Home » Archived » AM3 » Injection and EMF generated API
Injection and EMF generated API [message #655816] Tue, 22 February 2011 12:20 Go to next message
Hello
I'm facing a problem when I try to use a EMF resource after an injection.
I have writen an injector from XML to my metamodel. But when I try to access the resource the model objects are DynamicEObjectImpl even if the generated EMF code is available ! I get the following error:
!MESSAGE Unable to create view ID fr.irit.ifclipse.views.IFConfigurationView: org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to fr.irit.ifclipse.metamodel.IFConfig.IFConfig
I have posted in the EMF forum, but since I'm using the AM3 XMLInjector, may be you can help me.
my post on EMF forum: http://www.eclipse.org/forums/index.php?t=rview&goto=655 772#msg_655772
And this is the code of the injector:
package fr.irit.ifclipse.xml.injector;
import java.io.IOException;
import java.io.InputStream;
import java.io.PipedInputStream;
import java.io.PipedOutputStream;
import java.net.URL;
import java.util.Collections;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.emf.EMFExtractor;
import org.eclipse.m2m.atl.core.emf.EMFInjector;
import org.eclipse.m2m.atl.core.emf.EMFModel;
import org.eclipse.m2m.atl.core.emf.EMFModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFReferenceModel;
import org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel;
import org.eclipse.m2m.atl.drivers.emf4atl.AtlEMFModelHandler;
import org.eclipse.m2m.atl.engine.vm.AtlLauncher;
import org.eclipse.m2m.atl.engine.vm.AtlModelHandler;
import org.eclipse.m2m.atl.engine.vm.ModelLoader;
import org.eclipse.m2m.atl.projectors.xml.XMLInjector;
public class IFConfigurationXMLInjectorImpl implements
		IFConfigurationXMLInjector {
	private static final String IF_CONFIGURATION_ECORE_PATH = "fr.irit.ifclipse.metamodel/src/fr/irit/ifclipse/metamodel/metamodel/IFConfiguration.ecore";
	private static final String XML_ECORE_PATH = "org.eclipse.m2m.atl.projectors.xml/src/org/eclipse/m2m/atl/projectors/xml/resources/XML.ecore";
	private AtlEMFModelHandler modelHandler;
	private ModelLoader modelLoader;
	private ASMEMFModel XMLMetamodel;
	private ASMEMFModel IFConfigurationMetamodel;
	private URI XML_ecoreURI;
	private URI IFConfiguration_ecoreURI;
	private URL XML2IFConfiguration_PATH;
	 * inject an XML inputstream into an IFConfiguration resource
	public Resource inject(InputStream sourceXML) {
		// load the MetaM and M
		createResources();
		Resource result = null;
		EMFInjector emfInjector = new EMFInjector();
		try {
			// create an EMFModel instance of XML
			EMFReferenceModel XMLReferenceModel = (EMFReferenceModel) (new EMFModelFactory())
					.newReferenceModel();
			emfInjector.inject(XMLReferenceModel, XML_ecoreURI.toString());
			EMFModel sourceXMLEMFModel = (EMFModel) (new EMFModelFactory())
					.newModel(XMLReferenceModel);
			// inject the inputstream in the XML EMFModel
			XMLInjector xmlInjector = new XMLInjector();
			xmlInjector.inject(sourceXMLEMFModel, sourceXML, null);
			// transform the XML EMFModel to IFConfig EMFModel using
			// XML2IFConfig.asm
			result = xml2ifConfigTrafo(sourceXMLEMFModel);
		} catch (ATLCoreException e) {
			e.printStackTrace();
		return result;
	private void createResources() {
		modelHandler = (AtlEMFModelHandler) AtlModelHandler
				.getDefault(AtlModelHandler.AMH_EMF);
		modelLoader = modelHandler.createModelLoader();
		XML_ecoreURI = URI.createPlatformPluginURI(XML_ECORE_PATH, true);
		IFConfiguration_ecoreURI = URI.createPlatformPluginURI(
				IF_CONFIGURATION_ECORE_PATH, true);
		XML2IFConfiguration_PATH = IFConfigurationXMLInjectorImpl.class
				.getResource("resources/XML2IFConfig.asm");
	private Resource xml2ifConfigTrafo(final EMFModel sourceXMLEMFModel) {
		Map<String, Object> models = new HashMap<String, Object>();
		initMetamodels(models);
		// get/create models
		try {
			// TODO: transform the 2 EMFModels into ASMEMFModels
			final PipedOutputStream outputStream = new PipedOutputStream();
			PipedInputStream inputStream = new PipedInputStream(outputStream);
			new Thread(new Runnable() {
				public void run() {
					try {
						(new EMFExtractor()).extract(sourceXMLEMFModel,
								outputStream, null);
					try {
						outputStream.close();
					} catch (IOException e) {
			}).start();
			ASMEMFModel XMLInputModel = (ASMEMFModel) modelLoader.loadModel(
					"IN", XMLMetamodel, inputStream);
			inputStream.close();
			URI saveURI = URI
					.createFileURI("d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifclipse/xml/savedXML.xml.xmi");
			Resource XMLExtent = XMLInputModel.getExtent();
			XMLExtent.setURI(saveURI);
			XMLExtent.save(Collections.EMPTY_MAP);
			ASMEMFModel IFConfigOutputModel = (ASMEMFModel) modelLoader
					.newModel("OUT", "", IFConfigurationMetamodel);
			// load models
			models.put("IN", XMLInputModel);
			models.put("OUT", IFConfigOutputModel);
			// launch
			AtlLauncher.getDefault().launch(this.XML2IFConfiguration_PATH,
					Collections.EMPTY_MAP, models, Collections.EMPTY_MAP,
					Collections.EMPTY_LIST, Collections.EMPTY_MAP);
			result = IFConfigOutputModel.getExtent();
			URI saveURI_IF = URI
					.createFileURI("d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifclipse/xml/savedIFConfig.ifconfig.xmi");
			result.setURI(saveURI_IF);
			result.save(Collections.EMPTY_MAP);
		return result;
	// loads the metamodels in a Map<String, Object>
	private void initMetamodels(Map<String, Object> models) {
		try {
			XMLMetamodel = (ASMEMFModel) modelLoader.loadModel("XML",
					modelLoader.getMOF(), XML_ecoreURI.toString());
			IFConfigurationMetamodel = (ASMEMFModel) modelLoader.loadModel(
					"IFConfiguration", modelLoader.getMOF(),
					IFConfiguration_ecoreURI.toString());
			models.put("XML", XMLMetamodel);
			models.put("IFConfiguration", IFConfigurationMetamodel);
	public Resource inject(Resource IFConfigResource, InputStream sourceXML,
			Map<String, Object> options) {
		return null;
Re: Injection and EMF generated API [message #655898 is a reply to message #655816] Wed, 23 February 2011 04:00 Go to previous messageGo to next message
Le 22/02/2011 18:20, ElArbi a écrit :
> Hello
> " fr.irit.ifclipse.metamodel/src/fr/irit/ifclipse/metamodel/me tamodel/IFConfiguration.ecore ";
> " org.eclipse.m2m.atl.projectors.xml/src/org/eclipse/m2m/atl/p rojectors/xml/resources/XML.ecore ";
> @Override
> createResources();
> try {
> EMFModelFactory())
You must use the same EMF factory for all (meta)models implied in your
injection/transformation
> // XML2IFConfig.asm
> return result;
> try {
> public void run() {
> try {
> try {
> }).start();
> URI saveURI = URI
> .createFileURI(" d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifc lipse/xml/savedXML.xml.xmi ");
> // load models
> // launch
> AtlLauncher.getDefault().launch(this.XML2IFConfiguration_PAT H,
> .createFileURI(" d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifc lipse/xml/savedIFConfig.ifconfig.xmi ");
> return result;
> try {
> @Override
> return null;
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: Injection and EMF generated API [message #655905 is a reply to message #655816] Wed, 23 February 2011 04:20 Go to previous messageGo to next message
Hi El Arbi,
Are you using the latest version of the XML injector available from the AM3 folder of the MoDisco project's SVN https://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.mod isco/incubation/trunk/am3/plugins/trunk/org.eclipse.m2m.atl. projectors.xml/ ?
Hugo
Re: Injection and EMF generated API [message #655923 is a reply to message #655905] Wed, 23 February 2011 05:33 Go to previous messageGo to next message
Hugo Bruneliere wrote on Wed, 23 February 2011 04:20
Hi El Arbi,
Hugo
Yes, the only modificaiton in trunk is that the XML.ecore and KM3 had moved from org.eclipse.m2m.atl.projectors.xml.resources to model package. Should I update ?
Re: Injection and EMF generated API [message #655925 is a reply to message #655898] Wed, 23 February 2011 05:35 Go to previous messageGo to next message
I have done it but still have the same error Sad
Re: Injection and EMF generated API [message #656236 is a reply to message #655925] Thu, 24 February 2011 11:21 Go to previous message
I finally found the problem (and a solution):
I was loading the package from it's serialized form => it's factory will instantiate the dynamic EObject implementation.
So using my package namespace URI instead solved the problem. I replaced the following code:
URI IFConfiguration_ecoreURI = URI.createPlatformPluginURI(IF_CONFIGURATION_ECORE_PATH, true);
with this one
URI IFConfiguration_NS_URI = URI.createURI("uri:http://irit.fr/ifconfiguration");
					IFConfiguration_NS_URI.toString());
And it works !
Thanks.
Previous Topic:ATL metamodel validated
Next Topic:Can't launch UML2OWL on ATL 3.1
Current Time: Wed Oct 29 20:07:25 EDT 2025
Powered by FUDForum. Page generated in 0.04264 seconds
