Re: Several questions about LDT [message #1416682 is a reply to message #1416679] |
Thu, 04 October 2012 13:34 |
Simon Bernard Messages: 345 Registered: July 2009 |
Hi Denis,
I have some precision/correction about your problems :
1) We currently (v0.8.x) don't support UTF8 encoding, we only support ascii (one byte character exactly).
2) As you found by yourself, all problems about syntax coloring, variables highlighting and folding come from non ascii character in your source file. If you want to follow this problem, a https://bugs.eclipse.org/bugs/show_bug.cgi?id=376304 is opened.
As you could see, it's a serious problem and we https://bugs.eclipse.org/bugs/show_bug.cgi?id=384932 to fix it for the v0.9.0, but we did not found a good solution for now.
Your proposition is interesting but this means if there are non ascii character in code, outline content-assist and documentation will contains "?" char instead of the right one :/.
If we don't find a better solution, this could be the lesser evil.
Thx denis for your feedback and the code you post.
Re: Several questions about LDT [message #1416717 is a reply to message #1416716] |
Thu, 18 October 2012 21:43 |
Denis Artemov wrote on Thu, 18 October 2012 21:23
> The highliting bug gone after updating of LDT from repository. Thanks! :)
Excellent! :)
Please keep on sharing your experience with LDT, and feel free to discuss enhancement requests or bugs along the way
Benjamin
FUDForum. Page generated in 0.04136 seconds
