Re: VE 1.4 and Eclipse 3.6 [message #544020 is a reply to message #542857] |
Thu, 01 July 2010 11:46 |
Hi, same problem here. Eclipse Helios for Java Dev.
Cannot complete the install because one or more required items could not be found.
Software being installed: Visual Editor 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk (org.eclipse.ve.feature.group 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk)
Missing requirement: Visual Editor Common Data Editor 1.4.0.v20090826-1446 (org.eclipse.ve.cde 1.4.0.v20090826-1446) requires 'bundle com.ibm.icu [3.4.4.1,4.1.0)' but it could not be found
Cannot satisfy dependency:
From: Visual Editor 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk (org.eclipse.ve.feature.group 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk)
To: org.eclipse.ve.cde [1.3.0,2.0.0)
My Plugins:
Mobile Tools
PDT
Pydev
Android Plugin for Eclipse.
A quick update by the plugin dev would be great.
Thanks!
Pascal
[Updated on: Thu, 01 July 2010 11:46] by Moderator Report message to a moderator
Re: VE 1.4 and Eclipse 3.6 [message #544903 is a reply to message #544673] |
Tue, 06 July 2010 00:43 |
kit Messages: 4 Registered: July 2010 |
I tried to do what you outlined: I unzipped eclipse VE-Update-1.4.0, copied the contents on the plugin folder to eclipse Helios plugin. However, I only found the Manifest files you referred to in features folder of eclipse. The unzipped features folder from the VE download has 'jar' files. How did you handle this? Is there a way to 'unzip' or 'execute' the jar files to get to the Manifest?
Also, in eclipse, the plugin files have extensions ".jar", but the unzipped download files have ".jar.pack.gz" Is there a utility that will decompress these plugin's down to just ".jar"?
I'm new to eclipse and java, so I will appreciate any help anyone can provide. I have been trying to get the VE component installed all weekend.
[Updated on: Tue, 06 July 2010 01:37] Report message to a moderator
Re: VE 1.4 and Eclipse 3.6 [message #545016 is a reply to message #542857] |
Tue, 06 July 2010 11:55 |
Ben H Messages: 13 Registered: July 2009 |
Hi kit,
.jar files are in fact just normal .zip files.
I am using Total Commander for example with a plug-in that handles .jar files as zip files. So i open it, edit the MANIFEST.MF in it and pack it back in.
hmm gz is a packing format that can be unpacked with a tool named gzip(gunzip), Total Commander can do that too. But what is about the .pack format i don't know. I just copied the jar files from my eclipse 3.5 installation to my 3.6. Eclipse 3.5 was able to install the ve via update site.
greetz,
Ben
[Updated on: Tue, 06 July 2010 12:01] Report message to a moderator
Re: VE 1.4 and Eclipse 3.6 [message #545497 is a reply to message #542857] |
Thu, 08 July 2010 04:13 |
Yves YANG Messages: 688 Registered: July 2009 |
The build for Helios is ongoing. It will be available soon.
Best regards
Yves YANG
"Chris" wrote in message
news:i05njj$ho2$1@build.eclipse.org...
> Hi!
> I have some problems installing VE 1.4 on a fresh Eclipse 3.6 IDE for Java
> EE Developers installation, because i get some dependency errors (see
> below). There are some infos in different threads and in this bugreport:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=301766
> for VE 1.4 and Eclipse 3.5. I have tried to installed only the VE SDK but
> still get the dependency error. Are there any chances to install VE 1.4 on
> Eclipse 3.6 or do we need a new VE version?
> Thanks in advance for a reply.
> Chris
> Dependency error:
> Quote:
>> Cannot complete the install because of a conflicting dependency.
>> Software being installed: Visual Editor SDK
>> 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO
>> (org.eclipse.ve.sdk.feature.group
>> 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO)
>> Software currently installed: Eclipse IDE for Java EE Developers
>> 1.3.0.20100617-0521 (epp.package.jee 1.3.0.20100617-0521)
>> Only one of the following can be installed at once: International
>> Components for Unicode for Java (ICU4J) 4.2.1.v20100412 (com.ibm.icu
>> 4.2.1.v20100412)
>> International Components for Unicode for Java (ICU4J) 4.0.1.v20090822
>> (com.ibm.icu 4.0.1.v20090822)
>> From: Eclipse IDE for Java EE Developers 1.3.0.20100617-0521
>> To: org.eclipse.epp.package.jee.feature.feature.group
>> [1.3.0.20100617-0521]
>> From: Java EE IDE Feature 1.3.0.20100617-0521
>> (org.eclipse.epp.package.jee.feature.feature.group 1.3.0.20100617-0521)
>> To: org.eclipse.platform.feature.group
>> [3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY]
>> From: Eclipse Platform
>> (org.eclipse.platform.feature.group
>> 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY)
>> To: org.eclipse.rcp.feature.group
>> [3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS]
>> From: Eclipse RCP 3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS
>> (org.eclipse.rcp.feature.group 3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS)
>> To: com.ibm.icu [4.2.1.v20100412]
>> To: org.eclipse.ve.java.core [1.3.0,2.0.0)
>> From: Visual Editor Java Core 1.4.0.v20090826-1446
>> (org.eclipse.ve.java.core 1.4.0.v20090826-1446)
>> To: bundle com.ibm.icu [3.4.4.1,4.1.0)
>> From: Visual Editor SDK
>> To: org.eclipse.ve.feature.group
>> [1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk]
[Updated on: Tue, 28 June 2011 14:22] by Moderator Report message to a moderator
Re: VE 1.4 and Eclipse 3.6 [message #558692 is a reply to message #558658] |
Tue, 14 September 2010 04:15 |
hiro nakag Messages: 8 Registered: August 2010 |
Hi, runiter.
Do you install EMF SDK from updatesite?
(EMF SDK is the Modeling category in updatesite.)
Required bundle "org.eclipse.emf.codegen" is a plugin included in EMF, and my plugins requre EMF and GEF SDK.
I think your eclipse is not installed EMF SDK completely.
Please check Installation Details.
Thanks for reading my poor English.
[Updated on: Tue, 14 September 2010 10:07] Report message to a moderator
Re: VE 1.4 and Eclipse 3.6 [message #629916 is a reply to message #542857] |
Wed, 29 September 2010 23:01 |
mmc01 Messages: 1 Registered: September 2010 |
I cannot install VE1.4 in Eclipse 3.6. I downloaded eclipse Helios and unzip. Next, I install VE from URL.But I have some error. After that, I install EMF from Helios - http://download.eclipse.org/releases/helios ,But when I tried to install VE again. I have same error. When I can use VE1.5? It's too late.
Missing requirement: Visual Editor PropertySheet 1.4.0.v20090826-1446 (org.eclipse.ve.propertysheet 1.4.0.v20090826-1446) requires 'bundle com.ibm.icu [3.4.4.1,4.1.0)' but it could not be found
To: org.eclipse.ve.propertysheet [1.4.0.v20090826-1446]
[Updated on: Thu, 30 September 2010 07:54] Report message to a moderator
Re: VE 1.4 and Eclipse 3.6 [message #638197 is a reply to message #633062] |
Wed, 10 November 2010 12:20 |
Santosh Messages: 4 Registered: November 2010 |
installing VE 1.4 on a fresh Eclipse 3.6 IDE I Helios in SUSE linux..... I used the following update link -> http://download.eclipse.org/tools/ve/updates/1.4/
I'm gettiing the following error message during installation:
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Collect, operand=, action=).
Artifact not found: osgi.bundle,org.eclipse.jem,2.0.300.R3_1_maintenance.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem_2.0.300.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.beaninfo,2.0.300.R3_1_maintenanc e.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.beaninfo_2.0.300.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.beaninfo.vm,2.0.200.R3_1_mainten ance.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.beaninfo.vm_2.0.200.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.beaninfo.vm.common,2.0.201.R3_1_ maintenance.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.beaninfo.vm.common_2.0.201.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.proxy,2.0.201.R3_1_maintenance.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.proxy_2.0.201.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.source,1.4.0.v20090826-1446-7H-F PbAcggQleH8hJifHfUd.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.source_1.4.0.v20090826-1446-7H-FPbAcggQleH8hJif HfUd.jar
Artifact not found: osgi.bundle,org.eclipse.jem.ui,2.0.100.R3_0_4.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.ui_2.0.100.R3_0_4.jar
Artifact not found: osgi.bundle,org.eclipse.jem.util,2.0.200.R3_1_maintenance.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.util_2.0.200.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.workbench,2.0.201.R3_1_maintenan ce.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.workbench_2.0.201.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.ve,1.4.0.v20090826-1446.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.cde,1.4.0.v20090826-1446.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.cde_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.doc,1.4.0.v20090826-1446.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.doc_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.java.core,1.4.0.v20090826-1446.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.java.core_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.propertysheet,1.4.0.v20090826-144 6.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.propertysheet_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.sdk,1.4.0.v20090826-1446.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.sdk_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.source,1.4.0.v20090826-1446-777N- CcNBC0BwNk5HZZk.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.source_1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk .jar
can any body help me
