Re: I want customize code [message #1416527 is a reply to message #1416522] |
Mon, 16 July 2012 20:00 |
I am not sure what you are trying to do ;)
First of all, the location from which you should trigger the build is the top level folder, the one that contains features/, plugins/, etc folder
If you follow the instructions to build a standalone product that are available http://wiki.eclipse.org/Koneki/LDT/Tutorials/Building_LDT_from_source, you will end with zipped ready-to-use LDT products in product/target/products/ folder.
The product/target/repository/ folder is an update site that you can use to upgrade an existing LDT install.
What you are trying to do by renaming the produced JARs and stuff is definitely not a good idea and it is very unlikely that it'll work! ;)
Keep us posted!
Ben
FUDForum. Page generated in 0.03782 seconds
