| Sorting crosstab by non-group attribute [message #263253] |
Thu, 13 December 2007 20:02  |
Originally posted by: smithbb+eclipse.gmail.com
Hi All,
I need to sort a crosstab (each level) by an attribute that is not the
group by attribute. I've tried adding an "Attribute" in the group level
edit box, but that doesn't help. (There is no doco on what the
"Attribute(s)" in the group level editor do... any ideas?
Ashley Cambrell
| Re: Sorting crosstab by non-group attribute [message #263491 is a reply to message #263264] |
Tue, 18 December 2007 17:30  |
Sweet, I'll give it a try.
Is that the purpose of the Create Attribute in the Group Level edit dialog?
Thanks Tianli
Ashley Cambrell
Tianli wrote:
> Hi Ashiley
> Please use the latest BIRT2.3.0 build, You can specify a sorting key using
> the expression builder and specify the attribute's expression like
> dimension["Group"]["Level"]["Attr"] as your sorting key.
> Best regards!
> "Ashley Cambrell" <smithbb+eclipse@gmail.com> wrote in message
> news:fjskmg$bn5$1@build.eclipse.org...
>> Hi All,
>> Cheers,
>> Ashley Cambrell
FUDForum. Page generated in 0.04450 seconds
