Re: WB not rendering/painting in IDE [message #1697932 is a reply to message #1462720] |
Tue, 09 June 2015 16:16 |
Martin Rittner Messages: 1 Registered: June 2015 |
Junior Member |
Similar issue, I guess same reason - see attached screenshot: My design renders, but the items do not appear at the correct position (they are all clickable, but further down than displayed). Also, my component tree has only entries with empty labels, which is the most annoying, as I don't know what I am clicking at in the tree... Basically, WindowBuilder is useless, this way.
Could be Gnome, could be the fact that this a very high resolution monitor (see screenshot), and on Linux(es), many programs don't cope with that very well yet, could be both...
Fedora 22, Gnome 3.16.2, Evolution Luna 4.4.2, WindowBuilder 1.8.0
Re: WB not rendering/painting in IDE [message #1701294 is a reply to message #1699647] |
Fri, 10 July 2015 15:44 |
Norbert Skalski Messages: 8 Registered: November 2014 |
Junior Member |
I never got it to work. Nobody seems to care either in the Centos realm or Eclipse. Just consider Eclipse Windowbuilder completely broken with Centos 6.6 and the like.
I am lucky to have a spare workstation that now is the dedicated to running eclipse on windows specifically for building java gui's with windowbuilder.
There is the Mars release of Eclipse which i will try shortly, but most likely this year i will be retiring swing and all these unsupported tools and moving to JavaFX.
EDIT: Tried Eclipse Mars, same issue. Windowbuilder in Eclipse will not render correctly with GNOME running on Centos 6.6. Save yourself some pain, don't even try.
[Updated on: Fri, 10 July 2015 19:10] Report message to a moderator
FUDForum. Page generated in 0.05357 seconds
