Home » Archived » Koneki » Autocompletion for external API
Autocompletion for external API [message #1417005] |
Sun, 03 November 2013 07:28 |
Hi there,
Let's say I want to add documentation to an external dynamic library such as http://keplerproject.github.io/luafilesystem/, in order to get a autocomplete feature over http://keplerproject.github.io/luafilesystem/manual.html#reference. Right now, I'm pretty sure it's impossible to link a source package like it can be done in java, since usually these external library that aren't .lua are wrote in C.
So, if the programmer really want to get autocompletion for this, he can either try to:
-Create a class with documentation that somehow "mock/mimic" the external library(but when running the program, he switch to the real library).
-Create somekind of an adapter class with documentation where he simply recall the original library for each field and function.
So far, I guess that Koneki has probably some other priorities, but I was wondering if there could be something to be done here.
I mean, once we use the "require" statement for an external library, it's possible to detect a new table/module on _G. Then, it's usually possible to detect wether the "top element" inside the said component is a function/variable/userdata with his related name. Here's a piece of code that show what I mean(borrow from http://lua-users.org/wiki/TableSerialization : "Universal tostring"):
function table_print (tt, indent, done)
done = done or {}
indent = indent or 0
if type(tt) == "table" then
local sb = {}
for key, value in pairs (tt) do
table.insert(sb, string.rep (" ", indent)) -- indent it
if type (value) == "table" and not done [value] then
done [value] = true
table.insert(sb, "{\n");
table.insert(sb, table_print (value, indent + 2, done))
table.insert(sb, "}\n");
elseif "number" == type(key) then
table.insert(sb, string.format("\"%s\"\n", tostring(value)))
else
"%s = \"%s\"\n", tostring (key), tostring(value)))
end
end
return table.concat(sb)
else
return tt .. "\n"
end
end
function to_string( tbl )
if "nil" == type( tbl ) then
return tostring(nil)
elseif "table" == type( tbl ) then
return table_print(tbl)
elseif "string" == type( tbl ) then
return tbl
else
return tostring(tbl)
end
end
So my question, would it be possible to add autocomplete for a dynamic library(.dll on windows or .so on unix)?
Thanks again,
Btw, I've compilled 1.1_M2 with maven3 for testing this http://www.eclipse.org/forums/index.php/t/528888/ and it seem to work great now, as long as we respect the luadoc nomenclature :)
Re: Autocompletion for external API [message #1417014 is a reply to message #1417006] |
Fri, 22 November 2013 15:56 |
Simon Bernard wrote on Wed, 06 November 2013 12:42
> A solution for your problem, could be to create a mock file with the API written with the documentation language, to package it in a zip file and to add it to the sourcepath/buildpath
> (right on your project/ Build Path / add External Archives)
> In this case, the file will be not used at runtime and you don't need to implement adapter or to switch manualy.
In Koneki 1.1_M2, I could go in build path > source > Add Folder and this new folder path could be used as source for the autocompletion when using require statement. No need to zip those(which is very useful, so I can add these external API on the go, without zipping/unzipping for every change). Also, at the time, the buildpath wasn't added in package.path variable.
Now I recently made a check out of the "master" branch and all these path are added in package.path variable when I execute a lua script and there no way to exclude them of this variable or to uncheck them in "Order and Export" :x
Furthermore, in "Libaries" > "Add Library..." > "Lua User Libraries", I get the following exception:
Plug-in org.eclipse.koneki.ldt.ui was unable to load class org.eclipse.dltk.internal.ui.internal.wizards.buildpath.UserLibraryWizardPage.
org.eclipse.dltk.internal.ui.internal.wizards.buildpath.UserLibraryWizardPage cannot be found by org.eclipse.koneki.ldt.ui_1.1.0.201311012011
Since this wasn't a official release, I know these kind of error can be expected, so I just wanted to let you know about this :)
Current Time: Thu May 02 08:40:26 GMT 2024
Powered by FUDForum. Page generated in 0.04295 seconds
