    Replies Views Last message
  How to modify and save a BPMN model?
modify and save a BPMN model properly
By: Mahdi Saeedi Nikoo on Fri, 10 November 2023
2 1224 Thu, 16 November 2023 09:15
By: mahdi saeedi
  Question
By: Alex Entony on Sat, 04 March 2023
1 1494 Wed, 11 October 2023 18:33
By: Jack Jones
  Installation not possible - Modeler no longer supported?
Cannot install Modeler Plugin into lastest Eclipse version
By: R T on Thu, 06 July 2023
0 5104 Thu, 06 July 2023 15:04
By: R T
  How to extend modeler with custom features
By: mahdi saeedi on Fri, 07 April 2023
2 907 Sun, 09 April 2023 13:30
By: mahdi saeedi
  Visualize BPMN diagram using BPMN2 in a new java application
By: Alex Tomasi on Wed, 18 December 2013
4 3653 Mon, 13 February 2023 22:20
By: Ralph Soika
  How to mention software tool (MS Excel, SAP etc.) in an activity during process mapping
By: Md Ekramul Mostaquim on Thu, 09 February 2023
1 966 Mon, 13 February 2023 22:18
By: Ralph Soika
  Difference between new model and new generic diagram
By: Ra Coon on Sat, 15 October 2022
1 2045 Wed, 19 October 2022 19:45
By: Ralph Soika
  Subprocess issue on opening
Subprocesses when opening file are not in the status stored in the last save
By: Emanuele Bertoni on Fri, 30 September 2022
0 1642 Fri, 30 September 2022 08:13
  Does BPMN Editor generate invalid UniqueId? (id attribute in XML file)
id attribute in XML file is no valid NCName. JBPM refuses to accept.
By: Karl Degen on Fri, 23 September 2022
2 2664 Mon, 26 September 2022 07:33
By: Karl Degen
  BPMN model
By: Ra Coon on Tue, 14 June 2022
4 3563 Wed, 15 June 2022 08:51
By: Ra Coon
  BPMN live model execution
By: Franck Barbier on Wed, 08 June 2022
0 3145 Wed, 08 June 2022 15:46
By: Franck Barbier
  Blurry context buttons on subsequent use
By: Maciej Swiderski on Sun, 05 June 2022
2 2980 Tue, 07 June 2022 08:46
  using Bpmn2DiagramEditorInput to change the bp diagram programmatically
By: Zenith Arnejo on Fri, 13 May 2022
2 4031 Thu, 26 May 2022 16:37
By: Zenith Arnejo
  Instantiating and Populating BP diagrams programmatically
By: Zenith Arnejo on Thu, 05 May 2022
6 3133 Wed, 11 May 2022 13:10
By: Zenith Arnejo
  Moving JBPM componentes into separate Extension project
We plan to move the JBPM components of Eclipse-BPMN2 into a separate extension project.
By: Ralph Soika on Sat, 18 December 2021
0 3390 Sat, 18 December 2021 06:03
By: Ralph Soika
  Exporting BPMN diagram to SVG
Exporting BPMN diagrams in SVG returns an error (BPMN2 modeller 1.5.3 on Eclipse 2021-09)
By: Corrado Topi on Mon, 06 December 2021
3 2667 Sat, 18 December 2021 05:57
By: Ralph Soika
  ServiceTask should have only one incoming connection.
By: Chain Head on Mon, 08 November 2021
2 1336 Tue, 09 November 2021 00:10
By: Chain Head
  Migrating Eclipse BPMN2 Modeler to web
By: James Solomon on Wed, 18 August 2021
2 2531 Tue, 24 August 2021 12:23
By: James Solomon
  How to pick an Icon in a CustomTask
Questions about how to specify custom Elements as an Extension of the BPMN2 Modeler
By: Sebastian Rochert on Mon, 03 May 2021
3 1731 Tue, 10 August 2021 21:42
By: Ralph Soika
  Code snippet for export diagram feature
Is that possible to write a java api to export a image from bpmn2 model
By: Bapi Das on Fri, 12 December 2014
2 5428 Tue, 10 August 2021 21:38
By: Ralph Soika
  BPMN 2.0 Modeler Plugin
Failure to run plugin
By: Hamzah Shafardan on Fri, 21 May 2021
1 2046 Tue, 25 May 2021 10:35
By: Ralph Soika
  Survey as part of my bachelor thesis
topic: Diffusion rate of open source business software
By: Rezan Kedik on Mon, 03 May 2021
2 1065 Tue, 04 May 2021 06:43
By: Rezan Kedik
  Create a new BPM Project
By: Natalia Zanetti on Wed, 18 November 2020
1 1409 Wed, 18 November 2020 17:21
By: Ralph Soika
  Problem install BPMN2 Modeler Core
I have problem install BPMN2 Modeler Core 1.5.1.Final-v20190425-2005-B1 into Red Hat CodeReady Studio
By: Eduard Nickelmann on Wed, 22 July 2020
2 3679 Thu, 23 July 2020 06:55
  Anyone ever couple (Import/Export) a BPMN(2.0) diagram to UML(Papyrus)
UML, Papyrus, BPMN 2.0 Modeler and interop (Import/Export) per spec 8.3.4
By: Sam Warner on Tue, 14 July 2020
2 1537 Wed, 15 July 2020 20:51
By: Sam Warner
  HowTo question
Collaboration, Choreography, Conversations, Process, and inter-op within BPMN Modeler2
By: Sam Warner on Sun, 12 July 2020
3 1416 Wed, 15 July 2020 16:10
By: Ralph Soika
  triage usage before file a bug
Bug Choreography ChoreographyTask Add Participant
1 1582 Wed, 15 July 2020 16:00
By: Ralph Soika
  Import dataobjects?
Is ist possible to import data objects
By: Simon Hettwer on Mon, 22 June 2020
2 1354 Tue, 23 June 2020 06:44
By: Simon Hettwer
  BPMN 2.0 Modeler for Eclipse 2020-03
By: Markus Buchner on Wed, 25 March 2020
1 1809 Wed, 25 March 2020 13:36
By: Ralph Soika
  How do i retrieve the xml code ?
By: Giorgio Mazzotta on Wed, 18 March 2020
1 1449 Wed, 18 March 2020 13:26
By: Ralph Soika
  help with a deadlock
By: Maxime Vroege on Mon, 16 March 2020
1 1594 Wed, 18 March 2020 12:10
By: Ralph Soika
  BPMN2 Create new tab for the Task class
By: Giorgio Mazzotta on Fri, 06 March 2020
3 1588 Wed, 11 March 2020 18:01
  BPMN2 Modeler extensions
Interesting blog about BPMN2 Modeler extensions
By: Paul Leacu on Wed, 13 March 2019
2 3280 Tue, 15 October 2019 15:10
By: satya gagrani
  Question parameters from .wid file tab "I/O Parameters"
why are the parameters and results from the wid-file not in the tab "I/O-Paramters"?
By: Nicole Zellmeier on Wed, 03 July 2019
3 3742 Wed, 28 August 2019 08:41
  BPMN2 Property Page Redraw Loop
By: Michael Wellman on Wed, 06 March 2019
1 2433 Wed, 13 March 2019 20:31
By: Ralph Soika
  Can I extend twice the same object using modelExtension ?
By: Xabier Garat on Thu, 01 November 2018
1 2740 Mon, 05 November 2018 19:29
By: Xabier Garat
  Can anyone tell me how to debug the Eclipse BPMN2 Modeler source code
By: Yang Zheng on Thu, 16 August 2018
2 4292 Wed, 26 September 2018 12:56
By: Yang Zheng
  How to extract the part of source code of Eclipse BPMN2 Modeler that automatically generates DI info
By: Yang Zheng on Mon, 13 August 2018
0 3601 Mon, 13 August 2018 19:18
By: Yang Zheng
  Why can't I display processes in my BPMN file with collaboration ?
I create an xml bpmn file with collaboration info and no BPMN Diagram info. The modeler only generate empty pools for me
By: Yang Zheng on Thu, 09 August 2018
3 3965 Fri, 10 August 2018 21:21
By: Yang Zheng
  Poll: Who will attend EclipseCon Europe 2018?
By: Ralph Soika on Wed, 01 August 2018
0 6854 Wed, 01 August 2018 11:59
By: Ralph Soika
  java.lang.ClassCastException: org.eclipse.bpmn2.impl.ExpressionImpl incompatible with org.eclipse.bp
save and close the diagram, and reopen it, and double click user task
By: steven hu on Tue, 24 July 2018
0 3450 Tue, 24 July 2018 14:08
By: steven hu
  Loss of my shape decoration
By: Xabier Garat on Wed, 25 April 2018
7 4723 Sun, 22 July 2018 16:06
By: Xabier Garat
  Key 'namespace' ignored when generating genmodel
By: Xabier Garat on Sat, 21 July 2018
0 2951 Sat, 21 July 2018 12:22
By: Xabier Garat
  Creating process documentation
By: David Jingleheimer on Sun, 01 July 2018
0 2909 Sun, 01 July 2018 13:13
  Does the customtasks example work ?
By: Romain Bernard on Thu, 28 June 2018
3 2539 Fri, 29 June 2018 08:47
By: Romain Bernard
  Other problems when saving BPMN models
The Process ID is Invalid: Sub20%process20%AB
By: Jack Veenendaal on Fri, 15 June 2018
2 2636 Wed, 20 June 2018 08:02
By: Jack Veenendaal
  Problem when saving a model
By: Gonzalo López on Sat, 26 May 2018
2 2861 Tue, 29 May 2018 22:04
By: Gonzalo López
  problem with displaying large diagram
By: Pavel A. Puchkov on Wed, 22 November 2017
8 10604 Sun, 27 May 2018 08:36
By: Neil Mackenzie
  Trigger the update of an other instance of my extension
By: Xabier Garat on Thu, 03 May 2018
2 4255 Thu, 10 May 2018 14:23
By: Xabier Garat
  BPMN Plugin extraction
By: im hello world on Wed, 25 April 2018
1 2159 Thu, 26 April 2018 07:44
By: Ralph Soika
  Feature null
By: Xabier Garat on Thu, 01 March 2018
6 3307 Thu, 05 April 2018 21:19
By: Xabier Garat
  Icon in the customTask shape
By: Xabier Garat on Fri, 30 March 2018
12 5469 Thu, 05 April 2018 09:59
By: Xabier Garat
  Receive Task validation error vs. BPMN specification
By: Yelena Kasyanova on Thu, 01 March 2018
1 3383 Tue, 06 March 2018 09:46
By: Ralph Soika
  Example: Implementing an Extension
We would like to implement an extension to bpmn2-modeler
By: Julian Wadephul on Mon, 26 February 2018
1 2620 Wed, 28 February 2018 08:59
By: Ralph Soika
  I can't get the defined properties
By: Xabier Garat on Sun, 03 December 2017
6 6814 Thu, 08 February 2018 12:55
By: Xabier Garat
  Extende Palette Tool
I would like to configure Palette to easily add callActivity and userTask with predefined input and output
By: Paolo Cappuccini on Thu, 18 January 2018
0 4565 Thu, 18 January 2018 13:06
  Generated custom workeditors are using invalid imports
By: Henrik Larsson on Fri, 15 December 2017
0 5410 Fri, 15 December 2017 14:39
By: Henrik Larsson
  Build Error
Lots of building errors
By: Mateus Costa on Fri, 01 December 2017
1 4257 Mon, 11 December 2017 12:15
By: Mateus Costa
  Creating more than one extension
By: Xabier Garat on Wed, 22 November 2017
0 5055 Wed, 22 November 2017 14:58
By: Xabier Garat
  Create Elements Programmatically
By: Umut Kazan on Mon, 30 October 2017
5 6192 Tue, 21 November 2017 08:46
By: Umut Kazan
  I want to add an customxml editor.
By: inho kim on Mon, 20 November 2017
0 5071 Mon, 20 November 2017 01:38
By: inho kim
  Problem in ExtendingRuntime tutorial
By: Xabier Garat on Thu, 16 November 2017
1 2205 Sat, 18 November 2017 11:33
By: Xabier Garat
  How to cofigurate ServiceTask?
Configuration of 'serviceTask'
By: hocine hd on Wed, 13 September 2017
2 13422 Mon, 30 October 2017 15:05
By: Victor Chirita
  Diagrams in BPMN2 distorted
By: Atika Sharma on Fri, 27 October 2017
0 3707 Fri, 27 October 2017 18:47
By: Atika Sharma
  Pattern implementation
By: Raoudha Saida on Fri, 13 October 2017
2 2650 Fri, 13 October 2017 11:45
By: Raoudha Saida
  Extend Annotation
Extend Annotations Element
By: Mauro P. on Thu, 14 March 2013
7 10752 Fri, 13 October 2017 11:29
By: Ralph Soika
  Loss of type information?
By: Bert Brecht on Thu, 05 October 2017
0 6633 Thu, 05 October 2017 11:29
By: Bert Brecht
  Pop-up sub-process
Pop-up sub-process doesn't work
By: Robert Iordache on Fri, 25 August 2017
1 6765 Sat, 26 August 2017 09:23
By: Ralph Soika
  Extending SubChoreography [context button pad]
By: Alexandre Page on Wed, 26 July 2017
1 9541 Mon, 31 July 2017 19:41
By: Alexandre Page
icon3.gif New Tutorial - How To Start Contributing
By: Ralph Soika on Sat, 13 May 2017
0 51295 Sat, 13 May 2017 13:14
By: Ralph Soika
  jBPM with BPMN 2.0 modeler
Process execution of BPMN 2.0 process in eclipse with jBPMN
By: Frederick Dodzi Agbleke on Mon, 17 April 2017
1 26796 Wed, 26 April 2017 21:52
By: Ralph Soika
  Example Models
Looking for example models
By: Zeviel PErsellin on Tue, 11 April 2017
2 5671 Wed, 26 April 2017 21:47
By: Ralph Soika
  CDATA in Sequence Flow Condition
By: Imanuel R on Wed, 22 March 2017
3 7417 Thu, 23 March 2017 12:55
By: Ralph Soika
  BPMN Element Labels
By: Umut Kazan on Thu, 16 February 2017
2 25008 Mon, 13 March 2017 05:47
By: Umut Kazan
  Transfert message between activities in two pool
By: yakin ali on Sat, 11 March 2017
0 8806 Sat, 11 March 2017 14:31
By: yakin ali
  BPMN1.2 to BPMN2.0
By: yakin ali on Wed, 01 March 2017
1 2928 Wed, 01 March 2017 13:41
By: Robert Brodt
  BPMN to BPMT
By: yakin ali on Sat, 25 February 2017
0 11237 Sat, 25 February 2017 22:33
By: yakin ali
  haw add pool in BMPT
By: yakin ali on Thu, 23 February 2017
6 4067 Fri, 24 February 2017 22:21
By: yakin ali
  Error, please check if there is a FeatureModel/exemple_FM.xml
Error
By: yakin ali on Wed, 22 February 2017
2 2685 Wed, 22 February 2017 16:07
By: yakin ali
  Internal Error: propertyTab
By: im hello world on Mon, 20 February 2017
0 12008 Mon, 20 February 2017 08:26
By: im hello world
  NullPointerException : public class MytaskPropertySection extends DefaultPropertySection
By: im hello world on Fri, 17 February 2017
0 15433 Fri, 17 February 2017 23:13
By: im hello world
  How to open/convert/import/transform old STP BPMN models to BPMN 2.0 Modeler?
By: Jens Bürger on Thu, 09 February 2017
2 4644 Thu, 16 February 2017 08:58
By: Jens Bürger
  new properties to existing BPMN elements
By: im hello world on Sun, 12 February 2017
2 5302 Tue, 14 February 2017 09:35
By: im hello world
  PropertyExtension
entending ResourceRole
By: im hello world on Wed, 08 February 2017
5 4444 Mon, 13 February 2017 13:02
By: im hello world
  Namespace prefix in definitions
By: Bert Brecht on Tue, 07 February 2017
2 4183 Sun, 12 February 2017 21:17
By: Bert Brecht
  Extending ResourceRole
0 28337 Sun, 12 February 2017 08:46
By: im hello world
  CustomTaskFeautureContainer is missing
By: im hello world on Sun, 05 February 2017
1 2072 Tue, 07 February 2017 17:23
By: Robert Brodt
  Adding attributes, specifying their type at runtime
By: Francesco Scialpi on Wed, 03 September 2014
2 3539 Mon, 06 February 2017 17:43
By: im hello world
  how to execute a business process
By: fadouch nawara on Mon, 06 February 2017
3 3530 Tue, 07 February 2017 15:18
By: Robert Brodt
  how to set Custom Task default value
By: jo sungdae on Thu, 22 December 2016
1 12645 Fri, 13 January 2017 08:15
By: Kai Rosswag
  Multiple Instances Embedded SubProcess Input Instance Parameter Problem
By: Robert Georges on Thu, 24 November 2016
0 6503 Thu, 24 November 2016 12:28
By: Robert Georges
  In memory 2 sequence flow created while loading the resource file.
Reloading the bpmn file with custom task is showing duplicate sequence flow.
By: Rakesh Kumar Shah on Fri, 11 November 2016
0 42090 Fri, 11 November 2016 05:31
  Several identical elements in <extensionElements> tag
By: Oleg Shcherbakov on Mon, 26 September 2016
1 7345 Mon, 07 November 2016 14:10
  Latest Stable Channel
By: Kai Rosswag on Fri, 21 October 2016
1 2491 Fri, 21 October 2016 15:07
By: Robert Brodt
  Save the progress of a Model
By: Guillermo Fuentes on Wed, 12 October 2016
6 4383 Thu, 20 October 2016 18:59
  Problem I/O Parameter.
By: jo sungdae on Wed, 12 October 2016
3 3563 Thu, 13 October 2016 00:23
By: jo sungdae
icon5.gif how add a pattern of workflow by means of code?
By: Guillermo Fuentes on Thu, 01 September 2016
3 33018 Mon, 10 October 2016 15:25
  Change font of selected elements
By: Yannik Pietschmann on Fri, 23 September 2016
1 3087 Fri, 23 September 2016 14:54
By: Robert Brodt
  Change default drag/drop of task to abstract from script
How do I Change default drag/drop of task to abstract from script
By: Sean McPoland on Tue, 30 August 2016
5 3642 Tue, 13 September 2016 14:05
By: Robert Brodt
  Can't create new BPMN2 model - project does not exist? Select parent folder?
By: Edward Henigin on Wed, 02 January 2013
3 6975 Wed, 31 August 2016 19:07
By: Robert Brodt
  Add pattern with Subprocess
I need to add a pattern in the tool palette...
By: Guillermo Fuentes on Mon, 29 August 2016
3 2894 Tue, 30 August 2016 15:54
By: Robert Brodt
  Need Help understand Call Activity.
By: Kai Rosswag on Tue, 26 July 2016
2 3906 Fri, 19 August 2016 10:02
By: Kai Rosswag
  output BPMN standard
version of generated BPMN format
By: Mana Taghdiri on Mon, 15 August 2016
1 4488 Wed, 17 August 2016 18:15
By: Robert Brodt
  No Default Tabs from BPMN2.0 Modeller
I am trying to fix the order of the Tab when it is repaced by Custom Task.
By: Rakesh Kumar Shah on Mon, 08 August 2016
5 3848 Tue, 16 August 2016 12:51
icon4.gif It miss cases/icons into End event list : Cancel End event and multiple End event
You don't respect BPM notation v2.0 : it miss 2 cases.
By: Olivier FALCK on Thu, 28 July 2016
1 4657 Tue, 09 August 2016 20:49
By: Robert Brodt
  Import of BPMN Models on server
By: Peter Steinmetz on Thu, 14 July 2016
1 4431 Tue, 09 August 2016 20:46
By: Robert Brodt
  Using BPMN2 Model in maven
By: Bert Brecht on Wed, 06 July 2016
1 4168 Fri, 08 July 2016 15:33
By: Robert Brodt
  Dynamically update the layout of a customTaskElement
By: Ralph Soika on Tue, 31 May 2016
10 9856 Thu, 23 June 2016 17:30
By: Robert Brodt
  How to place a second icon into a CustomShapeFeatureContainer
By: Ralph Soika on Sat, 04 June 2016
4 7237 Mon, 20 June 2016 14:14
By: Ralph Soika
  How to use a custom icons?
2 6236 Sun, 19 June 2016 07:55
By: Ralph Soika
  How to open bpmn files properly
By: Delacyr Ferreira on Tue, 14 June 2016
2 4421 Wed, 15 June 2016 21:40
  Help save the BPMN2 Modeler Project from extinction!
By: Robert Brodt on Thu, 03 March 2016
8 11515 Tue, 14 June 2016 14:08
By: Robert Brodt
  Overriding Validation Through Constraint
Way to figure out to override the BPMN Model Validation.
By: Rakesh Kumar Shah on Mon, 30 May 2016
1 4285 Tue, 31 May 2016 11:08
  Neon M2 build is not available
By: Robert Brodt on Thu, 26 May 2016
0 3975 Thu, 26 May 2016 15:53
By: Robert Brodt
  Validation Error Decorations do not show
By: Kai Rosswag on Wed, 25 May 2016
3 5045 Sat, 28 May 2016 12:43
By: Robert Brodt
  change color with code
By: Simone Maria Clementi on Tue, 24 May 2016
6 6008 Sat, 04 June 2016 16:21
icon1.gif How refresh diagram?
I need to refresh the diagram to update a task
By: Guillermo Fuentes on Tue, 17 May 2016
2 2946 Tue, 17 May 2016 23:44
  Cannot collapse subtask
By: Marcus Mängel on Sat, 14 May 2016
3 4030 Thu, 26 May 2016 13:51
By: Robert Brodt
  Format : any for uploaded bpmn file in workbench
I am unable to open Uploaded bpmn file in kie workbench. Found that in metadata format:any
By: Pradeep Kamath on Thu, 05 May 2016
2 3369 Thu, 26 May 2016 05:41
By: Robert Brodt
  EventBasedGateway with catch events always shows validation errors
EventBasedGateway always shows validation error (Gateway sequence should have condition) when used with catch events
By: Bert Robben on Fri, 22 April 2016
1 3946 Sun, 24 April 2016 17:45
By: Robert Brodt
  How do I create a custom editor with the BPMN2 Modeler?
By: Jonas Le on Wed, 20 April 2016
2 4391 Thu, 21 April 2016 10:06
By: Jonas Le
  Change Process ID, BPMN2 elements ID
By: Andras Weintrauth on Thu, 14 April 2016
7 8526 Wed, 04 May 2016 05:19
By: Robert Brodt
  Extending a Participant
By: Mechim Aicha on Thu, 14 April 2016
1 3446 Thu, 14 April 2016 15:50
By: Robert Brodt
  Pallete Customization
Removing existing Palette
By: Rakesh Kumar Shah on Tue, 12 April 2016
2 5759 Wed, 13 April 2016 03:29
  add a constraint to a custom task
By: Mechim Aicha on Fri, 08 April 2016
1 4463 Mon, 11 April 2016 13:27
By: Robert Brodt
  Looking for translations
By: Kai Rosswag on Fri, 08 April 2016
1 3377 Sat, 09 April 2016 12:29
By: Robert Brodt
  Generate an image of bpmn file
By: jamila oukha on Wed, 06 April 2016
3 3804 Wed, 06 April 2016 19:59
By: Robert Brodt
  Replacing Tab doesn't work
By: Girish Kumar on Mon, 21 March 2016
1 3289 Mon, 21 March 2016 11:28
By: Girish Kumar
  Customtask features no longer recognized
By: Martin Jonsson on Sun, 20 March 2016
2 3725 Mon, 21 March 2016 17:04
By: Martin Jonsson
  BPMN2 Modeler 1.2.4.CR1 - looks good to me!
By: Ralph Soika on Fri, 18 March 2016
1 2541 Fri, 18 March 2016 19:02
By: Robert Brodt
  ClassCastException for console view from BPMEditor
By: Bhuvan Mehta on Fri, 18 March 2016
1 3969 Fri, 18 March 2016 14:07
By: Robert Brodt
  New builds available for Mars and Luna
By: Robert Brodt on Thu, 17 March 2016
0 5242 Thu, 17 March 2016 19:57
By: Robert Brodt
  bindAttribute did not work in case of copy&pase
By: Ralph Soika on Sat, 12 March 2016
2 4259 Tue, 15 March 2016 07:40
By: Ralph Soika
  v1.3.0: Strange Behavior of 'Edit Script Task'
v1.3.0 / Edit Script Task
By: Csaba Veg on Thu, 10 March 2016
2 2392 Thu, 10 March 2016 17:36
By: Csaba Veg
  Text box height of the Script field of Script Tasks
Script Task/Properties View/Script field
4 3616 Sat, 12 March 2016 08:33
By: Csaba Veg
  open wizard bpmn2
By: jamila oukha on Wed, 09 March 2016
0 4714 Wed, 09 March 2016 17:28
By: jamila oukha
  NPE While creating SequenceFlow between events after Mars.2 update
By: Bhuvan Mehta on Wed, 09 March 2016
15 7914 Tue, 15 March 2016 11:14
By: Bhuvan Mehta
  Creating new features in my elements for some actions
By: Delacyr Ferreira on Wed, 09 March 2016
6 7952 Tue, 05 April 2016 19:33
By: Robert Brodt
  Exception while opening bpmn Editor After Mars.2 Update
BPMN Editor Opening Issue
By: Bhuvan Mehta on Tue, 08 March 2016
18 14563 Thu, 21 April 2016 09:45
By: Bhuvan Mehta
  Custom Task
By: Salvatore Urso on Wed, 02 March 2016
3 5062 Tue, 08 March 2016 17:22
By: Robert Brodt
  add a new workflow pattern bpmn 2.0
By: jamila oukha on Fri, 26 February 2016
0 7475 Fri, 26 February 2016 12:50
By: jamila oukha
  Add a new workflow pattern
12 15025 Tue, 26 April 2016 21:06
By: Robert Brodt
  NoClassDefFoundError DefaultBpmn2RuntimeExtension$RootElementParser - after update to 1.2.3
By: Ralph Soika on Wed, 10 February 2016
2 3954 Wed, 10 February 2016 22:01
By: Ralph Soika
  Schema Read Problem After Update
After updating plugin I get schema_reference.4: Failed to read schema document
By: Willem Duminy on Fri, 08 January 2016
1 6827 Fri, 15 January 2016 22:15
By: Ralph Soika
  Import existing Pool from other file to Collaboration diagram
By: Jonas Anseeuw on Thu, 07 January 2016
1 7409 Thu, 18 February 2016 20:23
By: Robert Brodt
  Is anyone using WSIL support?
By: Robert Brodt on Fri, 13 November 2015
0 4813 Fri, 13 November 2015 16:49
By: Robert Brodt
  Sources - Which Tag for current development in 1.2.1
By: Ralph Soika on Thu, 12 November 2015
9 4124 Mon, 30 November 2015 18:01
By: Robert Brodt
  Some things we're working on for Neon
By: Robert Brodt on Thu, 12 November 2015
0 4615 Thu, 12 November 2015 16:47
By: Robert Brodt
  Using @Autowired in User Task > On Exit Script to call Spring Service
JBPM 6.2 :: Calling Spring Service from Eclipse BPMN2 Modeller Screen for User Task > Exit Script
By: Devendra Chaudhari on Sun, 18 October 2015
1 4052 Tue, 20 October 2015 11:58
By: Robert Brodt
  Bpmn2 diagram editor - Properties, constraint field is not showing up
By: nirmalya sinha on Fri, 25 September 2015
1 3600 Sat, 26 September 2015 11:02
By: nirmalya sinha
  BIRT Publishing
BIRT Publishing
By: Jeongpil An on Tue, 08 September 2015
1 2167 Tue, 08 September 2015 15:22
By: Robert Brodt
  Cannot add Called Element containing a hyphen
Getting error message 'The Activity ID is not valid.'
By: Enda Campbell on Fri, 28 August 2015
2 3565 Mon, 31 August 2015 22:15
By: Enda Campbell
  Warnings and error badges not being displayed
Warnings and errors for a diagram I'm creating aren't being displayed.
By: Matt Turnbull on Tue, 25 August 2015
7 4507 Thu, 27 August 2015 15:12
By: Robert Brodt
  Extending Resoure element
By: imen bensaid on Thu, 13 August 2015
0 4534 Thu, 13 August 2015 19:13
By: imen bensaid
  Eclipse BPMN2 Modeler and Activiti Designer metamodels question
About the tools mentioned compatibility at the metamodel level
By: Anton Ivanov on Wed, 29 July 2015
1 7267 Tue, 20 October 2015 12:03
By: Robert Brodt
icon3.gif Eclipse Mars on Debian Jessie with Gnome 3
By: Ralph Soika on Sat, 04 July 2015
1 3837 Tue, 07 July 2015 20:05
By: Robert Brodt
  Mars, Luna and the Graphiti dependencies....
By: Ralph Soika on Fri, 26 June 2015
2 4013 Sat, 04 July 2015 09:58
By: Ralph Soika
  The referenced BPMN element does not exist.
By: Jie Lin on Thu, 18 June 2015
3 3334 Wed, 10 February 2016 17:43
By: Robert Brodt
  Developer Tutorial: Validation
By: Robert Brodt on Tue, 16 June 2015
0 3723 Tue, 16 June 2015 23:22
By: Robert Brodt
icon5.gif Ctrl + A (select all ) + [delete] operations caused Exception.
By: Takahiro Yamanaka on Tue, 16 June 2015
2 2637 Sun, 21 June 2015 22:15
  Using BPMN2 modeler API
Using API in java project
By: Bruno Oliveira on Mon, 15 June 2015
1 3328 Mon, 15 June 2015 16:36
By: Robert Brodt
icon5.gif We want to create a custom validation logic
By: Takahiro Yamanaka on Sun, 14 June 2015
4 3593 Sun, 21 June 2015 22:25
icon5.gif generate org.eclipse.bpmn2 source code from BPMN20.genmodel
By: Aaron Li on Mon, 01 June 2015
2 4619 Fri, 19 June 2015 03:41
By: Aaron Li
  Re: Exception while opening diagram
By: fki ahmed on Wed, 27 May 2015
1 3702 Wed, 10 June 2015 17:28
By: Robert Brodt
icon9.gif Custom SequenceFlow's extended properties doesn't work for bpmn2.
By: Takahiro Yamanaka on Sat, 23 May 2015
3 3870 Mon, 15 June 2015 16:31
By: Robert Brodt
  Difference between BPEL and BPMN
By: Hailah M. on Tue, 19 May 2015
1 4556 Fri, 29 May 2015 06:21
By: Ralph Soika
  Copy/pasting pools between diagrams are supposed to work?
By: Ismael Olea on Thu, 07 May 2015
2 3650 Fri, 08 May 2015 08:52
By: Ismael Olea
  Vertical align doesn't work between lanes?
2 3265 Fri, 08 May 2015 08:46
By: Ismael Olea
  Breaking Eclipse with a model made with Modeler
The model I've created seems to have some inconsistence it breaks Eclipse
By: Ismael Olea on Wed, 06 May 2015
3 3380 Fri, 08 May 2015 08:55
By: Ismael Olea
  Problem adding attributes to Conversation
Attributes not visible in properties window
By: Jonas Anseeuw on Thu, 30 April 2015
0 4198 Thu, 30 April 2015 07:40
By: Jonas Anseeuw
  Export diagram as html file
I wanna know if it's possible to export a diagram to html file (like a web file that can be "surfed / navigable"), as we can do with the Bizagi publishing as web.
By: Mariana Silva on Mon, 27 April 2015
1 5347 Wed, 29 April 2015 09:04
By: Ralph Soika
  Developer Tutorial : ToolPalettes
By: Ralph Soika on Wed, 22 April 2015
1 3936 Wed, 29 April 2015 15:58
By: Robert Brodt
  Bpmn2ResourceImpl stores different output than the modeler
By: Flavio Donze on Wed, 22 April 2015
0 4038 Wed, 22 April 2015 12:42
By: Flavio Donze
  One or two runtimes?...
By: Adam Fowler on Thu, 16 April 2015
3 3291 Fri, 17 April 2015 13:51
By: Robert Brodt
  Adding default information for new process files
3 3342 Fri, 17 April 2015 13:54
By: Robert Brodt
  How to change the Label of a extended featureContainer
By: Ralph Soika on Wed, 15 April 2015
2 3298 Wed, 22 April 2015 20:06
By: Ralph Soika
icon3.gif Documentation about extending the BPMN 2.0 Modeler
Where to find documentation about extending the BPMN 2.0 Modeler?
By: Jonas Anseeuw on Tue, 14 April 2015
5 4395 Wed, 22 April 2015 17:26
By: Ralph Soika
  Routing problem with Lanes since version 1.1.2?
By: Ralph Soika on Mon, 13 April 2015
1 2982 Tue, 14 April 2015 01:29
By: Robert Brodt
icon5.gif How to validate incoming connections?
By: Ralph Soika on Sat, 11 April 2015
6 5642 Wed, 15 April 2015 17:30
By: Robert Brodt
  Creating a documentation of BPMN 2.0 model
BPMN 2.0 modeller, documenting model
By: Wojtek Kurek on Tue, 07 April 2015
3 3735 Thu, 09 April 2015 16:01
By: Robert Brodt
  Replacing property tab did overwrite all model objects?
By: Ralph Soika on Thu, 02 April 2015
3 3514 Fri, 03 April 2015 16:29
By: Ralph Soika
  TextObjectEditor - setMultiLine(true) not working as expected?
By: Ralph Soika on Tue, 24 March 2015
2 2846 Fri, 27 March 2015 16:37
By: Ralph Soika
  GMF/EFM BPMN2 Modeler project
We are find GMF/EFM BPMN2 Modeler project
By: Enyo Goncalves on Tue, 24 March 2015
3 3270 Mon, 30 March 2015 13:46
By: Robert Brodt
  User task with notification
By: prasad rao on Fri, 20 March 2015
1 3293 Mon, 23 March 2015 19:34
By: Robert Brodt
  default sequence flow gets lost when adding new condition
By: Stefan Henke on Wed, 18 March 2015
2 4460 Tue, 24 March 2015 09:15
By: Stefan Henke
  Create the updatesite
By: Marcelo F. Terenciani on Sat, 14 March 2015
7 5709 Wed, 25 March 2015 07:17
By: Robert Brodt
  Finally, some tutorials explaining how to use all of this cra... stuff
By: Robert Brodt on Wed, 11 March 2015
0 3890 Wed, 11 March 2015 22:06
By: Robert Brodt
  Updated Custom Task example
By: Robert Brodt on Tue, 10 March 2015
0 3867 Tue, 10 March 2015 16:22
By: Robert Brodt
  No, I haven't been hit by a bus...
...I've just been very busy lately
By: Robert Brodt on Sat, 07 March 2015
1 2544 Sat, 07 March 2015 23:08
By: Ralph Soika
icon5.gif How to append a text node to a EObject
By: Ralph Soika on Sat, 07 March 2015
8 6287 Mon, 30 March 2015 13:32
By: Robert Brodt
  Define a customized BPMN modeler palette
By: Frederik Gailly on Fri, 06 March 2015
0 3911 Fri, 06 March 2015 22:59
By: Frederik Gailly
  What is the difference between bindAttribute() and bindReference() ?
By: Ralph Soika on Fri, 06 March 2015
1 3246 Tue, 10 March 2015 14:02
By: Robert Brodt
  Process level ioSpecification
Will modeler support ioSpecification under process element?
By: John Dorien on Thu, 05 March 2015
1 4013 Tue, 10 March 2015 14:08
By: Robert Brodt
icon5.gif How to extend a EventDefinition ?
By: Ralph Soika on Wed, 04 March 2015
2 4159 Tue, 10 March 2015 00:51
By: Robert Brodt
icon9.gif Latest BPMN2 modeler not working for JBPM
By: Ander Ruiz on Tue, 03 March 2015
4 8031 Tue, 01 December 2015 06:21
By: Dinesh Gupta
icon5.gif opening extended bpmn file
about re-opening bpmn file created with Bpmn-Modeler extension plugin
By: mhammad makni on Sun, 01 March 2015
7 7060 Sat, 14 March 2015 16:29
By: mhammad makni
  How to extend a model entry at runime
By: Ralph Soika on Sun, 01 March 2015
1 2859 Sun, 01 March 2015 21:41
By: Ralph Soika
  How to implement a custom property section?
By: Ralph Soika on Fri, 27 February 2015
1 2980 Tue, 03 March 2015 20:40
By: Ralph Soika
icon5.gif Who can help me to extend the BPMN2 Plugin?
How to extend the BPMN Modler to work with Imixs-Workflow?
By: Ralph Soika on Sun, 22 February 2015
4 4754 Tue, 10 March 2015 12:26
By: Ralph Soika
  BPMN2 validator for custom file extensions
By: Stefan Henke on Fri, 20 February 2015
7 6391 Mon, 23 March 2015 20:08
By: Robert Brodt
Legend New Messages New Messages   No New messages No New messages   Locked (w/ unread messages) Locked (w/ unread messages)   Locked Locked   Moved to another forum Moved to another forum
Current Time: Tue May 21 16:00:38 GMT 2024
Powered by FUDForum. Page generated in 0.03993 seconds
