Re: CellEditor activation on double click [message #300448 is a reply to message #300362] |
Thu, 09 March 2006 08:50 |
Originally posted by: address.starts.after.hyphen-martin.umgeher.joanneum.at
Fabrizio Bertocci wrote:
> This question has been already asked in the past, but still I couldn't
> find an answer to this:
> Does anybody know how can I enable the CellEditor of a table only after
> a double click instead of a single click?
> I would like to have the capability to select a row with a single click
> and edit a cell by double-clicking at it.
> Any help is appreciated!
> Fabrizio
I also would like to do that, have posted this question several times,
never got an answer. There is a bug report that looks promising:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=87733
But it's from March 2005, and the only comment (from Veronika Irvine)
says 'This behaviour is provided by JFace. Moving to the UI component.'
which I don't understand: does it work, and I just can't find the
functionality? Or will it be possible in the next eclipse release?
If someone could shed some light on that subject, I'd be very thankful.
M
Re: CellEditor activation on double click [message #300540 is a reply to message #300448] |
Fri, 10 March 2006 23:47 |
Originally posted by: _NOSPAM_fabrizio.rti.com
Martin (& everybody else is interested to hear about this),
I gave a look at the Jface source code, and I now understand what does
that comment (in Bugzilla) means.
The TableViewer object uses this TableEditorImpl (so, not a
TableViewerImpl as stated in the bug report) to manage the low-level
interaction with the cell editor.
The TableEditorImpl sucks big time... these are some functions from that
file:
____________________________________________________
* Handles the mouse down event; activates the cell editor.
* @param event the mouse event that should be handled
public void handleMouseDown(MouseEvent event) {
if (event.button != 1)
return;
if (cellEditor != null)
applyEditorValue();
// activate the cell editor immediately. If a second mouseDown
// is received prior to the expiration of the doubleClick time then
// the cell editor will be deactivated and a doubleClick event will
// be processed.
doubleClickExpirationTime = event.time
+ Display.getCurrent().getDoubleClickTime();
Item[] items = getSelection();
// Do not edit if more than one row is selected.
if (items.length != 1) {
tableItem = null;
return;
tableItem = items[0];
activateCellEditor(event);
the 'activateCellEditor(event)' make sure that the click happens over an
editable cell and calculate which cell to edit, set some globals, then
pass the control to
'activateCellEditor()' (without arguments) that:
- implements the real activation of the cell editor
- installs a MouseListener to check if another click happens before
the double-click time. If this happen it 'cancel editing' and call the
TableViewer method 'handleDoubleClickEvent' (that fire up a 'double
click event' to the StructuredViewer (base class of TableViewer).
So, bottom line here, is that is not that simple to make this behavior
configurable, because there are a bunch of other classes that depends on
this behavior, and the entire API is designed around this behavior...
See, the method called to the TableViewer is 'handleDoubleClickEvent' ->
The entire class and interface structure is specifically designed to
work in this way...
Don't misunderstand me, I'm sure it is a perfectly possible job, but not
in 10 minutes (at least for me).
Fabrizio
>> after a double click instead of a single click?
>> click and edit a cell by double-clicking at it.
>> Fabrizio
> M
Re: CellEditor activation on double click [message #300641 is a reply to message #300545] |
Tue, 14 March 2006 15:31 |
Stepan Rutz wrote:
> Proposed workaround:
> Add a new empty column at the beginning of the table/tree. This column
> shows no content or the number of the record or a small icon like a
> small 4x4 pixel square. Also that column can be colored differently with
> an ITableColorProvider or such.
> The purpose of this non-editable column at the first position is to
> provide a way to select columns. Its quite intuitive and users will find
> out very soon that they can use it to select columns. A width of approx.
> 24 or 32 pixels will do so not much screen-estate is wasted.
> Its just a workaround, since I myself ran into the hardwired behavior of
> "single-click-always-edits"-problem.
> /Stepan
I played around a bit with this stuff and came up with a solution that
seems to work but is far from perfect. Class TableViewerSupport
implements the SWT Listener interface so that it gets the double-click
event and knows on what cell the action occured (thx to snippet 3). It
also implements ICellModifier and acts as a proxy for the actual
modifier of the TableViewer, only allowing cell modification during a
double-click event and delegating all other functionality. It's still
quite ugly (I don't like top-level classes implementing listener
interfaces, for example), but as I said---it seems to work.
To use it, pass your TableViewer instance to the static method
TableViewerSupport.enableDoubleClickEditing. I hope this helps someone.
If you find a big *ooups* in there, please tell me :)
M
P.S. I'd still love to see the 'edit on double-click' functionality to
be part of SWT/jFace.
import org.eclipse.jface.viewers.ICellModifier;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.TableItem;
public class TableViewerSupport implements Listener, ICellModifier {
private final TableViewer viewer;
private final ICellModifier modifier;
private boolean isEditingEnabled = false;
public static void enableDoubleClickEditing(TableViewer viewer) {
new TableViewerSupport(viewer);
private TableViewerSupport(TableViewer viewer) {
this.viewer = viewer;
modifier = viewer.getCellModifier();
viewer.setCellModifier(this);
viewer.getTable().addListener(SWT.MouseDoubleClick, this);
public void handleEvent(Event event) {
final Point pt = new Point(event.x, event.y);
final TableItem item = viewer.getTable().getItem(pt);
if (item != null) {
for (int column = 0; column < viewer.getTable().getColumnCount();
column++) {
Rectangle rect = item.getBounds(column);
if (rect.contains(pt)) {
isEditingEnabled = true;
viewer.editElement(item.getData(), column);
return;
public boolean canModify(Object element, String property) {
return isEditingEnabled && modifier.canModify(element, property);
public Object getValue(Object element, String property) {
return modifier.getValue(element, property);
public void modify(Object element, String property, Object value) {
modifier.modify(element, property, value);
FUDForum. Page generated in 0.03975 seconds
