Issues with importing processes created in Eclipse BPMN2 Modeler Project [message #1444023] |
Mon, 13 October 2014 14:46 |
Greetings!
I would kindly like to ask the forum to help me understand how to work with an imported BPMN2 File in Stardust.
I am currently performing the following steps:
1. Creating a BPMN diagram in Eclipse BPMN2 Modeler project.
2. Importing the model in Stardust using the "import" option in the Portal.
(Just a FYI: I am just creating the BPMN file and directly importing it)
3. Once I import the model, I try to create some participants and roles.
All goes well till I click the "Deploy" option. Once I try to deploy the model in the Stardust Engine it gives me the following error.
Cannot deploy: Model file name / path not available
When I create a model directly in Stardust Portal's BPMN modeler, I am able to create and deploy the Processes without any issue.
Could you please help me to understand if I am missing some step while importing the models or if there is some compatibility issue that I might not be aware of.
It would be really great if you could point me to some documentation on the same.
Kunal.
FUDForum. Page generated in 0.03790 seconds
