
  Load EMF model instance with Xtend/Java
By: John Henbergs on Sat, 09 October 2021
5 2393 Sun, 10 October 2021 04:41
By: Ed Willink
  [CDO] Container reference db mapping- referential integrity problem
By: Erik Lundström on Mon, 27 September 2021
4 2450 Thu, 30 September 2021 12:18
By: Erik Lundström
  Ecore2Ecore language
By: Tomas Wall on Mon, 20 September 2021
1 1832 Wed, 22 September 2021 16:45
By: Ed Merks
  Getting CDOElementProxy in various places
By: Alain Picard on Tue, 14 September 2021
3 1959 Fri, 17 September 2021 15:34
By: Eike Stepper
  [CDO] Weird Issue with resources
By: Alain Picard on Thu, 12 August 2021
4 2352 Fri, 17 September 2021 08:53
By: Eike Stepper
  Using Ecore2Java with dependent models
CI/CD setup for EMF
By: Jörn Guy Süß on Mon, 06 September 2021
9 2732 Mon, 13 September 2021 05:34
By: Jörn Guy Süß
  Ecore for mapping metamodel
By: Tomas Wall on Thu, 02 September 2021
1 1686 Fri, 03 September 2021 11:49
By: Ed Willink
  Invoking XSDExporter (ModelConverter) programmatically
CI/CD for EMF functionality
By: Jörn Guy Süß on Thu, 02 September 2021
1 1134 Thu, 02 September 2021 04:53
By: Ed Merks
  Java.lang.RuntimeException: Cannot create a resource for 'xxxx'; a registered resource
error when trying to launch an ATL transformation from a Java program.
By: nour nour on Mon, 05 July 2021
8 3780 Thu, 26 August 2021 10:52
By: German Vega
  Ecore2Java ant task reports success, generates nothing.
Not possible to automate code generation in CI toolchain
By: Jörn Guy Süß on Fri, 20 August 2021
1 1062 Fri, 20 August 2021 08:07
By: Ed Merks
  Displaying animated Gif in a view
EMF Edit Code
By: Lukas Baron on Thu, 12 August 2021
3 1954 Sat, 14 August 2021 05:40
By: Ed Merks
  Identifier specification
By: jo ber on Thu, 05 August 2021
1 1374 Thu, 05 August 2021 13:19
By: Ed Willink
  Cannot instantiate generics in tree editor
By: Elie Richa on Tue, 13 July 2021
9 4029 Thu, 22 July 2021 06:36
By: Ed Merks
  generate a diagram for a model instance
how can I generate a diagram a model instance (for an instance of a metamodel)?
By: Morteza Yaqubkhani on Tue, 20 July 2021
2 1666 Wed, 21 July 2021 08:20
  Using OCL in xcore
Create OCL contrains for a xcore model
By: Steve Peters on Fri, 09 July 2021
3 1545 Sat, 10 July 2021 15:25
By: Ed Willink
  Error when running ecore codegen with tycho
Ecore Codegen Tycho
By: Rik X on Fri, 02 July 2021
3 1743 Wed, 07 July 2021 18:34
By: Ed Willink
Current Time: Wed Jul 17 20:18:15 GMT 2024
Powered by FUDForum. Page generated in 0.07575 seconds
