Re: Koneki doesn't open lua scripts in RH Linux [message #1416471 is a reply to message #1416467] |
Mon, 04 June 2012 15:54 |
Hello Avinash, and thanks for the report.
This is weird, we just tested on an Ubuntu x64 and it works well.
Assuming you have managed to compile liblua5.1.so and libjnlua5.1.so correctly, and it seems you did ;) then maybe what went wrong is how you replaced these 2 files in the JNLua linux64 JAR file.
You should start eclipse with the "-clean" option after having replaced the files; so as the OSGi cache for this bundle gets refreshed.
On a side note, you seem to be running an old version of LDT (201201241319), it would probably do no harm to try with a more recent version, just in case :)
Keep us posted, there's definitely something look weird here!
Re: Koneki doesn't open lua scripts in RH Linux [message #1416476 is a reply to message #1416475] |
Wed, 06 June 2012 15:27 |
Do you have the exact same weird "GLIBC_2.7 not found" issue with the updated .so's?
WRT the "old" version of LDT, I assume you have downloaded the standalone RCP product, right? In order to get the up-to-date version you'd need to update it (Help > Check for updates). Actually it should even have updated itself automatically, but maybe the PC you're using LDT on is not connected to the internet (or behind a proxy, which you would thus need to configure in the preferences).
The version we serve on the website is still the "old" one for the reason it is quite a PITA to produce a newer one, and the old one gets updated anyway.
Benjamin
FUDForum. Page generated in 0.04526 seconds
