Re: ldt under ubuntu 12.04 64bit not running [message #1416460] |
Mon, 21 May 2012 10:18 |
Volker Scheffold wrote on Mon, 21 May 2012 12:15
> Hi Benjamin,
> But, am I right, I have first to start the debugger with lua -e "require('debugger')();" from the commandline, then I can use it in eclipse?
Nope it is the other way around!
You first have to launch the debug config in Eclipse, it opens a debugging server and the script you later launch from the command line then connects to it!
If you feel it needs clarification in the documentation on the Wiki, feel free to update accordingly... :)
Re: ldt under ubuntu 12.04 64bit not running [message #1416461 is a reply to message #1416460] |
Mon, 21 May 2012 10:26 |
One more thing, you should make sure to actually append the name of the script you want to debug, on your commandline ; for example:
lua -e "require('debugger')();" MyApp.lua
According to your previous messages, I am not sure you did that, and this might explain a few things :)
Cheers!
FUDForum. Page generated in 0.04298 seconds
