Home » Modeling » EMF » How to avoid the output of an element path instead of its ID?
- How to avoid the output of an element path instead of its ID? [message #1852029] Tue, 26 April 2022 11:25 Go to next message
Ralph Soika is currently offline Ralph SoikaFriend
I have constructed a EMF model form the BPMN 2.0 specification. No I run into a strange behavior when construction a model programmatically.
My root element 'definitions' contains two childs (bpmndi:BPMNDiagram and bpmn2:process). The bpmndi:BPMNDiagram contains a bpmndi:BPMNPlane holding a reference to the bpmn2:process. Each element has a unique id.
        Definitions definitions = Bpmn2Factory.eINSTANCE.createDefinitions();
        definitions.setExporter("demo");
        definitions.setExpressionLanguage("java");
        org.openbpmn.bpmn2.Process process = Bpmn2Factory.eINSTANCE.createProcess();
        process.setId("P001");
        process.setIsClosed(true);
        BPMNDiagram bpmdiagram = BpmndiFactory.eINSTANCE.createBPMNDiagram();
        bpmdiagram.setId("D002");
        bpmdiagram.setName("my diagram");
        BPMNPlane bpmnplane = BpmndiFactory.eINSTANCE.createBPMNPlane();
        bpmnplane.setId("BPMNPlane_1");
        bpmnplane.setBpmnElement(process);
        bpmdiagram.setPlane(bpmnplane);
        definitions.getProcesses().add(process);
        definitions.getDiagrams().add(bpmdiagram);
The outcome of the XML file looks like this:
<?xml version="1.0" encoding="ASCII"?>
<bpmn2:Definitions xmlns:bpmn2="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" expressionLanguage="java" exporter="demo">
  <bpmndi:BPMNDiagram id="D002" name="my diagram">
    <bpmndi:BPMNPlane id="BPMNPlane_1" bpmnElement="bpmn2:Process src/test/resources/openbpmn-empty.bpmn#P001"/>
  </bpmndi:BPMNDiagram>
  <bpmn2:process id="P001" isClosed="true"/>
</bpmn2:Definitions>
Where the bpmnElement in the bpmndi:BPMNPlane refers to the full path. But I would expect only the ID (which is unique in the complete model)
    <bpmndi:BPMNPlane id="BPMNPlane_1" bpmnElement="P001"/>
Can someone help me how to resolve this issue?
- Re: How to avoid the output of an element path instead of its ID? [message #1852036 is a reply to message #1852029] Tue, 26 April 2022 19:16 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
Unfortunately you do not show the ResouceSet maintenance or the save so you hide the usual sources of trouble from us.
A common failure to save properly is due to failure to save from within a ResourceSet. Another possibility is that you have assigned an unwise Resource URI.
Ed Willink
[Updated on: Tue, 26 April 2022 19:17]
Report message to a moderator
- Re: How to avoid the output of an element path instead of its ID? [message #1852060 is a reply to message #1852036] Thu, 28 April 2022 07:15 Go to previous message
Ensure that you load/create every resource, especially the initial one, with an absolute URI. If it's a resource in the workspace, ensure you use URI.createPlatformResourceURI("/project/path-to-file") and if it's a resource in the file system ensure you use URI.createFileURI(new File("path").getAbsolutePath()). In this case, if you later want to load the resource at runtime, you would probably want to use java.lang.Class.getResource(String) to get the URL...
Ed Merks
Previous Topic:how to load other project's ecore resource
Next Topic:[CDO] [ERROR] Buffer@6,443[RELEASED]
Current Time: Mon Jan 20 18:09:45 GMT 2025
Powered by FUDForum. Page generated in 0.04236 seconds
