Re: Requirement-Diff [message #1404262 is a reply to message #1404210] |
Wed, 30 July 2014 17:49 |
Hi Peter,
> do you have plans to implement a diff-view for different Versions of the same reqif file?
Yes. In fact, we implemented it and wrote about it at http://www.formalmind.com/en/blog/comparing-reqif-files-pror-essentials-diff
Having said that, the version described in the blog only works up to ProR 0.9.0, as it is based on a very old EMF Compare version.
We're developing a new version, based on EMF Compare 3. While it has not yet been announced officially, it is part of the latest formalmind Studio (http://www.formalmind.com/studio). Be warned, it works, but the diff view is not very user-friendly yet. If you find issues, please provide feedback via https://formalmind.zendesk.com/
Best,
- Michael
Re: Requirement-Diff [message #1701501 is a reply to message #1701441] |
Mon, 13 July 2015 18:14 |
Hi Aidan,
When you are in the Navigator View or Project View (not the Event-B Explorer), select the files you would like to compare and select "Compare With" from the context menu. There should be two options: "ReqIF Compare" and "Each other". Be sure to select "ReqIF Compare".
Please note that we are working on a commercial ReqIF compare component that will be a huge improvement over the status quo. Please sign up to our newsletter if you would like to get informed when it's available.
Best,
- Michael
Re: Requirement-Diff [message #1722867 is a reply to message #1722429] |
Tue, 09 February 2016 19:58 |
Hi Axel Thor,
Actually, I think you should have it installed, but the documentation is outdated. "Each other" should do the job.
To be on the save side, please check in the preferences at EMF Compare | Engines: There, you should the the customized Match- and Diff-Engines.
Best,
- Michael
Re: Requirement-Diff [message #1724423 is a reply to message #1724354] |
Tue, 23 February 2016 20:09 |
Hi Axel,
> We are putting some effort in using ProR for our requirement engineering work and this is one of the things that would be really good if would work properly.
I agree, it's a crucial feature. Sorry for putting on my commercial hat now: But that's exactly why we developed Binom, a commercial Diff component: http://formalmind.com/en/binom
We have not officially released it, but I can send you a trial license for the beta version. If you are interested, send me an email (michael.jastram@formalmind.com).
Best, Michael
Re: Requirement-Diff [message #1724611 is a reply to message #1724587] |
Wed, 24 February 2016 21:09 |
Hi Axel,
> But regarding the issue above, isn't ProR suppose to have some kind of free diff viewer available? I would guess that the exception is not supposed to be thrown right?
The short answer is: building a robust, scalable diff is extremely difficult.
The long answer: We underestimated the effort initially, but still created a free, working diff. However, it had a number of issues and did not scale well. Then EMF Compare evolved and got better, but without backward compatibility. Even minor version changes in EMF Compare that were not supposed to be incompatible were incompatible.
That's why we started to develop Binom. It took quite a bit of effort for a small company like ours, which is the reason why we cannot offer it for free.
FUDForum. Page generated in 0.04358 seconds
