Home » Eclipse Projects » Eclipse Platform » Help Search for nested bottom up documentation structures failes
Help Search for nested bottom up documentation structures failes [message #301171] Fri, 24 March 2006 08:23
Hi all,
I working with Eclipse 3.2M5 and have two plug-ins contributing to the
documentation. The first one contains the anchors while the second one
contributes by referencing the anchors. The merged documentation is
available in the "Help -Eclipse" window, *but* when I try to search via
the "Search: " entry only words in plug-in one are found.
How do I enable "Search:" to look into plug-in two documentation too?
What did I miss?
Many thanks
Guenther
--------- configuration --------
My setup looks like this:
Plug-in one "de.XXX.help/$nl$/toc.xml"
<toc label="Mein Handbuch" >
<topic label="Inhaltsverzeichnis"
href="html/Inhaltsverzeichnis.htm">
<anchor id="TOC"/>
</topic>
</toc>
Plug-in two:
<toc label="Diagrammverzeichnis"
link_to="../de.XXX.help/$nl$/toc.xml#TOC">
<topic label="Diagramme" href="html/figures.htm"/>
</toc>
Previous Topic:adding org.eclipse.swt
Next Topic:Best way to deploy an application?
Current Time: Mon Nov 17 16:52:26 EST 2025
Powered by FUDForum. Page generated in 0.03299 seconds
