Home » Newcomers » Newcomers » C/C++ Perspective missing ...
| C/C++ Perspective missing ... [message #268122] |
Mon, 26 January 2009 17:17  |
Originally posted by: kbeitz.jetheaddev.com
i've installed eclipse on my machine here, but cannot get it to provide me
with the C/C++ perspective.
i'm pasting the configuration details at the bottom. note that a number of
'org.eclipse.cdt' items are listed.
the original download link from my browser history is:
http://eclipse.unixheads.org/technology/epp/downloads/releas e/ganymede/SR1/eclipse-jee-ganymede-SR1-linux-gtk-x86_64.tar .gz
after initial installation, i went to the "Software Updates" page, and
attempted to install a number of items, including "C and C++ Development",
showing "Eclipse C/C++ Development Platform - Version 5.0.1.200809120802"
and "Eclipse C/C++ Development Tools - Version 5.0.1.200809120802" along
with Mylin Bridge development (same version).
i expected the C/C++ perspective to automatically be amongst the perspective
choices when choosing "Other...", but while there are many choices, C/C++ is
not amongst them.
i have tried the Help, and it informs me the first thing i need to do is
choose the C/C++ perspective, then perhaps choose "Reset Perspective". but
i cannot get that far.
does anyone have any ideas as to why the C/C++ perspective would not be
available?
*** Date: Monday, January 26, 2009 2:09:43 PM PT
*** Platform Details:
*** System properties:
eclipse.buildId=M20080911-1700
eclipse.commands=-os
linux
-ws
gtk
-arch
x86_64
-showsplash
-launcher
/usr/local/bin/eclipse/eclipse
-name
Eclipse
--launcher.library
/usr/local/bin/eclipse/plugins/org.eclipse.equinox.launcher. gtk.linux.x86_64_1.0.101.R34x_v20080731/eclipse_1115.so
-startup
/usr/local/bin/eclipse/plugins/org.eclipse.equinox.launcher_ 1.0.101.R34x_v20080819.jar
-exitdata
628095
-vm
/usr/bin/java
eclipse.ee.install.verify=false
eclipse.home.location=file:/usr/local/bin/eclipse/
eclipse.launcher=/usr/local/bin/eclipse/eclipse
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=PlatformProfile
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1233005850262
eclipse.vm=/usr/bin/java
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-jar
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/usr/local/bin/eclipse/plugins/org.eclipse.e quinox.launcher_1.0.101.R34x_v20080819.jar
java.class.version=50.0
java.endorsed.dirs=/usr/lib/jvm/java-6-sun-1.6.0.07/jre/lib/ endorsed
java.ext.dirs=/usr/lib/jvm/java-6-sun-1.6.0.07/jre/lib/ext:/ usr/java/packages/lib/ext
java.home=/usr/lib/jvm/java-6-sun-1.6.0.07/jre
java.io.tmpdir=/tmp
java.library.path=/usr/lib/jvm/java-6-sun-1.6.0.07/jre/lib/a md64/server:/usr/lib/jvm/java-6-sun-1.6.0.07/jre/lib/amd64:/ usr/lib/jvm/java-6-sun-1.6.0.07/jre/../lib/amd64:/usr/lib64/ xulrunner-addons:/usr/java/packages/lib/amd64:/lib:/usr/lib
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_07-b06
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_07
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=10.0-b23
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.defaultlog=off
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.location=/usr/local/bin/ eclipse/plugins/org.eclipse.platform_3.3.101.v200809111700/s plash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.swt.browser.XULRunnerInitialized=true
org.eclipse.swt.browser.XULRunnerPath=/usr/lib/xulrunner-1.9 .0.5
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.24
org.osgi.framework.processor=x86-64
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.k
erberos,javax.security.auth.login,javax.security.auth.spi,ja vax.security.auth.x500,javax.security..cert,javax.security.s asl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sample d,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.s ql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swin g.border,javax.swing.colorchooser,javax.swing.event,javax.sw ing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,java x.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.s ynth,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser,javax.swing.text.rtf,javax.sw ing.tree,javax.swing.undo,javax.tools,javax.transaction,java x.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.ann otation,javax.xml.bind.annotation.adapters,javax.xml.bind.at tachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xm l.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xm l.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.cr ypto.dsig.spec,javax.xml.dataty
pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.Current
Package,org.omg.PortableServer.POAManagerPackage,org.omg.Por tableServer.POAPackage,org.omg.PortableServer.portable,org.o mg.PortableServer.ServantLocatorPackage,org.omg.SendingConte xt,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,o rg.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.d om.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom .traversal,org.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=amd64
os.name=Linux
os.version=2.6.24-23-generic
osgi.arch=x86_64
osgi.bundles=reference:file:org.eclipse.equinox.simpleconfigurator_1.0.0.v20080604.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/usr/local/bin/eclipse/configuration/org.ec lipse.osgi/bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/usr/local/bin/eclipse/configur ation/
osgi.framework=file:/usr/local/bin/eclipse/plugins/org.eclip se.osgi_3.4.2.R34x_v20080826-1230.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.4.2.R34x_v20080826-1230
osgi.install.area=file:/usr/local/bin/eclipse/
osgi.instance.area=file:/x/
osgi.instance.area.default=file:/home/kbeitz/workspace/
osgi.logfile=/x/.metadata/.log
osgi.manifest.cache=/usr/local/bin/eclipse/configuration/org .eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.splashLocation=/usr/local/bin/eclipse/plugins/org.eclip se.platform_3.3.101.v200809111700/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/usr/local/bin/eclipse/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=64
sun.boot.class.path=/usr/lib/jvm/java-6-sun-1.6.0.07/jre/lib /resources.jar:/usr/lib/jvm/java-6-sun-1.6.0.07/jre/lib/rt.j ar:/usr/lib/jvm/java-6-sun-1.6.0.07/jre/lib/sunrsasign.jar:/ usr/lib/jvm/java-6-sun-1.6.0.07/jre/lib/jsse.jar:/usr/lib/jv m/java-6-sun-1.6.0.07/jre/lib/jce.jar:/usr/lib/jvm/java-6-su n-1.6.0.07/jre/lib/charsets.jar:/usr/lib/jvm/java-6-sun-1.6. 0.07/jre/classes
sun.boot.library.path=/usr/lib/jvm/java-6-sun-1.6.0.07/jre/l ib/amd64
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=gnome
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/usr/local/bin
user.home=/home/kbeitz
user.language=en
user.name=kbeitz
user.timezone=US/Pacific
*** Features:
org.eclipse.cdt (5.0.1.200809120802) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.mylyn (5.0.1.200809120802) "Mylyn Plug-in"
org.eclipse.cvs (1.1.1.r34x_20080902-7C79E8N9nJD4oAW9V1938) "Eclipse CVS Client"
org.eclipse.datatools.connectivity.feature
(1.6.1.v200809191145-7_7K7_Dn-QY4jNGDlg0YiVa76H) "Data Tools Platform
Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.6.1.v200809191145-7C67OCYQCD4D-JkHcYh) "DTP ODA Designer UI Framework
Plug-in"
org.eclipse.datatools.connectivity.oda.feature
(1.6.1.v200809191145-7F27PBcMAAwAtKkESVZ) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.6.1.v200809191145-37A09oA55S5P_P8CEO24)
"Data Tools Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature
(1.6.1.v200809191145-652AlJAKaLiJyLhdmBEKK) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.enablement.feature
(1.6.1.v200809191145-7D8H7C9FSwOBZabCz-MXEZLR8Rnc) "Eclipse Data Tools
Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature
(1.6.1.v200809191145-57_1_pF9IQJZIsJcVhBEKK) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.ibm.feature
(1.6.1.v200809191145-7D43EB7sQS9RbiYgHAa) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.jdbc.feature
(1.6.1.v200809191145-3-09oA55S5J8JADJJ) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.msft.feature
(1.6.1.v200809191145-442_kE77c7VBQDFNW) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.mysql.feature
(1.6.1.v200809191145-442_kE77c7TBTBKPQ) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.oda.designer.feature
(1.6.1.v200809191145-2118s733I3I6C4_6C) "Eclipse Data Tools Platform XML ODA
Designer"
org.eclipse.datatools.enablement.oda.feature
(1.6.1.v200809191145-797P6CYQCD4CvIcEeNW) "Eclipse Data Tools Platform XML
ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature
(1.6.1.v200809191145-442_kE77c7UAOBJML) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.postgresql.feature
(1.6.1.v200809191145-441_kE77c7R_RCIOP) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sap.feature
(1.6.1.v200809191145-440_kE77c7QAQEIQQ) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature
(1.6.1.v200809191145-7A-5E9IgKLhLGetRuu9) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.modelbase.feature
(1.6.1.v200809191145-6-0BcMAAwAmEgFXTT) "Eclipse Data Tools Platform
SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.feature
(1.6.1.v200809191145-7F7d5E8yz-UHrDYUGnc_DXkE39Kp) "Eclipse Data Tools
Platform SQL Tools Common UI Plug-in"
org.eclipse.dltk.core (0.95.1.v20080626-2043-0EEJ6E9IgKLhLZW8AKz0uq5)
"Eclipse Dynamic Languages Toolkit (Incubation)"
org.eclipse.dltk.mylyn (0.95.1.v20080626-2043-08T07w31191_1402545) "Dynamic
Languages Toolkit IncrTcl Core"
org.eclipse.dltk.tcl (0.95.1.v20080626-2043-0EEJ77E9IgKLhLeUz0ALs1x5) "Tcl
Development Tools (Incubation)"
org.eclipse.draw2d (3.4.1.v20080806-3307w31191_2102462) "Graphical Editing
Framework Draw2d"
org.eclipse.emf (2.4.1.v200808251517) "EMF - Eclipse Modeling Framework"
org.eclipse.emf.codegen (2.4.0.v200808251517) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.4.1.v200808251517) "EMF Ecore Code Generator"
org.eclipse.emf.codegen.ecore.ui (2.4.1.v200808251517) "EMF Ecore Code
Generator UI"
org.eclipse.emf.codegen.ui (2.4.0.v200808251517) "EMF Code Generation UI"
org.eclipse.emf.common (2.4.0.v200808251517) "EMF Common"
org.eclipse.emf.common.ui (2.4.0.v200808251517) "EMF Common UI"
org.eclipse.emf.converter (2.4.1.v200808251517) "EMF Model Converter"
org.eclipse.emf.databinding (1.0.0.v200808251517) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.0.0.v200808251517) "EMF Edit Data Binding"
org.eclipse.emf.ecore (2.4.1.v200808251517) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.4.1.v200808251517) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.4.0.v200808251517) "EMF Sample Ecore Editor"
org.eclipse.emf.ecore.sdo (2.4.0.v200808251517) "EMF SDO - EMF's Service
Data Objects Implementation"
org.eclipse.emf.edit (2.4.1.v200808251517) "EMF Edit"
org.eclipse.emf.edit.ui (2.4.1.v200808251517) "EMF Edit UI"
org.eclipse.emf.mapping (2.4.0.v200808251517) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.4.0.v200808251517) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.4.0.v200808251517) "EMF Ecore
Mapping Editor"
org.eclipse.emf.mapping.ui (2.4.0.v200808251517) "EMF Mapping UI"
org.eclipse.gef (3.4.1.v20080806-67718083A56B4H2A3213573) "Graphical Editing
Framework GEF"
org.eclipse.help (1.0.1.R34x_v20080827-7r7xEIxEI6Zu5nEqN7M3UBpglaat) "Help
System Base"
org.eclipse.jdt (3.4.1.r341_v20080709-0800-7o7tEAfEF_U5qyUgrb2HAp539P97)
"Eclipse Java Development Tools"
org.eclipse.jst (3.0.2.v200808250510-7U-8r9LJ9cNr7UGsQ02P0aZsUk1o) "J2EE
Standard Tools (JST)"
org.eclipse.jst.ws.axis2tools.feature
(1.0.1.v200807092124-77-E_BCYQCD4CyNjOPRU) "J2EE Standard Tools (JST)"
org.eclipse.mylyn_feature (3.0.3.v20081015-1500-e3x) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.0.3.v20081015-1500-e3x) "Mylyn"
org.eclipse.mylyn.context_feature (3.0.3.v20081015-1500-e3x) "Mylyn"
org.eclipse.mylyn.ide_feature (3.0.3.v20081015-1500-e3x) "Mylyn"
org.eclipse.mylyn.java_feature (3.0.3.v20081015-1500-e3x) "Mylyn"
org.eclipse.mylyn.pde_feature (3.0.3.v20081015-1500-e3x) "Mylyn"
org.eclipse.mylyn.team_feature (3.0.3.v20081015-1500-e3x) "Mylyn"
org.eclipse.nab.mwt (0.9.9.200806181757) "NAB/MWT Plug-in"
org.eclipse.nab.mwt.native.linux.gtk (0.9.9.200806181757) "GTK handler for
NAB/MWT Plug-in"
org.eclipse.pde (3.4.1.r341_v20080731-7T7U0E9mlRIuGUYviF_VP) "PDE"
(3.4.1.r341_v20080731-9I96EiDElYevwz-p1bP5z-NlAaP7vtX6Utotqs u) "Eclipse
Platform"
org.eclipse.rcp (3.4.100.r341_v20080814-989JESIEdAciFYfkZZsBfSwQ2341)
"Eclipse RCP"
org.eclipse.releng.tools (3.2.200.v20080603-33-7w31191525) "RelEng Plug-in"
org.eclipse.rse (3.0.1.v200809181500-7H368qfenEMeUOENNFdiKV_gK8) "Remote
System Explorer End-User Runtime"
org.eclipse.rse.core (3.0.1.v200809171600-7Z379EB7sQS9S4YPJaHC) "Remote
System Explorer Core"
org.eclipse.rse.dstore (3.0.1.v200809181500-7J32DUUEFDF8Hu9FH7) "RSE DStore
Services"
org.eclipse.rse.ftp (3.0.1.v200809171630-78479_kE77c7Q8b8T_F) "RSE FTP Service"
org.eclipse.rse.local (2.1.1.v20080710-7_40AgI99m9d_O) "RSE Local Services"
org.eclipse.rse.ssh (2.1.1.v20080714-7830_kE77c7V8M) "RSE SSH Services"
org.eclipse.rse.telnet (2.1.1.v200809181500-6678AgI99m9W9X5J79) "RSE Telnet
Service"
org.eclipse.rse.terminals (0.1.1.v200809041200-2229sB7EO_T_T5C6B3457) "RSE
Terminals UI (Incubation)"
org.eclipse.rse.useractions (1.1.1.v200809041200-2118s733I3K484673) "RSE
User Actions"
org.eclipse.sdk
(3.4.1.R34x_v20080827-7O7S78C2J40sK2o_ALcK8tLN_yZSJeg0P-3EtL 4Ra90kv)
"Eclipse Project SDK"
org.eclipse.team.svn (0.7.3.I20080814-1500) "Subversive SVN Team Provider
(Incubation)"
org.eclipse.team.svn.mylyn (0.7.3.I20080814-1500) "Subversive Integration
for the Mylyn Project (Incubation)"
org.eclipse.team.svn.mylyn.source (0.7.3.I20080814-1500) "The sources of the
Subversive Integration for the Mylyn Project (Incubation)"
org.eclipse.team.svn.nl1 (0.7.3.I20080814-1500) "Subversive SVN Team
Provider Localization (Incubation)"
org.eclipse.team.svn.nl1.sources (0.7.3.I20080814-1500) "The sources of the
Subversive Localization (Incubation)"
org.eclipse.team.svn.resource.ignore.rules.jdt (0.7.3.I20080814-1500)
"Subversive JDT Ignore Extensions (Incubation)"
org.eclipse.team.svn.resource.ignore.rules.jdt.source (0.7.3.I20080814-1500)
"The sources of the Subversive JDT Ignore Extensions (Incubation)"
org.eclipse.team.svn.sources (0.7.3.I20080814-1500) "The sources of the SVN
Team Provider (Incubation)"
org.eclipse.tm.discovery (3.0.0.v20080530-7N-E8ME8McIJXIwdh) "Target
Management Service Discovery Engine"
org.eclipse.tm.terminal (2.0.1.v200807281235-2-07w311918392346) "Target
Management Terminal Widget"
org.eclipse.tm.terminal.serial (2.0.1.v20080715-2-07w31191826) "Target
Management Terminal Serial Connector"
org.eclipse.tm.terminal.ssh (2.0.1.v200807281235-2-07w311918392346) "Target
Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet (2.0.1.v20080715-2-07w31191826) "Target
Management Terminal Telnet Connector"
org.eclipse.tm.terminal.view (2.0.1.v20080715-2-07w31191826) "Target
Management Terminal View"
org.eclipse.wst (3.0.2.v200808250510-7A-8f8QqVJLTFUkFahb1QIq2z0t8) "Web
Standard Tools (WST)"
org.eclipse.wst.ws_wsdl14.feature (1.4.0.v200802280619-13-7w311917141518)
"Web Standard Tools (WST)"
org.eclipse.wst.ws_wsdl15.feature (1.5.1.v200802280619-1407w311917141519)
org.eclipse.xsd (2.4.1.v200808251517) "XSD - XML Schema Definition Model"
org.eclipse.xsd.edit (2.4.0.v200808251517) "XSD Edit"
*** Plug-in Registry:
com.ibm.icu (3.8.1.v20080530) "International Components for Unicode for Java
(ICU4J)" [Active]
com.jcraft.jsch (0.1.37.v200803061811) "JSch" [Resolved]
javax.activation (1.1.0.v200806101325) "Apache Geronimo Activation Plug-in"
[Resolved]
javax.mail (1.4.0.v200804091730) "Javax Mail Plug-in" [Resolved]
javax.servlet (2.4.0.v200806031604) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle"
[Resolved]
javax.wsdl (1.4.0.v200806030407) "WSDL4J" [Resolved]
javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
javax.xml (1.3.4.v200806030440) "JAXP XML" [Resolved]
javax.xml.rpc (1.1.0.v200806030420) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200806030421) "SAAJ" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG"
[Resolved]
org.apache.ant (1.7.0.v200803061910) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v200807230600) "Apache Web Services" [Resolved]
org.apache.cactus (1.7.2.v200805140145) "Cactus Resource Plug-in" [Starting]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.discovery (0.2.0.v200806030120) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons
Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v200803061910) "Apache Jakarta Commons Lang"
[Resolved]
org.apache.commons.logging (1.0.4.v20080605-1930) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.net (1.4.1.v200803071935) "Apache Commons Net" [Resolved]
org.apache.jasper (5.5.17.v200806031609) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.log4j (1.2.13.v200806030600) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis"
[Resolved]
org.apache.oro (2.0.8.v200803061811) "Apache Jakarta ORO" [Resolved]
org.apache.wsil4j (1.0.0.v200806040330) "WSIL4J" [Resolved]
org.apache.xerces (2.9.0.v200805270400) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v200806030312) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v200806030322) "Apache XML Commons
Serializer" [Resolved]
org.eclipse.ant.core (3.2.0.v20080529) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.3.0.v20080529) "Ant UI" [Starting]
[Starting]
org.eclipse.cdt.core (5.0.1.200809120802) "C/C++ Development Tools Core"
[Starting]
org.eclipse.cdt.core.linux (5.0.0.200809120802) "C/C++ Development Tools
Core for Linux" [Resolved]
org.eclipse.cdt.core.linux.x86_64 (5.0.0.200809120802) "C/C++ Development
Tools Core for Linux (x86_64)" [Resolved]
org.eclipse.cdt.debug.core (5.0.1.200809120802) "C/C++ Development Tools
Debug Model" [Starting]
org.eclipse.cdt.debug.mi.ui (5.0.1.200809120802) "C/C++ Development Tools
GDB/MI CDI Debugger UI" [Installed]
org.eclipse.cdt.debug.ui (5.0.1.200809120802) "C/C++ Development Tools
org.eclipse.cdt.doc.user (5.0.1.200809120802) "C/C++ Development User Guide"
[Starting]
org.eclipse.cdt.launch (5.0.1.200809120802) "C/C++ Development Tools
Launching Support" [Installed]
org.eclipse.cdt.make.core (5.0.1.200809120802) "C/C++ Standard make Build
Core" [Starting]
org.eclipse.cdt.make.ui (5.0.1.200809120802) "C/C++ Standard make Build UI"
[Installed]
org.eclipse.cdt.managedbuilder.core (5.0.1.200809120802) "CDT Build System
Core" [Starting]
org.eclipse.cdt.managedbuilder.gnu.ui (5.0.0.200809120802) "GNU Managed
Build Definitions" [Starting]
org.eclipse.cdt.managedbuilder.ui (5.0.1.200809120802) "C/C++ Managed
Builder UI" [Installed]
org.eclipse.cdt.mylyn (1.0.0.200809120802) "Mylyn Plug-in" [Resolved]
org.eclipse.cdt.mylyn.ui (5.0.1.200809120802) "Mylyn CDT Integrator" [Installed]
org.eclipse.compare (3.4.0.I20080604) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.4.0.I20080509-2000) "Commands" [Resolved]
org.eclipse.core.contenttype (3.3.0.v20080604-1400) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.1.1.M20080827-0800b) "JFace Data Binding"
[Active]
org.eclipse.core.databinding.beans (1.1.1.M20080827-0800a) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.4.0.v20080603-2000) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.4.0.v20080603-2000) "File Buffers" [Active]
org.eclipse.core.filesystem (1.2.0.v20080604-1400) "Core File Systems" [Active]
org.eclipse.core.filesystem.linux.x86_64 (1.0.100.v20080604-1400) "Core File
System for Linux" [Resolved]
org.eclipse.core.jobs (3.4.0.v20080512) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.1.0.I20080604) "Internet Connection Management" [Active]
org.eclipse.core.resources (3.4.1.R34x_v20080902) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.4.0.v20080604-1400) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.runtime (3.4.0.v20080512) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20071008) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20080610) "Eclipse
Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.100.v20080529-1300) "Core Variables" [Active]
org.eclipse.cvs (1.0.100.v20080603) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.connectivity (1.1.1.v200809180120) "Data Tools
Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.1.v200807150030)
"Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform Apache Derby Database
Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.1.v200807010433)
"Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200805231345)
"DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.0.v200805152355) "Eclipse
Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v200805152355)
"Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC
(1.0.0.v200805152355) "Eclipse Data Tools Platform DBDefinition Generic JDBC
Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda (3.1.3.v200808270255) "DTP Open Data
Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.3.v200808270255) "DTP
ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.7.v200807231215) "DTP ODA
Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.7.v200808051050) "DTP
ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.7.v200808261835)
"Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.7.v200808130628)
"Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.6.v200805152355) "DTP
ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.6.v200805152355)
"DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.3.v200809180120) "Eclipse
Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.1.1.v200808140022)
"Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.1.v200808300421)
"Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.1.2.v200809150616) "Data Tools
Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.1.v200807230727) "Eclipse
Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.6.1.v20080828133713) "Data Tools Platform
User Documentation" [Resolved]
org.eclipse.datatools.enablement.finfo (1.5.1.v200805152355) "Eclipse Data
Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200805152355) "Eclipse Data
Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200805152355)
"Eclipse Data Tools Platform HSQLDB Database Definition Enablement Plug-in"
[Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200807220100) "Eclipse
Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n
(1.0.0.v200806100223) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.0.v200805152355) "Eclipse
Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform DB2 UDB Database
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n
(1.0.0.v200805152355) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.0.v200805152355) "Eclipse
Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition
(1.0.1.v200807170829) "Eclipse Data Tools Platform Informix Database
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200806271414) "Eclipse Data
Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v200805152355) "Data
Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v200807181158)
"Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform SQL Server Database
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200808222228)
"Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.1.v200808261158) "Eclipse Data
Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.1.v200805170742)
"Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200805152355) "Eclipse
Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.1.1.v200808211640) "Eclipse Data
Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.1.1.v200808271112) "Eclipse
Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.1.1.v200808261409) "Eclipse Data
Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.1.1.v200808130628) "Eclipse
Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200805152355) "Eclipse Data
Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.1.v200808021450)
"Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.1.v200806260315) "Eclipse
Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200805152355)
"PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition
(1.0.0.v200805152355) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200806060334)
"PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200805152355) "Eclipse
Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform MaxDB Definition Plug-in"
[Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200805152355) "Eclipse
Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200805310538) "High-level
Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200805310538) "Sybase
ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASA Database
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200805152355)
"Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200805310538) "Sybase
ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200807010411)
"JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASE Database
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200805152355)
"Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200806260315) "ASE
Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200805152355) "Sybase
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200808221518) "Sybase UI
Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200805152355) "Data Tools Platform Help
Utilities" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.0.v200808020150) "Eclipse
Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v200805152355) "Derby Plug-in"
[Starting]
org.eclipse.datatools.modelbase.sql (1.0.0.v200805152355) "Eclipse Data
Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.v200805152355) "Eclipse Data
Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.1.v200807251820) "Eclipse
Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200806070329) "SQL
Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.v200807080500) "Eclipse
Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.0.v200808280228) "DTP ODA
Context-sensitive Help" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200807211830) "Eclipse Data
Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.0.0.v200808260630) "Data Core
Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.1.0.v200808260630) "Data UI
Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200805152355) "Eclipse Data
Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200808140643) "Eclipse
Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.0.v200808140615) "Eclipse Data
Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.v200808140615) "Eclipse
Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v200808271350) "Eclipse
Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.1.v200808140615) "Eclipse
Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200808080530)
"Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.1.v200808140615)
"Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200808140615)
"Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200807211830) "Eclipse Data
Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.v200808271350) "Eclipse Data
Tools Platform SQL Results View Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v200807211830) "Eclipse
Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200808140615) "Eclipse Data Tools
Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.0.v200808271350) "SQL
Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.v200808271350) "Eclipse Data
Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.v200808271350) "Eclipse
Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.v200808300730)
"Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.tablewizard (1.0.0.v200808140615) "Eclipse
Data Tools Platform Database Table Creation Plug-in" [Starting]
org.eclipse.dd.debug.memory.renderings.traditional (1.0.0.v20080609)
"Traditional Memory Rendering" [Starting]
org.eclipse.dd.debug.ui.memory.transport (1.0.0.v20080609) "Memory Transport
Plug-in" [Starting]
org.eclipse.dd.dsf (1.0.0.v20080609) "Debug Services Framework Core" [Starting]
org.eclipse.dd.dsf.debug (1.0.0.v20080609) "Debug Services Framework Debug"
[Starting]
org.eclipse.dd.dsf.debug.ui (1.0.0.v20080609) "Debug Services Framework
Debug UI" [Installed]
org.eclipse.dd.dsf.ui (1.0.0.v20080609) "Debug Services Framework UI" [Starting]
org.eclipse.dd.gdb (1.0.0.v20080609) "GDB DSF Debugger Integration Core"
[Starting]
org.eclipse.dd.gdb.launch (1.0.0.v20080609) "Debug Services Framework GDB
Launch Plug-in" [Installed]
org.eclipse.dd.gdb.ui (1.0.0.v20080609) "Debug Services Framework GDB UI
org.eclipse.dd.mi (1.0.0.v20080609) "GDB/MI Protocol-based DSF Debugger
Integration Core" [Starting]
org.eclipse.debug.core (3.4.0.v20080612) "Debug Core" [Active]
org.eclipse.debug.ui (3.4.1.v20080811_r341) "Debug UI" [Starting]
org.eclipse.dltk (0.95.0.v20080526-1423) "Eclipse Dynamic Languages Toolkit
(Incubation)" [Resolved]
org.eclipse.dltk.console (0.95.0.v20080526-1423) "Dynamic Languages Toolkit
Console Core (Incubation)" [Starting]
org.eclipse.dltk.console.ui (0.95.0.v20080526-1423) "Dynamic Languages
Toolkit Console UI (Incubation)" [Active]
org.eclipse.dltk.core (0.95.1.v20080920-R0951) "Dynamic Languages Toolkit
Core (Incubation)" [Active]
org.eclipse.dltk.debug (0.95.1.v20080903-1434) "Dynamic Languages Toolkit
Debug Core (Incubation)" [Starting]
org.eclipse.dltk.debug.ui (0.95.1.v20080903-1434) "Dynamic Languages Toolkit
Debug UI (Incubation)" [Starting]
org.eclipse.dltk.launching (0.95.1.v20080915-1703) "Dynamic Languages
Toolkit Launching Core (Incubation)" [Active]
org.eclipse.dltk.mylyn (0.95.1.v20080903-1434) "Dynamic Languages Toolkit
IncrTcl Core" [Starting]
org.eclipse.dltk.tcl (0.95.0.v20080526-1423) "Tcl Development Tools
org.eclipse.dltk.tcl.activestatedebugger (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit Tcl Active State Debugger Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.core (0.95.1.v20080920-R0951) "Dynamic Languages
Toolkit Tcl Core (Incubation)" [Starting]
org.eclipse.dltk.tcl.debug (0.95.0.v20080526-1423) "Dynamic Languages
Toolkit Tcl Debug Core (Incubation)" [Starting]
org.eclipse.dltk.tcl.debug.ui (0.95.1.v20080626-2043) "Dynamic Languages
Toolkit Tcl Debug UI (Incubation)" [Starting]
org.eclipse.dltk.tcl.doc.user (0.95.0.v20080609-1540) "Tcl Development User
Guide (Incubation)" [Starting]
org.eclipse.dltk.tcl.launching (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Tcl Launching Core (Incubation)" [Starting]
org.eclipse.dltk.tcl.tclchecker (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit TclChecker Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.testing (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Tcl Testing Frameworks Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.testing.tcltest (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit TclTest Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.ui (0.95.1.v20080920-R0951) "Dynamic Languages Toolkit
Tcl UI (Incubation)" [Active]
org.eclipse.dltk.testing (0.95.0.v20080609-1540) "Dynamic Languages Toolkit
org.eclipse.dltk.ui (0.95.1.v20080920-R0951) "Dynamic Languages Toolkit Core
org.eclipse.dltk.validators.core (0.95.1.v20080707-1511) "Dynamic Languages
Toolkit Validators Core (Incubation)" [Starting]
org.eclipse.dltk.validators.ui (0.95.1.v20080707-1511) "Dynamic Languages
Toolkit Validators UI (Incubation)" [Starting]
org.eclipse.draw2d (3.4.0.v20080529) "Graphical Editing Framework Draw2d"
[Starting]
org.eclipse.draw2d (3.4.1.v20080910-1351) "Graphical Editing Framework
Draw2d" [Starting]
org.eclipse.dstore.core (3.0.1.v200809110140) "RSE DStore Core" [Starting]
org.eclipse.dstore.extra (2.1.0.v20080406) "RSE DStore Platform Support"
[Starting]
org.eclipse.ecf (2.0.0.v20080611-1715) "Eclipse Communication Framework
(ECF)" [Active]
org.eclipse.ecf.filetransfer (2.0.0.v20080611-1715) "ECF Filetransfer API"
[Active]
org.eclipse.ecf.identity (2.0.0.v20080611-1715) "ECF Identity API" [Active]
org.eclipse.ecf.provider.filetransfer (2.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.0.v20080611-1715) "Eclipse Communication Framework
(ECF)" [Resolved]
org.eclipse.emf (2.4.0.v200808251517) "EMF - Eclipse Modeling Framework"
[Starting]
org.eclipse.emf.ant (2.4.0.v200808251517) "EMF Ant Tasks" [Starting]
org.eclipse.emf.codegen (2.4.0.v200808251517) "EMF Code Generation" [Starting]
Generator" [Starting]
Generator UI" [Starting]
[Starting]
org.eclipse.emf.common (2.4.0.v200808251517) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.4.0.v200808251517) "EMF Common UI" [Active]
org.eclipse.emf.commonj.sdo (2.4.0.v200808251517) "CommonJ SDO - Service
Data Objects" [Starting]
org.eclipse.emf.converter (2.4.0.v200808251517) "EMF Model Converter" [Starting]
org.eclipse.emf.databinding (1.0.0.v200808251517) "EMF Data Binding" [Starting]
Binding" [Starting]
org.eclipse.emf.ecore (2.4.1.v200808251517) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.4.0.v200808251517) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.change.edit (2.4.0.v200808251517) "EMF Change Edit"
[Starting]
org.eclipse.emf.ecore.edit (2.4.1.v200808251517) "EMF Ecore Edit" [Starting]
[Starting]
Data Objects Implementation" [Starting]
org.eclipse.emf.ecore.xmi (2.4.1.v200808251517) "EMF XML/XMI Persistence"
[Active]
org.eclipse.emf.edit (2.4.1.v200808251517) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.4.1.v200808251517) "EMF Edit UI" [Active]
org.eclipse.emf.exporter (2.4.0.v200808251517) "EMF Model Exporter" [Starting]
org.eclipse.emf.importer (2.4.1.v200808251517) "EMF Model Importer" [Starting]
org.eclipse.emf.importer.ecore (2.4.0.v200808251517) "EMF Ecore Importer"
[Starting]
org.eclipse.emf.importer.java (2.4.1.v200808251517) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.4.0.v200808251517) "EMF Rose Importer"
[Starting]
org.eclipse.emf.mapping (2.4.0.v200808251517) "EMF Mapping" [Starting]
[Starting]
Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.4.0.v200808251517) "EMF Ecore to
Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v200808251517) "EMF Ecore
to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.4.0.v200808251517) "EMF Ecore to XML
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.4.0.v200808251517) "EMF Ecore to XML
org.eclipse.emf.mapping.ui (2.4.0.v200808251517) "EMF Mapping UI" [Starting]
org.eclipse.epp.usagedata.gathering (1.0.1.R200809220400) "Usage Data
Gathering Plug-in" [Active]
org.eclipse.epp.usagedata.recording (1.0.1.R200809220400) "Usage Data
Recording Plug-in" [Active]
org.eclipse.epp.usagedata.ui (1.0.1.R200809220400) "Usage Data UI Plug-in"
[Starting]
org.eclipse.equinox.app (1.1.0.v20080421-2006) "Equinox Application
Container" [Active]
org.eclipse.equinox.common (3.4.0.v20080421-2006) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.frameworkadmin (1.0.2.R34x_v20080910) "Equinox Framework
Admin" [Active]
org.eclipse.equinox.frameworkadmin.equinox (1.0.2.R34x_v20080911) "Equinox
Framework Admin for Equinox" [Active]
org.eclipse.equinox.http.jetty (1.1.0.v20080425) "Jetty Http Service" [Active]
org.eclipse.equinox.http.registry (1.0.100.v20080427-0830) "Http Service
Registry Extensions" [Active]
org.eclipse.equinox.http.servlet (1.0.100.v20080427-0830) "Http Services
Servlet" [Active]
org.eclipse.equinox.jsp.jasper (1.0.100.v20080427-0830) "Jasper Jsp Support
Bundle" [Active]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20080427-0830) "Jasper Jsp
Registry Support Plug-in" [Active]
org.eclipse.equinox.launcher (1.0.101.R34x_v20080819) "Equinox Launcher"
[Resolved]
org.eclipse.equinox.launcher.gtk.linux.x86_64 (1.0.101.R34x_v20080731)
"Equinox Launcher Linux X86_64 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.0.2.R34x_v20080808-1156)
"Equinox Provisioning Artifact Repository Support" [Active]
org.eclipse.equinox.p2.console (1.0.0.v20080514-1900) "Equinox Provisioning
Console" [Starting]
org.eclipse.equinox.p2.core (1.0.0.v20080530-1237) "Equinox Provisioning
Core" [Active]
org.eclipse.equinox.p2.director (1.0.2.v20080806-1619) "Equinox Provisioning
Director" [Active]
org.eclipse.equinox.p2.director.app (1.0.1.R34x_v20080729) "Equinox
Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.2.v20080806-1619) "Equinox
Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (1.0.1.R34x_v20080827) "Equinox Provisioning
Engine" [Active]
org.eclipse.equinox.p2.exemplarysetup (1.0.0.v20080427-2136) "Equinox
Provisioning Exemplary Setup" [Active]
org.eclipse.equinox.p2.extensionlocation (1.0.2.R34x_v20080825) "Extension
Location Repository Support" [Active]
org.eclipse.equinox.p2.garbagecollector (1.0.1.R34x_v20080818) "Provisioning
Garbage Collector" [Active]
org.eclipse.equinox.p2.jarprocessor (1.0.0.v20080514-1900) "Equinox
Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (1.0.0.v20080514-1900) "Equinox Provisioning
Metadata" [Active]
org.eclipse.equinox.p2.metadata.generator (1.0.1.R34x_v20080819) "Equinox
Provisioning Metadata Generator" [Active]
org.eclipse.equinox.p2.metadata.repository (1.0.0.v20080604) "Equinox
Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.reconciler.dropins (1.0.2.R34x_v20080909) "Dropin
Reconciler Plug-in" [Active]
org.eclipse.equinox.p2.touchpoint.eclipse (1.0.2.R34x_v20080910) "Equinox
Provisioning Eclipse Touchpoint" [Active]
org.eclipse.equinox.p2.touchpoint.natives (1.0.0.v20080505-1850) "Equinox
Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.ui (1.0.1.R34x_v20080909) "Equinox Provisioning UI
Support" [Active]
org.eclipse.equinox.p2.ui.sdk (1.0.1.R34x_v20080818) "Equinox Provisioning
Platform Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.0.0.v20080427-2136) "Equinox
Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.1.R34x_v20080808-1156) "Update site
repository adapter bundle (Incubation)" [Starting]
org.eclipse.equinox.preferences (3.2.201.R34x_v20080709) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.4.0.v20080516-0950) "Extension Registry
Support" [Active]
org.eclipse.equinox.security (1.0.1.R34x_v20080721) "Equinox Java
Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.0.0.v20080603-1810) "Equinox Security
Default UI" [Starting]
org.eclipse.equinox.simpleconfigurator (1.0.0.v20080604) "Simple
Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (1.0.2.R34x_v20080911)
"Simple Configurator Manipulator" [Active]
org.eclipse.gef (3.4.1.v20080806) "Graphical Editing Framework GEF" [Starting]
org.eclipse.help (3.3.101.v20080702_34x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.300.v20080507) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.101.M20080728_34x) "Help System Base" [Active]
org.eclipse.help.ui (3.3.101.M20080715_34x) "Help System UI" [Active]
org.eclipse.help.webapp (3.3.101.M20080805_34x) "Help System Webapp" [Active]
org.eclipse.jdt (3.4.1.r341_v20080709-0800) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.3.101.R34x_v20080902-1220) "Java Annotation
Processing Core" [Starting]
org.eclipse.jdt.apt.pluggable.core (1.0.100.v20080407-1345) "Java Compiler
Apt IDE" [Starting]
org.eclipse.jdt.apt.ui (3.3.100.v20080407-1345) "Java Annotation Processing
UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.100.v20080513-1235) "Java Compiler Apt"
[Resolved]
org.eclipse.jdt.compiler.tool (1.0.100.v_883_R34x) "Java Compiler Tool
Support" [Resolved]
org.eclipse.jdt.core (3.4.2.v_883_R34x) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.2.0.v20080603-2000) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.4.0.v20080604) "JDI Debug Model" [Starting]
org.eclipse.jdt.debug.ui (3.3.1.v20080730_r341) "JDI Debug UI" [Starting]
org.eclipse.jdt.doc.isv (3.4.1.r341_v20080716-0800) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.4.1.r341_v20080820-0800) "Eclipse Java
development user guide" [Resolved]
org.eclipse.jdt.junit (3.4.0.v20080603-2000) "Java Development Tools JUnit
support" [Starting]
org.eclipse.jdt.junit.runtime (3.3.0.v20080603-2000) "Java Development Tools
JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.200.v20080603-2000) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.4.1.v20080729_r341) "Java Development Tools
Launching Support" [Starting]
org.eclipse.jdt.ui (3.4.1.r341_v20080827-1100) "Java Development Tools UI"
[Active]
org.eclipse.jem (2.0.201.v200806201600) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (2.0.100.v200806051600) "Java EMF Model BeanInfo
(Introspection) Support" [Starting]
org.eclipse.jem.proxy (2.0.100.v200806051600) "Java EMF Model Proxy Support"
[Starting]
org.eclipse.jem.ui (2.0.100.v200806051600) "Java EMF Model UI" [Active]
org.eclipse.jem.util (2.0.100.v200805140020) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (2.0.101.v200807170530) "Java EMF Model Workbench
Support" [Starting]
org.eclipse.jface (3.4.1.M20080827-2000) "JFace" [Active]
org.eclipse.jface.databinding (1.2.1.M20080827-0800a) "JFace Data Binding
for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.4.1.r341_v20080827-1100) "JFace Text" [Resolved]
org.eclipse.jpt.core (2.0.101.v200809020200) "Java Persistence API Tools -
Core" [Starting]
org.eclipse.jpt.db (1.1.2.v200809112059) "Java Persistence API Tools - DB"
[Starting]
org.eclipse.jpt.db.ui (1.0.1.v200805020000) "Java Persistence API Tools - DB
UI" [Resolved]
org.eclipse.jpt.doc.user (1.0.201.v200809020200) "Java Persistence
Documentation - Doc" [Starting]
org.eclipse.jpt.eclipselink.core (1.0.0.v200806050000) "Java Persistence API
Tools - EclipseLink Support - Core" [Starting]
org.eclipse.jpt.eclipselink.core.ddlgen (1.0.0) "Java Persistence API Tools
- EclipseLink Support - DDL Generation" [Resolved]
org.eclipse.jpt.eclipselink.ui (1.0.0.v200805300000) "Java Persistence API
Tools - EclipseLink Support - UI" [Starting]
org.eclipse.jpt.gen (1.1.0.v200805020000) "Java Persistence API Tools -
Entity Gen" [Resolved]
org.eclipse.jpt.ui (2.0.101.v200809030200) "Java Persistence API Tools - UI"
[Starting]
org.eclipse.jpt.utility (1.2.100.v200808060200) "Java Persistence API Tools
- Utility" [Resolved]
org.eclipse.jsch.core (1.1.100.I20080604) "JSch Core" [Active]
org.eclipse.jsch.ui (1.1.100.I20080415) "JSch UI" [Starting]
org.eclipse.jst (1.0.100.v200805140017) "J2EE Standard Tools (JST)" [Resolved]
org.eclipse.jst.common.annotations.controller (1.1.100.v200805140020)
"Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.100.v200805140020) "Annotation
Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.102.v200806010600) "Annotations
org.eclipse.jst.common.frameworks (1.1.200.v200805140020) "Integration
Plug-in" [Starting]
org.eclipse.jst.common.project.facet.core (1.3.1.v200807031821) "Project
Facet Core (Java Support)" [Active]
org.eclipse.jst.common.project.facet.ui (1.3.1.v200807031821) "Project Facet
UI (Java Support)" [Starting]
org.eclipse.jst.ejb.doc.user (1.1.0.v200805152320) "EJB docs" [Starting]
org.eclipse.jst.ejb.ui (1.1.202.v200809040612) "WTP EJB UI Plug-in" [Starting]
| Re: C/C++ Perspective missing ... [message #268202 is a reply to message #268122] |
Thu, 29 January 2009 03:34  |
> [...]/eclipse-jee-ganymede-SR1-linux-gtk-x86_64.tar.gz
You downloaded the "Eclipse IDE for Java EE Developers".
To use the C/C++ perspective, post-install the full CDT feature
(Help->Software Updates->Find & Install->Search for new [...]).
Or download "Eclipse IDE for C/C++ Developers" (eclipse-cpp-*).
Current Time: Thu Nov 20 06:01:55 EST 2025
Powered by FUDForum. Page generated in 0.08952 seconds
