Re: certificate problems running buckminster headless for an rcp app [message #531825 is a reply to message #531809] |
Thu, 06 May 2010 09:45 |
Could this be related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=309059 ?
- thomas
On 05/06/2010 11:28 AM, Andreas Pakulat wrote:
> Jesper Eskilson wrote on Thu, 06 May 2010 04:24
>> On 2010-05-05 22:49, Andreas Pakulat wrote:
>> > I've followed http://www.ralfebert.de/blog/eclipsercp/rcp_builds/ to
>> > create a hudson-driven build of my rcp app. Unfortunately I'm hitting a
>> > brick wall without being able to get more information. The step that
>> > should create the product from the p2-site fails with:
>> > !ENTRY org.eclipse.equinox.p2.engine 8 0 2010-05-05 22:38:28.737
>> > !MESSAGE One or more certificates rejected. Cannot proceed with
>> > installation.
>> > I've used my normal Eclipse installation as target platform and thought
>> > that would work best. But apparently I'm missing something
>> somewhere. It
>> > might already be enough if I could find out which plugins have
>> > certificate problems, but there's no further output..
>> I've seen this exact problem, but only on some machines. It works on
>> our build server, so I didn't investigate the problem further.
>> /Jesper
> I guess I could add that the build worked once last week with that
> target platform, unfortunately I've changed quite some things around
> afterwards and at this point I can't seem to re-construct what I changed.
Re: certificate problems running buckminster headless for an rcp app [message #532052 is a reply to message #531706] |
Thu, 06 May 2010 22:45 |
John Messages: 1 Registered: May 2010 |
Junior Member |
I too received this error today. I an using eclipse-java-galileo-SR2-win32 on Windows 7 and attempted to install the Saleforce.com IDE add-on. I received the following error:
!SESSION 2010-05-06 15:09:55.191 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_20
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.equinox.p2.engine 4 4 2010-05-06 15:25:03.375
!MESSAGE An error occurred during the org.eclipse.equinox.internal.provisional.p2.engine.phases.Ch eckTrust phase.
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2010-05-06 15:25:03.375
!MESSAGE session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.CheckTrust, operand=, action=).
!MESSAGE One or more certificates rejected. Cannot proceed with installation.
!ENTRY org.eclipse.equinox.p2.engine 4 4 2010-05-06 15:31:20.836
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2010-05-06 15:31:20.836
Re: certificate problems running buckminster headless for an rcp app [message #532082 is a reply to message #532052] |
Fri, 07 May 2010 06:09 |
Yes, this is condistent with https://bugs.eclipse.org/bugs/show_bug.cgi?id=309059
- thomas
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> phase.
> installation.
> phase.
> installation.
Re: certificate problems running buckminster headless for an rcp app [message #532212 is a reply to message #532082] |
Fri, 07 May 2010 14:27 |
Jesper Eskilson Messages: 134 Registered: July 2009 |
I worked around this by reverting back to using jdk1.6.0_16 until this
is resolved.
> - thomas
>> phase.
>> installation.
>> phase.
>> installation.
/Jesper
FUDForum. Page generated in 0.03846 seconds
