Home » Eclipse Projects » Eclipse Platform » showing progress
showing progress [message #250533] Tue, 08 June 2004 10:58 Go to next message
Originally posted by: pieter.west.NOSPAM.nl
Where can I find some documentation on showing a progress monitor?
I found this:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/documents/plan_concurrency_modal_progress.htm l
But it doesn't help me very much I'm afraid.
Re: showing progress [message #250606 is a reply to message #250533] Tue, 08 June 2004 13:49 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Basically, do what it said. To bring up progress monitor use:
PlatformUI.getWorkbench().getProgressService().busyCursorWhi le(operation);
This call needs to be run from the UI thread. But your operation will be
executed in another thread. All of the shells will be disabled and a
busy cursor will be set. If it takes longer than a certain preset time
(it looks to be hard-coded to 800 ms), then and only then will the
progress monitor dialog come up. That way the user is not bothered with
a dialog for short operations, only for longer ones.
Thanks, Rich Kulp
Re: showing progress [message #250870 is a reply to message #250606] Wed, 09 June 2004 06:07 Go to previous messageGo to next message
Vut what exactly is "operation" ??
Re: showing progress [message #250894 is a reply to message #250870] Wed, 09 June 2004 07:53 Go to previous message
As the javadoc or the source easily tells you:
IRunnableWithProgress
Previous Topic:message to view
Next Topic:Eclipse Help Contents - Internal Server error
Current Time: Tue Nov 04 18:12:15 EST 2025
Powered by FUDForum. Page generated in 0.04532 seconds
