Home » Eclipse Projects » Eclipse Platform » What happened to the JFace content-assist lightbulb decoration in M8?
What happened to the JFace content-assist lightbulb decoration in M8? [message #250520] Tue, 08 June 2004 10:34 Go to next message
Hi all,
I have built a non-IDE application that uses the new content assist API in
JFace.
In M8 when a Text widget had content assist 'installed' a little lightbulb
decoration would appear just to the left of the Text widget.
My users miss the lightbulb (this is because content assist is not always
available, it depends on if there is a product catalog available for the
vendor that they are using). If the lightbulb showed up then that indicated
that assistance was available and they would go right to that field and use
the content assistance instead of grabbing a catalog off the shelf.
Anyway, in M9 this decoration no longer shows up and I haven't been able to
figure out what happened to it.
Can anybody tell me if it is still possible to get that decoration to show
up when using content assist?
TIA,
ted stockwell
Re: What happened to the JFace content-assist lightbulb decoration in M8? [message #250566 is a reply to message #250520] Tue, 08 June 2004 12:13 Go to previous messageGo to next message
Go to Preferences->Java->Editor and check "Light bulb for quick assists"
- Jeff
ted stockwell wrote:
> Hi all,
> JFace.
> TIA,
> ted stockwell
Re: What happened to the JFace content-assist lightbulb decoration in M8? [message #250570 is a reply to message #250566] Tue, 08 June 2004 12:15 Go to previous messageGo to next message
Er, looks like I was a bit quick to reply. Perhaps you should look at
how the Java editor is using this preference setting. Maybe it is
similar to what is needed for your custom editor.
- Jeff
> - Jeff
>> Hi all,
>> API in
>> JFace.
>> lightbulb
>> indicated
>> and use
>> able to
>> show
>> TIA,
>> ted stockwell
Re: What happened to the JFace content-assist lightbulb decoration in M8? [message #250574 is a reply to message #250570] Tue, 08 June 2004 12:22 Go to previous message
Yes, that's puts me on the right trail, thanks...
"Jeff Myers" <myersj@nospam.us.ibm.com> wrote in message
news:ca4o9d$k2h$3@eclipse.org...
> - Jeff
> > - Jeff
Previous Topic:Appending a newline to a Document
Next Topic:CVS Help
Current Time: Wed Nov 12 20:29:09 EST 2025
Powered by FUDForum. Page generated in 0.04774 seconds
