Re: Gideros Code Assist [message #1416731 is a reply to message #1416725] |
Mon, 05 November 2012 17:44 |
Marc Aubry Messages: 76 Registered: July 2009 |
Member |
Hi Hilman,
This is a better thread to talk about Gideros :)
Some points:
*Be sure you have correctly add the EE to your current project, when the EE is added, you it appear in the script explorer as a node under the project.
* To be able to browse code, be sure to use the a global variable of the module name.
for example, with the lua 5.1 EE, if I type :
string.lower("HELLO")
I can open the lower or string declaration because the EE contain a "string.lua" file with a "lower" method.
* the explicit version: require the module as following:
local myvar = require "string"
myvar.lower("HELLO")
To have a outline, with more than first level variable, use Lua Documentation Language to document your code as explain http://wiki.eclipse.org/Koneki/LDT/User_Area/Documentation_Language.
If is still not working, please tell us with more detail want to try to do.
Marc
FUDForum. Page generated in 0.02976 seconds
