Keep debugger running [message #1416517] |
Sun, 15 July 2012 20:32 |
uiy uiy Messages: 56 Registered: May 2012 |
Member |
Every time I want to debug I first have to select the debug configuration(click the "bug" button then select the debug configuration I've created) then select the run configuration(little green "play" button).
After I debug a process I have to repeat the process. Is there any way to keep the debugger running without having to restart it? (or basically have it automatically restart and wait for input after a previous termination?)
This process is somewhat time consuming because I am debugging lualatex code which requires me to switch between windows. Also if I forget to start the debugger and have time consuming lualatex code I'll have to wait a few minutes to realize that. Keeping the debugger always "available" is the best way to solve that problem. is it possible?
FUDForum. Page generated in 0.03326 seconds
