Forums will be read only after December 31st,2024
After 10 years of discussion and planning[1], these forums have been declared end of life, and will be replaced with a static read only copy on December 31, 2024. [1]https://gitlab.eclipse.org/eclipsefdn/helpdesk/-/issues/187
icon4.gif sticky: For e4 related questions please visit the "Eclipse 4" forum
By: Eclipse User on Mon, 04 November 2013
0 5835 Mon, 04 November 2013 17:00
  Remove Perspective from the Perspective Toolbar
By: Eclipse User on Fri, 30 August 2024
0 3413 Fri, 30 August 2024 12:13
  How to set the style of workbench by css
I did a practice but i don't know how to set the backgraound-color of MApplication and menu
By: Eclipse User on Thu, 18 July 2024
2 1554 Thu, 25 July 2024 06:08
  Remote Debugging Eclipse RCP
By: Eclipse User on Mon, 06 May 2024
0 1299 Mon, 06 May 2024 17:26
  Eclipse RCP & Hibernate
Hibernate with annotations does not work
0 1202 Mon, 06 May 2024 16:13
  How can i open the editor on a file from a jar
By: Eclipse User on Wed, 03 April 2024
0 1583 Wed, 03 April 2024 08:57
  RCP Integrated CDT
rcp,cdt,artop
By: Eclipse User on Sat, 16 March 2024
0 5637 Sat, 16 March 2024 14:17
  [CNF] Link with editor / lazy tree & auto-expanding the tree
By: Eclipse User on Thu, 29 July 2010
4 8241 Fri, 15 March 2024 19:37
  Run multiple instances of an RCP product/applications
By: Eclipse User on Fri, 01 March 2024
0 3449 Fri, 01 March 2024 17:57
  Eclipse plugin not using proxy (407 authentication required)
By: Eclipse User on Wed, 22 November 2023
3 2211 Thu, 25 January 2024 19:29
  Is there a way to add a toolbar item right beside quickaccess
By: Eclipse User on Thu, 11 January 2024
0 2172 Thu, 11 January 2024 20:45
  Detect User Inactivity and Logout (Eclipse RCP)
By: Eclipse User on Thu, 07 December 2023
1 1496 Tue, 26 December 2023 13:51
  Toolbars contributed to the coolbar not visible
Toolbars contributed to the coolbar after application initialization are not visible unless you manually lock and then unlock the toolbar region.
By: Eclipse User on Thu, 28 September 2023
1 1715 Wed, 13 December 2023 13:56
  maven tycho product launcher failed
maven tycho product launcher was failing outside of eclipse due to Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.sphinx.platform.internal.Activator.start() of bundle org.ecli
By: Eclipse User on Mon, 04 December 2023
0 41265 Mon, 04 December 2023 11:01
  Application could not be found in the registry.
Please help me understand this error trace
By: Eclipse User on Mon, 28 September 2009
4 13221 Tue, 14 November 2023 16:35
  Positioning of multi instance jface view in editor area
By: Eclipse User on Mon, 30 October 2023
0 1259 Mon, 30 October 2023 18:29
  Always visible perspective UI control?
Select perspective with UI control other than menu bar or perspective bar
By: Eclipse User on Tue, 24 October 2023
0 1399 Tue, 24 October 2023 03:44
  jdk 17 complaint p2 repo
By: Eclipse User on Mon, 16 October 2023
0 1599 Mon, 16 October 2023 05:05
  laptest p2 repository update from kepler
By: Eclipse User on Wed, 11 October 2023
0 1600 Wed, 11 October 2023 05:08
  enable/disable commands handler
By: Eclipse User on Thu, 26 May 2011
8 10518 Thu, 14 September 2023 10:04
  ClassNotFoundException emf.ecore cannot find emf.common
By: Eclipse User on Wed, 13 September 2023
0 1451 Wed, 13 September 2023 07:54
  How to listen theme change event ??
By: Eclipse User on Thu, 06 June 2013
2 45109 Wed, 30 August 2023 17:17
  Occasional Exit hang/crash
By: Eclipse User on Sat, 28 January 2012
1 9022 Sun, 13 August 2023 14:18
  Disabling the Inspection of Web Content in Apps
Disable webView inspection from outside an RCP app
By: Eclipse User on Tue, 25 July 2023
0 2037 Tue, 25 July 2023 08:57
  Java 11 and javax.annotation
Java11 does not include javax.annotation anymore which results in runtime errors.
By: Eclipse User on Tue, 21 March 2023
1 1494 Wed, 22 March 2023 07:47
  Restore a workbenchpage with an external memento.xml without closing eclipse 3.1
By: Eclipse User on Fri, 27 January 2006
2 6313 Thu, 16 March 2023 19:06
  Support for Eclipse RCP on MacOS?
By: Eclipse User on Mon, 15 August 2022
1 2719 Sat, 04 March 2023 23:11
  Force usage of external browser for help
By: Eclipse User on Tue, 31 January 2023
0 1904 Tue, 31 January 2023 09:31
  'No product definitions found' in tycho build
RCP build failing to materialize product
By: Eclipse User on Sun, 08 January 2023
1 1226 Mon, 09 January 2023 19:20
  How can i add multiple banner with eclipse rcp?
By: Eclipse User on Fri, 13 May 2016
3 5675 Wed, 23 November 2022 04:21
  activeWhen is not evaluated by IEvaluationService.requestEvaluation
By: Eclipse User on Thu, 17 November 2022
0 1839 Thu, 17 November 2022 16:25
  Eclipse RCP with Lombok and/or MapStruct ?
By: Eclipse User on Mon, 14 November 2022
0 1591 Mon, 14 November 2022 22:01
  Disable Help Topics in rcp application
By: Eclipse User on Wed, 06 April 2011
3 6055 Wed, 09 November 2022 15:49
  Images missing in Eclipse IDE
By: Eclipse User on Mon, 07 November 2022
0 1973 Mon, 07 November 2022 13:51
  Eclipse RCP tutorial
How to add an item on right click on a given file extension
By: Eclipse User on Sat, 17 September 2022
0 2001 Sat, 17 September 2022 22:42
  Eclipse Dropins Folder
By: Eclipse User on Fri, 16 September 2022
0 3000 Fri, 16 September 2022 14:25
  Plugin Testing 4.19
0 2987 Fri, 16 September 2022 13:00
  The RCP app is running in the background without any UI.
By: Eclipse User on Thu, 25 August 2022
0 3084 Thu, 25 August 2022 19:47
  Syntax Error in Export Logs
Syntax Error in export logs
By: Eclipse User on Thu, 18 August 2022
0 2008 Thu, 18 August 2022 22:17
  Exported Product cant load (any?) bundles
RCP Feature Export
By: Eclipse User on Fri, 12 August 2022
0 2248 Fri, 12 August 2022 18:38
  Is it safe to remove jdk/jmods of open-jdk for a sandboxed-with-JDK Eclipse RCP application
By: Eclipse User on Thu, 21 July 2022
0 2717 Thu, 21 July 2022 06:38
  unable to load plugins from http://download.eclipse.org/releases/kepler
unable to import plugins from target
By: Eclipse User on Mon, 04 July 2022
1 3029 Fri, 08 July 2022 08:09
  Eclipse RCP Application cannot find logback implemenmtation
SLF4j cannot load logback implementation
By: Eclipse User on Sun, 26 June 2022
1 2529 Tue, 28 June 2022 15:20
  How do I sign Jars when exporting an Eclipse RCP product?
By: Eclipse User on Tue, 24 May 2022
2 3900 Wed, 25 May 2022 11:51
  RCP Application do not export product with Babel feature
By: Eclipse User on Wed, 27 April 2022
0 2957 Wed, 27 April 2022 15:05
  Can't add org.eclipse.e4.ui.progress bundle as dependency
By: Eclipse User on Fri, 08 April 2022
2 1573 Sat, 09 April 2022 13:24
  OSGI Console not visible
1 2415 Sat, 09 April 2022 10:13
  Config Data Location of RCP Application
By: Eclipse User on Sun, 03 April 2022
3 3123 Wed, 06 April 2022 09:39
  PKCS11 Java 11
Access to modules from RCP plugin
By: Eclipse User on Mon, 31 January 2022
0 22974 Mon, 31 January 2022 16:59
  --add-opens in INI file not correctly used by launcher?
By: Eclipse User on Sat, 29 January 2022
2 8490 Mon, 31 January 2022 15:16
  HandlerUtil for isEnabled of handler
There is extremelly usefull utility HandleUtil class. But what if I need its features in the handler's isEnabled method?
By: Eclipse User on Fri, 20 November 2020
1 10419 Wed, 12 January 2022 22:19
  Building an Eclipse RCP application for Raspian aarch64 fails because of missing SWT classes
Missing SWT classes (ClassNotFoundException) but org.eclipse.swt.gtk.linux.aarch64.jar exists in directory
By: Eclipse User on Tue, 29 December 2020
2 2895 Wed, 12 January 2022 22:12
  Fixed Window Size depending on perspective
By: Eclipse User on Thu, 08 April 2021
1 2360 Wed, 12 January 2022 22:02
  Eclipse RCP Application (using p2 repo) Build automation using Ant
By: Eclipse User on Mon, 11 January 2021
1 2481 Wed, 12 January 2022 22:00
  Launcher Icon does not get reflected in the windows exe generated file
By: Eclipse User on Sun, 25 April 2021
1 2536 Wed, 12 January 2022 21:56
  target file versus Artifactory/Maven
How to change the Artifactory inside the target-file
By: Eclipse User on Mon, 26 April 2021
1 3120 Wed, 12 January 2022 21:54
  Eclipse photon and Eclipse oxygen compatibility in Mac BigSur
Is it possible to run Eclipse photon or Eclipse oxygen on Mac BigSur
By: Eclipse User on Tue, 31 August 2021
2 1896 Wed, 12 January 2022 21:52
  Converting from RCP to RAP affect on target file
When converting an RCP client to an RAP, is the target file something that is needed?
1 3026 Wed, 12 January 2022 21:51
  TPS Vulnerabilities
How TPS issues are fixed in RCP development
By: Eclipse User on Wed, 05 May 2021
1 6089 Wed, 12 January 2022 21:50
  How to add "Build project" option to my custom project in RCP application
By: Eclipse User on Mon, 24 May 2021
1 2852 Wed, 12 January 2022 21:47
  Composite form scrolls on top on radio or check button select
RCP 3.2 to 4.8 migration (compatibility mode) impacted Composite UI form
By: Eclipse User on Thu, 24 June 2021
1 2555 Wed, 12 January 2022 21:35
  Error on creating workspace for the first time
By: Eclipse User on Sun, 05 September 2021
1 3018 Wed, 12 January 2022 21:26
  Ecliplse Plugin Development using JPMS
Developing a plug-in for eclipse, I would like to use some jar dependencies inside plug-in which are packed as modules.
By: Eclipse User on Thu, 21 October 2021
1 3101 Wed, 12 January 2022 21:16
  Export RCP
error when exporting RCP product
By: Eclipse User on Fri, 22 October 2021
1 3326 Wed, 12 January 2022 20:52
  RCP product with few options for creating new project
By: Eclipse User on Tue, 30 November 2021
2 2819 Mon, 06 December 2021 13:10
  Weird error while trying to start RCP Client using Webstart jnlp
By: Eclipse User on Thu, 11 February 2021
4 19880 Thu, 16 September 2021 14:43
  Eclipse RCP Application not working on MacOS
By: Eclipse User on Thu, 09 September 2021
1 1449 Thu, 09 September 2021 12:43
  Perspective customizations not being respected
By: Eclipse User on Mon, 17 September 2012
5 4185 Thu, 09 September 2021 09:28
  How to use maven with RCP applications
Guidance in how to chose maven archetype
By: Eclipse User on Thu, 19 August 2021
1 3056 Thu, 19 August 2021 14:39
  Duplicate toolbars
Toolbars duplicated after upgrading from 3.x to 4.x compatibility layer.
By: Eclipse User on Thu, 07 June 2018
2 5334 Mon, 16 August 2021 17:34
  dirty parts sometimes not shown for saving on application closing
bug or desired behaviour: dirty parts sometimes not shown for saving on application closing
By: Eclipse User on Tue, 10 August 2021
1 1894 Fri, 13 August 2021 11:52
  Bundle lib uses getSystemResource
1 2172 Fri, 13 August 2021 11:48
  Undo not working from keyboard in custom view but working using mouse shortcut
By: Eclipse User on Thu, 29 July 2021
6 4470 Tue, 10 August 2021 12:20
  Plugin/Feature not loaded
By: Eclipse User on Mon, 19 July 2021
2 2213 Wed, 21 July 2021 09:41
  RCP App + java.awt.Desktop#setOpenUriHandler on MacOS
Advice in tracking down the issue related to URI scheme calls handling in RCP app.
By: Eclipse User on Thu, 01 July 2021
2 1992 Mon, 05 July 2021 11:32
  How to install Tycho on top Maven
Guidance in how to retrieve and install Tycho on top Maven
By: Eclipse User on Tue, 29 June 2021
1 1453 Tue, 29 June 2021 13:27
  which is the idle place to add the license check code in my RCP application
By: Eclipse User on Wed, 24 March 2021
2 1304 Wed, 07 April 2021 12:32
  Notarizing a RCP app on Mac
RCP notarization
By: Eclipse User on Wed, 31 March 2021
1 1409 Thu, 01 April 2021 22:23
  Application from scratch: e3 or e4?
By: Eclipse User on Tue, 27 October 2020
6 3282 Fri, 05 March 2021 14:27
  Display progress bar when opening an editor takes a long time
By: Eclipse User on Mon, 16 June 2014
1 4497 Wed, 24 February 2021 15:06
  SWT_AWT.new_Frame never returns on Linux
By: Eclipse User on Tue, 09 February 2021
0 14737 Tue, 09 February 2021 13:15
  Deploy Eclipse RCP based IDE to cloud
By: Eclipse User on Sat, 06 February 2021
4 2343 Mon, 08 February 2021 13:49
  RCP Help System: Tree icons could not be loaded
By: Eclipse User on Fri, 29 January 2021
1 3341 Tue, 02 February 2021 14:17
  Target Platform: No plugins found in repository?
By: Eclipse User on Fri, 15 January 2021
0 4262 Fri, 15 January 2021 09:12
  Codesigning causes broken app
By: Eclipse User on Wed, 23 December 2020
2 3074 Fri, 25 December 2020 14:18
  log WARN on RCP exit from org.apache.felix.scr
By: Eclipse User on Fri, 10 July 2020
3 2151 Sat, 12 December 2020 11:58
  RCP Product always exported old version of eclipse
By: Eclipse User on Fri, 27 November 2020
0 2981 Fri, 27 November 2020 08:12
  Force editor to (re)validate/refresh
During the configuration changed in the backend, I need to force the validation of the editor with that new informations
By: Eclipse User on Wed, 26 August 2020
2 2114 Fri, 20 November 2020 13:10
  running "external tools" from context menu
By: Eclipse User on Fri, 13 May 2011
7 8480 Tue, 10 November 2020 09:05
  hideView() no longer working after 64-bit migration
Problem closing a view tab after 64-bit migration of an RCP application
By: Eclipse User on Thu, 05 November 2020
0 2779 Thu, 05 November 2020 18:02
  Mouse wheel event handler cannot be be handled running RCP app on non-development platform
By: Eclipse User on Fri, 23 October 2020
0 1852 Fri, 23 October 2020 11:38
  put a view at the editor area of a perpective by default
I want to put my viewpart at the editor area by default. and I don't know how to code it in perspective class.
By: Eclipse User on Mon, 19 October 2020
0 2233 Mon, 19 October 2020 05:56
  eclipse rcp dopins for automation not showing any errors and not execting.
Eclipse RCP Test Automation Framework
By: Eclipse User on Mon, 14 September 2020
0 2234 Mon, 14 September 2020 10:44
  e4 and error log view
Is there a pure e4 error log view
4 2373 Sun, 13 September 2020 10:35
  make eclipse plugin as directory fromat
Log4j reusable plugin to map as required bundle for all other plugins in workspace
By: Eclipse User on Wed, 02 September 2020
0 7971 Wed, 02 September 2020 15:25
  swt browser in view crash when loading ext js page with complex and heavy layout
By: Eclipse User on Wed, 19 August 2020
2 1954 Fri, 28 August 2020 16:36
  Change the style of property sheet
UI of property sheet
1 1829 Mon, 24 August 2020 08:56
  p2 repository update with log4j2x
p2 repository with log4j2x
By: Eclipse User on Mon, 17 August 2020
3 1711 Mon, 17 August 2020 19:01
  Enable Eclipse Project Explorer extension only when two elements are selected
By: Eclipse User on Tue, 11 August 2020
1 2791 Tue, 11 August 2020 17:50
  Apple is moving to ARM processors
What will the Eclipse and RCP road maps look like in response?
By: Eclipse User on Mon, 22 June 2020
2 5523 Thu, 30 July 2020 09:09
  Integrating Terminal to Custom IDE
Trying To Integrate Terminal to our custom IDE, we are not able to integrate it.
By: Eclipse User on Wed, 15 July 2020
1 1790 Thu, 16 July 2020 06:23
  Could not resolve module / unresolved requirement org.eclipse.core.runtime
By: Eclipse User on Tue, 14 July 2020
1 6552 Thu, 16 July 2020 06:21
  Update the tool control values programmatically
By: Eclipse User on Mon, 13 July 2020
1 1968 Thu, 16 July 2020 06:12
  Missing bundle javax.xml
4 2862 Sat, 11 July 2020 15:30
  Public SSH Key adding option is disabled in Gerrit
Unable to add public ssh key in Gerrit as the element is disabled
By: Eclipse User on Thu, 02 July 2020
1 1255 Thu, 02 July 2020 18:28
  Create a custom project category from a project type
By: Eclipse User on Wed, 24 June 2020
1 1444 Wed, 24 June 2020 12:49
  License File
By: Eclipse User on Wed, 17 August 2011
1 8947 Tue, 23 June 2020 21:44
  non-osgi jars: embedded in bundle or in plugin directory?
By: Eclipse User on Thu, 04 February 2010
7 10022 Thu, 11 June 2020 08:41
  grid table Toolbar items not getting visible
By: Eclipse User on Wed, 06 May 2020
1 2439 Thu, 04 June 2020 09:32
  Not able to add view to IDE
I'm trying to add view to the existing plugin, after adding view in pom.xml file also view is not reflecting.
By: Eclipse User on Wed, 27 May 2020
6 2995 Fri, 29 May 2020 11:19
  Problem while launching RCP application as using .product file.
By: Eclipse User on Mon, 25 December 2006
3 5863 Wed, 20 May 2020 04:15
  Run Unittests on Jenkins: Could not load SWT library
By: Eclipse User on Tue, 19 May 2020
0 2349 Tue, 19 May 2020 13:09
  Eclipse RCP Dynamic help customization with dynamic url
Customizing Eclipse help url on fly
By: Eclipse User on Fri, 01 May 2020
3 2091 Mon, 11 May 2020 10:14
  eclipse custom widget like "Outline" or "help"
By: Eclipse User on Thu, 07 May 2020
0 2330 Thu, 07 May 2020 07:41
  Problem compiling RCP using Tycho
By: Eclipse User on Tue, 21 April 2020
2 1838 Tue, 21 April 2020 09:40
  Is there any way to let common navigator framework respond to unsaved changes?
Common navigator framework
By: Eclipse User on Sun, 19 April 2020
0 3322 Sun, 19 April 2020 20:13
  Scaling issues with text in toolbar
By: Eclipse User on Mon, 06 April 2020
4 3281 Tue, 14 April 2020 10:20
  unresolved requirements when running product
By: Eclipse User on Mon, 24 December 2018
4 4807 Mon, 06 April 2020 09:26
  export failure
when i am exporting java plugin getting a error
By: Eclipse User on Fri, 27 March 2020
1 2442 Mon, 30 March 2020 15:43
  export failure
export fails due to director
0 2585 Fri, 27 March 2020 08:25
  Is order of application main toolbar elements restorable
By: Eclipse User on Mon, 16 March 2020
2 1564 Thu, 19 March 2020 06:58
  Performance problems with large layouts in RCP application
By: Eclipse User on Thu, 12 March 2020
4 2210 Wed, 18 March 2020 14:12
  Eclipse Wizard - Back Button event
By: Eclipse User on Tue, 04 February 2020
3 2956 Tue, 25 February 2020 09:42
  Starting plugin with a non UI contribution
By: Eclipse User on Tue, 18 February 2020
3 2901 Mon, 24 February 2020 14:01
  Eclipse - Wizard Page
By: Eclipse User on Mon, 03 February 2020
1 1245 Mon, 03 February 2020 14:35
  Plugins load broken by org.eclipse.ui.decorator
The decorator extension corrupts the order in which the plugins gets loaded
By: Eclipse User on Thu, 30 January 2020
2 1947 Fri, 31 January 2020 16:57
  Debug configuration - HELP
By: Eclipse User on Thu, 09 January 2020
9 2700 Thu, 16 January 2020 14:46
  Deployment decisions for an exported RCP Product
I would like to learn about the different options to install an rcp product plus their consequences
By: Eclipse User on Fri, 20 December 2019
1 3643 Sun, 12 January 2020 12:27
  Non-default Perspective Content no Showing
Fragment UI
By: Eclipse User on Fri, 06 December 2019
1 2397 Fri, 13 December 2019 07:50
  missing constraint: Import package: javax.xml.stream; version
While launching child eclipse on RCP package, found an issue stating missing constraint
By: Eclipse User on Thu, 05 December 2019
1 6312 Fri, 13 December 2019 07:47
  Get the current launch configuration
By: Eclipse User on Wed, 11 December 2019
4 2030 Thu, 12 December 2019 08:31
  Setting the correct build configuration
By: Eclipse User on Tue, 10 December 2019
1 1614 Tue, 10 December 2019 19:28
  Integrating QT with Eclipse
By: Eclipse User on Tue, 03 December 2019
3 2369 Thu, 05 December 2019 12:30
  REST client within plugin
By: Eclipse User on Wed, 13 November 2019
2 4046 Sun, 01 December 2019 17:28
  Eclipse exported Product file is not working.
Product is created for the eclipse plug-in developed on Ecore model.
By: Eclipse User on Thu, 28 November 2019
13 5845 Fri, 29 November 2019 13:47
  Eclipse Plugin - Custom Builder
By: Eclipse User on Thu, 21 November 2019
1 4999 Thu, 28 November 2019 19:21
  Feasibility of swapping/swtiching between views when an event occurs
Feasibility of swapping/switching between views when an event occurs
1 2661 Thu, 28 November 2019 09:27
  Strange Menu Drawing Behavior With Exported RCP
By: Eclipse User on Mon, 18 November 2019
1 4418 Thu, 28 November 2019 03:26
  Secondary IDs broken?
Views with Secondary IDs recreated instead of reused on perspective change
By: Eclipse User on Wed, 20 November 2019
2 1678 Mon, 25 November 2019 23:16
  Eclipse 4 RCP Plugin. Programmatically import projects
Importing projects with a CLI triggered plugin while Eclipse is running
8 3753 Fri, 22 November 2019 16:52
  close and reopen a view
1 2121 Wed, 20 November 2019 20:13
  Create Java Editor Using Eclipse RCP
Creation of Java Editor which supports code completion and Syntax Highlighting
By: Eclipse User on Tue, 03 January 2017
1 17232 Fri, 15 November 2019 06:39
  openFile operation does not work for one of our product based on eclipse RCP.
openFile operation does not work for one of our product based on eclipse oxygen rcp
By: Eclipse User on Thu, 14 November 2019
0 3239 Thu, 14 November 2019 11:05
  launcher.openFile not working on RCP
By: Eclipse User on Thu, 22 August 2013
2 4141 Thu, 14 November 2019 10:59
  Starting Perspective
By: Eclipse User on Wed, 10 July 2019
2 18291 Fri, 08 November 2019 17:16
  RCP for plugin runs via popup-menu
By: Eclipse User on Tue, 06 August 2019
3 5806 Fri, 08 November 2019 17:11
  Plugin execution after "Install into host. Repository:" destination
After set plugin.xml, MANIFEST.MF, and other files plugin works great in run and debug mode. But after I install it via "Install into host. Repository:" mode, it will not more work
By: Eclipse User on Tue, 22 October 2019
10 4818 Thu, 24 October 2019 14:33
  Error on exporting product
By: Eclipse User on Wed, 16 October 2019
3 4013 Tue, 22 October 2019 05:00
  Tooltip not getting set for Command having new Wizard
Tooltip not getting set for Command having new Wizard - org.eclipse.ui.newWizard
By: Eclipse User on Thu, 07 July 2016
10 7963 Fri, 18 October 2019 07:37
  Minimal stand-alone help system does not show my help plugin
By: Eclipse User on Thu, 17 October 2019
0 10659 Thu, 17 October 2019 04:23
  Can not start my plugin from CL
My simple plugin will not launch when I am using the CL
By: Eclipse User on Wed, 02 October 2019
2 5593 Thu, 10 October 2019 10:30
  Eclipse RCP + OpenjDK 11 + Openjfx
By: Eclipse User on Mon, 07 October 2019
0 22221 Mon, 07 October 2019 06:42
  Launch wizard from Active Help page in Eclipse
0 20215 Wed, 02 October 2019 17:06
  Sample Code for Hyperbola from book Eclipse Rich Client Platform
http://eclipsercp.org/ isnot accessible
By: Eclipse User on Tue, 01 October 2019
0 19952 Tue, 01 October 2019 08:16
  RCP xml file editor
Problems with implementing eclipse text editor in rcp
By: Eclipse User on Fri, 17 October 2014
1 5659 Mon, 30 September 2019 09:17
  In Built XML/SCXML editor for RCP application?
Are there in built XML editors ready to use for RCP application?
By: Eclipse User on Thu, 26 September 2019
1 7779 Mon, 30 September 2019 09:09
  Tycho-packaging-plugin ignoring <additionalFileSets> during feature build?
By: Eclipse User on Wed, 25 September 2019
1 4201 Thu, 26 September 2019 09:57
  Unpacked Jars are still kept as Jars after being unpacked
By: Eclipse User on Tue, 17 September 2019
0 10234 Tue, 17 September 2019 16:53
  About the SWT_AWT bridge focus bugs
By: Eclipse User on Thu, 25 April 2019
3 48135 Mon, 09 September 2019 13:35
  Handler enable/disable not working
By: Eclipse User on Sat, 31 August 2019
0 174182 Sat, 31 August 2019 09:11
  Plugin/Bundle remains in STARTING status
By: Eclipse User on Mon, 23 October 2017
2 6019 Fri, 23 August 2019 18:54
  how to run junit test case in a customized Eclipse workspace?
show ` Cannot change the location once it is set.` when I set a certain path in filesystem programatically
By: Eclipse User on Wed, 24 April 2019
1 46790 Fri, 23 August 2019 18:14
  Fragment with resource
By: Eclipse User on Wed, 22 May 2019
1 37246 Fri, 23 August 2019 18:10
  Can strings in introContent be externalized?
By: Eclipse User on Wed, 26 June 2019
1 51650 Fri, 23 August 2019 18:10
  RCP works in Eclipse fails after build
After a build, none of my views have their @PostConstruct methods called
By: Eclipse User on Fri, 19 July 2019
1 22181 Fri, 23 August 2019 17:47
  Additional plugins as required plugins
Add CDT and GNUMCU plugins as Required Plug-ins for RCP Plugin
By: Eclipse User on Mon, 29 July 2019
1 25518 Fri, 23 August 2019 17:40
  Problem with the correct definition of a propertyTester
By: Eclipse User on Thu, 08 August 2019
1 2753 Fri, 23 August 2019 17:34
  RCP Mac Build issues - You can't open the application "Eclipse" because it may be damaged
RCP Mac build errors
By: Eclipse User on Tue, 13 August 2019
2 6044 Fri, 23 August 2019 17:13
  Eclipse in Maven Central
By: Eclipse User on Fri, 12 April 2019
3 30545 Tue, 20 August 2019 18:14
  combo box in toolbar
By: Eclipse User on Wed, 13 October 2004
3 4658 Fri, 09 August 2019 09:15
  [WARNING] Target location type 'Directory' is not supported
Tycho maven is not picking up the plugins from the Directoy in target plugin
By: Eclipse User on Thu, 01 August 2019
1 3263 Thu, 01 August 2019 12:48
  Hi, I am new to RCP
Noob
By: Eclipse User on Mon, 05 November 2018
1 4241 Fri, 19 July 2019 14:54
  How to enforce fetching of a p2 repository to use a specific java version?
1 52205 Fri, 05 July 2019 14:00
  Eclipse RCP 3.x to 4.8 migration
Whether 3.x to 4.x migration of rcp with existing code will be supported in mixed mode
By: Eclipse User on Fri, 24 May 2019
1 42560 Fri, 31 May 2019 06:13
  How to reuse Eclipse3.x workbench on Eclipse4 platform
By: Eclipse User on Wed, 08 May 2019
2 4134 Fri, 10 May 2019 07:03
  How to disable calling viewPart.saveState at some interval
By: Eclipse User on Tue, 23 April 2019
2 7269 Thu, 25 April 2019 09:20
  Bundle JRE with RCP Product
By: Eclipse User on Fri, 13 November 2015
1 6138 Tue, 16 April 2019 18:45
  RCP launcher - JDK11 support ?
RCP - JDK11 : launcher compliancy ?
By: Eclipse User on Mon, 15 April 2019
0 41706 Mon, 15 April 2019 12:58
  Eclipse RCP Oxygen - Remote Help setup
0 39895 Fri, 12 April 2019 07:11
  RCP app widgets styling looks whitewashed in Mac OS Mojave
By: Eclipse User on Thu, 11 April 2019
1 3242 Fri, 12 April 2019 01:46
  Commands and dynamic menu
By: Eclipse User on Thu, 21 March 2019
1 18012 Tue, 09 April 2019 13:18
  References plugin
Which plugin should I use to find references
By: Eclipse User on Tue, 26 March 2019
0 17428 Tue, 26 March 2019 06:32
  Deployed Version is not running
Eclipse 4.10 or 4.11 - deployed Version not running
0 18080 Thu, 21 March 2019 17:01
  Proxy Settings Preferences in RCP application
By: Eclipse User on Mon, 18 March 2019
1 2241 Mon, 18 March 2019 13:37
  Preferences and Menu Items are gone with 4.10 (or 4.9.)
Restoring old user functionalities
By: Eclipse User on Mon, 04 February 2019
1 6939 Mon, 18 March 2019 08:22
  custom size for toolbar icon
By: Eclipse User on Thu, 07 March 2019
0 38890 Thu, 07 March 2019 14:14
  Scroll to one line in console plugin
eclipse
By: Eclipse User on Tue, 19 February 2019
0 10057 Tue, 19 February 2019 07:51
  Exchange (EMF-)Editor
By: Eclipse User on Tue, 05 February 2019
5 3087 Fri, 08 February 2019 20:21
  Testing classes with injected IEclipsePreferences
By: Eclipse User on Fri, 08 February 2019
2 3049 Fri, 08 February 2019 19:56
  Remove Preferences Dialog - type filter text
disable or remove type filter text
By: Eclipse User on Wed, 06 February 2019
0 6161 Wed, 06 February 2019 11:01
  Using latest SWT build in legacy RCP app
By: Eclipse User on Fri, 11 January 2019
1 4719 Fri, 25 January 2019 13:51
  Changes from RCP 4.9 to 4.10?
The type org.eclipse.swt.graphics.Image cannot be resolved. It is indirectly referenced from required .class files
By: Eclipse User on Fri, 28 December 2018
12 9857 Wed, 09 January 2019 14:41
  Custom Tooltip getting disposed when perspective is changed in Windows -10
Custom tool-tip set for Tree elements getting disposed when Perspective is changed in Windows 10
By: Eclipse User on Tue, 01 January 2019
0 2994 Tue, 01 January 2019 10:50
  Custom editor indentation
By: Eclipse User on Wed, 26 December 2018
0 3498 Wed, 26 December 2018 12:59
  Migrating Eclipse RCP
Trying to use latest eclipse version for RCP
By: Eclipse User on Wed, 12 December 2018
0 3361 Wed, 12 December 2018 06:49
  Product configuration in a separate project
How to define a product configuration in a separate project?
By: Eclipse User on Mon, 12 November 2018
1 4771 Tue, 20 November 2018 12:35
  org.eclipse.swt.SWTException: Unsupported or unrecognized format
By: Eclipse User on Thu, 08 September 2005
2 6980 Sat, 03 November 2018 00:54
  Layout issue in Windows
Error in RCP application for MS Windows sytems.
By: Eclipse User on Tue, 23 October 2018
0 2355 Tue, 23 October 2018 15:55
  Error In Maven POM.XML
How to resolve the error in POM.xml.
By: Eclipse User on Thu, 04 October 2018
1 2847 Thu, 04 October 2018 13:37
  Trying to get "Link with editor" boolean value
By: Eclipse User on Fri, 07 September 2018
0 2499 Fri, 07 September 2018 09:26
Current Time: Tue Feb 18 23:17:50 GMT 2025
Powered by FUDForum. Page generated in 0.03756 seconds
