Home » Archived » Koneki » Problem Starting Koneki with DM-Server 3.6
Problem Starting Koneki with DM-Server 3.6 [message #1416533] |
Tue, 24 July 2012 14:59 |
Andre Tomas Messages: 28 Registered: July 2012 |
Junior Member |
Hello. I'm kinda new to this world, i'm trying to setup the funambol dm-server 3.6 and Koneki. I've followed this guide to install and setup both Koneki and DM-Server:
http://wiki.eclipse.org/Koneki/Simulators/OMA-DM/User_Guide
I'm on opensuse 11.4, every Ambient variable are set to the right place, i can install the jboss5 and set up the data base without any problem.
The DM-Server starts up just fine (at least i guess), after that i create a new ID to use and try to connect via Koneki and then i get the following exception:
15:51:17,058 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
15:51:17,086 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
15:51:17,183 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
15:51:17,619 ERROR [STDERR] org.jibx.runtime.JiBXException: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
15:51:17,620 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalElement(UnmarshallingContext.java:2565)
15:51:17,620 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalDocument(UnmarshallingContext.java:2736)
15:51:17,620 ERROR [STDERR] at com.funambol.server.engine.SyncAdapter.processMessage(SyncAdapter.java:287)
15:51:17,620 ERROR [STDERR] at com.funambol.server.syncbean.SyncBean.processMessage(SyncBean.java:228)
15:51:17,620 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
15:51:17,620 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
15:51:17,620 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
15:51:17,620 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
15:51:17,621 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
15:51:17,621 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
15:51:17,621 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
15:51:17,621 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_1852690398.invoke(InvocationContextInterceptor_z_fillMethod_1852690398.java)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
15:51:17,622 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_1852690398.invoke(InvocationContextInterceptor_z_setup_1852690398.java)
15:51:17,622 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.entity.ExtendedPersistenceContextPropagationInterceptor.invoke(ExtendedPersistenceContextPropagationInterceptor.java:60)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.stateful.StatefulInstanceInterceptor.invoke(StatefulInstanceInterceptor.java:81)
15:51:17,622 ERROR [STDERR] at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79)
15:51:17,622 ERROR [STDERR] at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:190)
15:51:17,623 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
15:51:17,623 ERROR [STDERR] at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:186)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
15:51:17,623 ERROR [STDERR] at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:176)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:216)
15:51:17,624 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:207)
15:51:17,624 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:164)
15:51:17,624 ERROR [STDERR] at $Proxy266.processMessage(Unknown Source)
15:51:17,624 ERROR [STDERR] at com.funambol.transport.http.server.LocalEJBSyncHolder.processMessage(LocalEJBSyncHolder.java:88)
15:51:17,624 ERROR [STDERR] at com.funambol.transport.http.server.Sync4jServlet.doPost(Sync4jServlet.java:250)
15:51:17,624 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
15:51:17,624 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
15:51:17,624 ERROR [STDERR] at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
15:51:17,624 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
15:51:17,625 ERROR [STDERR] at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
15:51:17,625 ERROR [STDERR] at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
15:51:17,625 ERROR [STDERR] at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
15:51:17,625 ERROR [STDERR] at java.lang.Thread.run(Thread.java:662)
15:51:17,625 FATAL [SyncAdapter] Error unmarshalling message: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
15:51:17,647 ERROR [[SyncServerServlet]] Servlet.service() for servlet SyncServerServlet threw exception
I'm Doing something wrong? i've look to the guide number of times and i don't understand ehat i may be doing wrong...
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416612 is a reply to message #1416533] |
Mon, 27 August 2012 21:08 |
Brandon F Messages: 14 Registered: August 2012 |
Junior Member |
I have exactly the same issue as Andre. Installation of JBoss, Koneki and Funambol worked fine, I can access the Funambol and JBoss web interface, the devices I create get stored in the database.
But when I want to connect with Koneki, the following happens:
Koneki shows an alert with "HTTP/1.1 500 Internal Server Error" and I get the same error log as Andre:
22:54:36,133 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,137 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,171 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,172 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,389 ERROR [STDERR] org.jibx.runtime.JiBXException: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
22:54:36,390 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalElement(UnmarshallingContext.java:2565)
22:54:36,390 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalDocument(UnmarshallingContext.java:2736)
22:54:36,390 ERROR [STDERR] at com.funambol.server.engine.SyncAdapter.processMessage(SyncAdapter.java:287)
22:54:36,391 ERROR [STDERR] at com.funambol.server.syncbean.SyncBean.processMessage(SyncBean.java:228)
22:54:36,391 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
22:54:36,391 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
22:54:36,391 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
22:54:36,391 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:616)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_10922545.invoke(InvocationContextInterceptor_z_fillMethod_10922545.java)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
22:54:36,398 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_10922545.invoke(InvocationContextInterceptor_z_setup_10922545.java)
22:54:36,398 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.entity.ExtendedPersistenceContextPropagationInterceptor.invoke(ExtendedPersistenceContextPropagationInterceptor.java:60)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
22:54:36,399 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.stateful.StatefulInstanceInterceptor.invoke(StatefulInstanceInterceptor.java:81)
22:54:36,399 ERROR [STDERR] at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79)
22:54:36,399 ERROR [STDERR] at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:190)
22:54:36,399 ERROR [STDERR] at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:186)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
22:54:36,405 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,405 ERROR [STDERR] at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
22:54:36,406 ERROR [STDERR] at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
22:54:36,406 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:176)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:216)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:207)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:164)
22:54:36,406 ERROR [STDERR] at $Proxy266.processMessage(Unknown Source)
22:54:36,406 ERROR [STDERR] at com.funambol.transport.http.server.LocalEJBSyncHolder.processMessage(LocalEJBSyncHolder.java:88)
22:54:36,406 ERROR [STDERR] at com.funambol.transport.http.server.Sync4jServlet.doPost(Sync4jServlet.java:250)
22:54:36,406 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
22:54:36,406 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
22:54:36,406 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
22:54:36,406 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
22:54:36,406 ERROR [STDERR] at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
22:54:36,407 ERROR [STDERR] at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
22:54:36,407 ERROR [STDERR] at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
22:54:36,407 ERROR [STDERR] at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
22:54:36,408 ERROR [STDERR] at java.lang.Thread.run(Thread.java:636)
22:54:36,408 FATAL [SyncAdapter] Error unmarshalling message: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
22:54:36,425 ERROR [[SyncServerServlet]] Servlet.service() for servlet SyncServerServlet threw exception
Any ideas? Are there any Funambol servers out there which are open to use? This way I could at least check if my Koneki is working correctly.
Thanks in advance,
Brandon
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416640 is a reply to message #1416639] |
Tue, 04 September 2012 16:35 |
Unfortunately I don't use the Funambol server on a daily basis... I hope Brandon can help you here... It seems that for him switching from Debian to Ubuntu did the trick ; maybe he can provide you with more accurate information on what needs to be put on the Ubuntu box... :?
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416644 is a reply to message #1416643] |
Wed, 05 September 2012 11:33 |
Wow, great work Brandon thanks so much!
I think that pieces of this should probably be used to update the documentation on the wiki. We should try to do that when Andre will have figured out what was wrong on his installation.
BTW Brandon you can subscribe to the topic to get e-mail notifications when a new post arrives!
Benjamin.
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416645 is a reply to message #1416644] |
Wed, 05 September 2012 16:30 |
Junior Member |
Hello, and thank you Brandon for your excellent post explaining every step of the way. But i'm out of luck for shore :( I tried exactly as u wrote, step by step, using the same components in the same version. The OS is exactly the same, the virtual machine is VirtualBox 4.1.20 (can't be that), the java version is also the same installed trough apt-get aswell. The eclipse was installed via apt-get as well... Alcomponents are inside the virtual machine, altho the host syste is on 64bits, but the vm i insalled is the 32bit one. Everything "by the book" and still got that error message saying it has no unmarshaller for element {SYNCML:SYNCML1.2}SYNCML :S.
I'm so frustrated right now..
I don't understand much yet about unmarshaller elements, but i think they have to be in one specific document, is it possible that need document is missing from my installation by any reason?
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416646 is a reply to message #1416533] |
Wed, 05 September 2012 18:34 |
Junior Member |
Hey,
I'm actually out of ideas now.
I uploaded my dm-server folder, my .profile file and an overview over all installed packages here:
h*tp://netload.in/datei934otcRlvI/dm-server.tar.bz2.htm
Unzip it with the command "tar xfvj dm-server.tar.bz2" if there is no GUI tool for that. You can create a list of all installed packages with "dpkg -l > packages.txt".
Remember to edit the .profile file and the file dm-server/install.properties. Maybe you should just copy all the files to the folder /home/USERNAME/funambol/Funambol.
So this folder should contain:
- the folder "dm-server" copied from my archieve
- the folder "jboss-5.1.0.GA", maybe you should download it again (remember, the -SDK version)
- the file "postgresql-9.1.902.jdbc3.jar"
Then you just have to edit the .profile and the dm-server/install.properties the way that you overwrite the word "USER" with your username. And maybe doublecheck the database account.
Oh and maybe you should check the rights on all the files and folders. If you don't care about the rights, I think a "chmod -R 777" on the folder funambol would definetely be worth a try!
When you did all of this and it won't work, I really have no clue how to help. If you have any ideas what you would like to check, let me know. My last idea would be a complete image of my VM, but this would be several gigabyte and with my internet connection it would take forever to upload.
Best of luck,
Brandon
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416933 is a reply to message #1416834] |
Fri, 05 July 2013 12:40 |
Attila Heidrich Messages: 4 Registered: July 2013 |
Junior Member |
We experience the same problem here as the others.
dm-server looks good, but the when connecting /funambol/dm we have the same error message.
The system is Ubuntu 13.04, I have tried Funambol versions:
3.5.1, bundled with hsql, java and jboss 3.2, no distribution-dependent component at all.
3.6 with jboss 4.1, and Sun Java 1.7
3.7 with tomcat7 and openjdk7
the result is the same for all... /dmdemo works fine, but /funambol/dm drops the "unsupported method" message.
Anyway, what should happen if I just open a browser and point to ht2p://localhost:8080/funambol/dm ?? 'cos now the error happens, but the guys developing the client reports the same error when connecting with the sample koneki client as well!
Current Time: Thu May 02 00:00:21 GMT 2024
Powered by FUDForum. Page generated in 0.06410 seconds
