Re: [Debugger] Does "Drop To Frame" work on Mac OS X? [message #481275 is a reply to message #480898] |
Thu, 20 August 2009 10:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Markus Keller![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=markus.kell.r%40gmail.com) Messages: 294 Registered: July 2009 |
Works for me in I20090811-0800 with JDK 1.5.0.
Note that 'drop to frame' does not work for all frames (e.g. it's not
supported on the top frame of a stack and AFAIR, there are also
limitations for callbacks from native code).
To see what your VM supports, go to the Debug view, select the process,
choose Properties, go to the VM Capability page and check the 'Stepping'
section.
Markus
On 2009-08-18 21:21, Eric Rizzo wrote:
> I recently switched to using a Mac for all my Eclipse/Java development.
> Something I've noticed is that I can't get the Drop To Frame function to
> be enabled. I've read that the JVM has to support that part of the debug
> API, but I can't believe that neither the 1.5 or 1.6 Mac JVMs supports
> this - really?
> Does it work for anyone? Is there any documentation about which JVMs
> support it and which do not?
> TIA,
> Eric
FUDForum. Page generated in 0.03498 seconds
