Re: Failed while installing Axis2 Web Services Core 1.1 [message #205137 is a reply to message #205130] |
Fri, 30 November 2007 02:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Alessandro Tucci![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=intucci%40tin.it) Messages: 33 Registered: July 2009 |
Member |
Hi everybody,
just let me point out something about the error message. It consists of
two rows:
1)
Failed while installing Axis2 Web Services Core 1.1. The Axis2 facets
cannot be installed since the Axis2 runtime location has not been set.
Please go to the Web Services preference page and set the Axis2 runtime
location under Axis2 Preferences.
2)
/home/atx85/Programmi/Java/IDE/eclipse_mant/workspace/.metad ata/.plugins/org.apache.axis2.facet/exploadedwar/WEB-INF/lib /activation.jar
(No such file or directory)
The first message is not correct: the Axis2 runtime location is properly
set, in fact the message:
Axis2 runtime loaded successfully !!!
is shown in the Preferences -> Web Services -> Axis2 Preferences ->
"Axis2 runtime" tab.
Instead, it is true that the file mentioned in the 2nd message does not
exist. Let me define
ECLIPSE_HOME=/home/atx85/Programmi/Java/IDE/eclipse_mant
The only files I have are:
$ECLIPSE_HOME/workspace/.metadata/.plugins/org.apache.axis2. facet/status.properties,
which contains only this row:
status=fail
$ECLIPSE_HOME/workspace/.metadata/.plugins/org.apache.axis2. facet/war.properties,
status=false
No other files or subdirectories can be found in
$ECLIPSE_HOME/workspace/.metadata/.plugins/org.apache.axis2. facet.
I hope this information can help you to solve the problem.
Thanks again for your interest,
Alessandro Tucci
Alessandro Tucci ha scritto:
> OS: Linux SuSE 10.1 (user privileges)
> JVM: sun jdk 1.5.0_12
> ECLIPSE: 3.3.1, build id M20071023-1652
> WTP version: 200709281648 (the one who is included in the latest stable
> release of TPTP)
> Hi everybody,
> I'm experiencing the same problem described by Mr. Wishcrop. I searched
> for a bug related to this issue, but it seems that no defect was opened
> about it. Did anybody find a solution or a workaround?
> Thanks for your interest,
> Alessandro Tucci
> Seng Phung-Lu wrote:
>> Guido,
>> This appears to be a defect. Please open a bug report with the
>> information you've provided.
>> https://bugs.eclipse.org/bugs/
>> Thanks,
>> Seng
Re: Failed while installing Axis2 Web Services Core 1.1 [message #205273 is a reply to message #205137] |
Sat, 01 December 2007 00:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Kathy Chan![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=kathy%40ca.ibm.com) Messages: 93 Registered: July 2009 |
Member |
This seems to be a problem. Please open a bug report in:
Since we have been running similar scenarios successfully in weekly smoke
tests, there might be something special about the configuration you are
using that cause the problem. So please be specific in describing how to
reproduce the problem including drivers used and system configuration.
Thanks!
Kathy Chan
"Alessandro Tucci" <intucci@tin.it> wrote in message
news:fintb0$9hf$1@build.eclipse.org...
> Hi everybody,
> two rows:
> 1)
> 2)
> status=fail
> status=false
> Alessandro Tucci
>> release of TPTP)
>> Hi everybody,
>> Alessandro Tucci
>>> Guido,
>>> Thanks,
>>> Seng
Re: Failed while installing Axis2 Web Services Core 1.1 [ERROR OF MINE] [message #205369 is a reply to message #205273] |
Tue, 04 December 2007 12:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Member |
Hi Kathy,
there is no need to open a bug. I was working with an old version of
Axis (1.4) that I downloaded when I didn't know much about web services
yet. As I upgraded to the last version (Axis2_1.3), everything about
installing facets worked fine.
Now there are other problems about deployment I am trying to face... :)
Sorry for having disturbed you.
Alessandro Tucci
Kathy Chan wrote:
> Thanks!
> Kathy Chan
>> Hi everybody,
>> two rows:
>> 1)
>> 2)
>> status=fail
>> status=false
>> Alessandro Tucci
>>> release of TPTP)
>>> Hi everybody,
>>> Alessandro Tucci
>>>> Guido,
>>>> Thanks,
>>>> Seng
Re: Failed while installing Axis2 Web Services Core 1.1 [message #649524 is a reply to message #548099] |
Wed, 19 January 2011 15:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
joshua lee![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=lcli4321%40gmail.com) Messages: 1 Registered: January 2011 |
Junior Member |
I suffered the same problem.
I really think that's some junks left in the .plugin folder
here is my steps to skip the error
1. backup the .metadata/.plugin folder
2. remove all stuff in .plugin
3. restart eclipse (it will generate somethings in the .plugin folder)
4. stop eclipse
5. copy original .plugin back (with file replacing)
6. restart eclipse
7. follow the original steps to build web service
it works for me, but not the first time...
hope it works for you guys.
[Updated on: Wed, 19 January 2011 15:29] Report message to a moderator
Re: Failed while installing Axis2 Web Services Core 1.1 [message #820875 is a reply to message #757388] |
Wed, 14 March 2012 17:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Pradeep Bommisetty![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=neoprady%40gmail.com) Messages: 4 Registered: March 2012 |
Junior Member |
I have the same problem with the below setup:
Eclipse Indigo(eclipse-jee-indigo-SR1-win32)
Axis2-1.6.1-war
jdk1.6.0
Did anyone solve the problem above with a similar configuration? Is it a problem with Indigo?
Tried with Gallileo and I am not seeing an error "<AXIS_HOME>\webapp (The system cannot find the file specified) even though axis war has been selected in the Window-Preferences-Axis2 Preferences. Whole setup worked fine on a local machine but when tried on a virtual machine, it bombs
[Updated on: Wed, 14 March 2012 21:24] Report message to a moderator
Re: Failed while installing Axis2 Web Services Core 1.1 [message #821492 is a reply to message #820875] |
Thu, 15 March 2012 12:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Junior Member |
The workaround here(bugs dot eclipse dot org/bugs/show_bug.cgi?format=multiple;id=327800#) seems to have worked for the java.lang.nullPointerException but after that when I try to run the service on server, it says classNotFound for "AxisAdminServlet". I see that the classes and axis jars are not copied on to the web-inf/library in the deployed folder.
To resolve this issue, either include the jar files that have this class file or if you don't need the admin related servlet mappings in the web.xml, just comment them out.
Here is the list of jars containing the AxisAdminServlet :
.axis2-WADI-02.jar
.axis2-kernel-1.4.jar
.axis2-1.4.jar
so you will have to point to the older version if you want to have org.apache.axis2.transport.http.AxisAdminServlet
[Updated on: Thu, 15 March 2012 16:29] Report message to a moderator
FUDForum. Page generated in 0.07981 seconds
