XWT Table DataBinding [message #1387592] |
Wed, 25 June 2014 09:48 |
Sascha Hanke Messages: 21 Registered: April 2014 Location: Germany |
Junior Member |
Hello there,
I have a problem with XWT databinding. I got my XWT table and a list as an input. I got my columns displayed but it wont show me content. The Eclipse console says:
!ENTRY org.eclipse.core.databinding 2 0 2014-06-25 11:39:22.228
!MESSAGE elementType cannot be null
What can I do to fix this?
My classes :
<Composite xmlns="http://www.eclipse.org/xwt/presentation" xmlns:x="http://www.eclipse.org/xwt" x:Class="de.datec.kassenbuch.ui.xwt.DetailPartXwt" xmlns:p1="clr-namespace:org.eclipse.jface.viewers"
xmlns:p2="clr-namespace:de.datec.kassenbuch.ui.table">
<Composite.layout>
<FillLayout/>
</Composite.layout>
<TableViewer x:Style="BORDER | FULL_SELECTION" input="{Binding path=buchungen}">
<TableViewer.table headerVisible="true" linesVisible="true"/>
<TableViewer.columns headerVisible="true">
<TableViewerColumn width="50" text="ID" bindingPath="id">
<TableViewerColumn.labelProvider>
<p2:IdColumnLabelProvider/>
</TableViewerColumn.labelProvider>
</TableViewerColumn>
<TableViewerColumn width="440" text="Datum" bindingPath="datum">
<p2:DateColumnLabelProvider/>
<TableViewerColumn width="440" text="Betrag" bindingPath="betrag">
<p2:AmountColumnLabelProvider/>
<TableViewerColumn width="400" text="Einnahme / Ausgabe" bindingPath="ausgabe">
<p2:TakeGiveColumnLabelProvider/>
</TableViewer.columns>
</TableViewer>
</Composite>
public DetailPartXwt(Composite parent, int style, Object object) {
super(parent, style);
setLayout(new FillLayout());
// load XWT
String name = DetailPartXwt.class.getSimpleName()
+ IConstants.XWT_EXTENSION_SUFFIX;
try {
URL url = DetailPartXwt.class.getResource(name);
Map<String, Object> options = new HashMap<String, Object>();
TableModel model = new TableModel();
options.put(IXWTLoader.DATACONTEXT_PROPERTY, model);
options.put(IXWTLoader.CLASS_PROPERTY, this);
options.put(IXWTLoader.CONTAINER_PROPERTY, this);
XWT.setLoadingContext(new DefaultLoadingContext(this.getClass()
.getClassLoader()));
XWT.loadWithOptions(url, options);
} catch (Throwable e) {
throw new Error("Unable to load " + name, e);
public class TableModel {
@Inject IDataService dataService;
List<KassenBuchungReduced> buchungen = new ArrayList<KassenBuchungReduced>(); {
KassenBuchungReduced test = new KassenBuchungReduced(1, new Date(120,2,2), 350, false);
public List<KassenBuchungReduced> getBuchungen() {
return buchungen;
public void setBuchungen(List<KassenBuchungReduced> buchungen) {
this.buchungen = buchungen;
Re: XWT Table DataBinding [message #1393292 is a reply to message #1392395] |
Thu, 03 July 2014 15:06 |
Junior Member |
now I got a new problem. I've read http://erdalkaracade.blogspot.de/2013/07/eclipse-e4-emf-and-xwt-in-action.htmland I want to export the selection from my table I made with xwt and use it in another part, just like you did.
When I use
<Composite.Resources>
<Var x:Name="booking" varName="selectedBuchung"/>
</Composite.Resources>
I get the following error :
!ENTRY org.eclipse.e4.ui.workbench 4 0 2014-07-03 17:02:02.612
!MESSAGE Unable to create class 'de.datec.kassenbuch.ui.view.MoreDetailView' from bundle '126'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.Error: Unable to load MoreDetailPartXwt.xwt
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1147)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:65)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4688)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:101)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:62)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:581)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1038)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:162)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.Error: Unable to load MoreDetailPartXwt.xwt
at de.datec.kassenbuch.ui.xwt.MoreDetailPartXwt.<init>(MoreDetailPartXwt.java:45)
at de.datec.kassenbuch.ui.view.MoreDetailView.postConstruct(MoreDetailView.java:50)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 82 more
Caused by: org.eclipse.xwt.XWTException: Type Var is not found.
at org.eclipse.xwt.XWTLoader.getMetaclass(XWTLoader.java:1151)
at org.eclipse.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:434)
at org.eclipse.xwt.javabean.ResourceLoader.applyStyles(ResourceLoader.java:872)
at org.eclipse.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:654)
at org.eclipse.xwt.javabean.ResourceLoader.createUIElement(ResourceLoader.java:366)
at org.eclipse.xwt.internal.core.Core.createCLRElement(Core.java:625)
at org.eclipse.xwt.internal.core.Core.load(Core.java:754)
at org.eclipse.xwt.internal.core.Core.load(Core.java:655)
at org.eclipse.xwt.XWTLoader.loadWithOptions(XWTLoader.java:1072)
at org.eclipse.xwt.XWT.loadWithOptions(XWT.java:623)
at de.datec.kassenbuch.ui.xwt.MoreDetailPartXwt.<init>(MoreDetailPartXwt.java:39)
... 88 more
Has the name changed? Or the whole way to do this?
When I do the e4 Inject/Optional/Named("selectedBuchung") thing, the object i get is null.
@Inject @Optional @Named("selectedBuchung")
private Object modelElement;
Greeting Sascha
[Updated on: Thu, 03 July 2014 15:06] Report message to a moderator
Re: XWT Table DataBinding [message #1395275 is a reply to message #1393292] |
Sun, 06 July 2014 17:30 |
Erdal Karaca Messages: 854 Registered: July 2009 |
Hi Sascha,
The E4 integration using the Var/Export mechanism was a proposal.
Up to now, no feedback from the community, so it did not make into the final release.
You can check out the sources into your workspace and build it yourself, for now:
git: http://git.eclipse.org/c/xwt/org.eclipse.xwt.git/tree/org.eclipse.xwt.e4
If you want this feature to be integrated into XWT itself, please file a new enhancement request.
And please do not hijack existing forum posts for different issues
Sascha Hanke wrote on Thu, 03 July 2014 17:06Hello,
When I use
!STACK 0
... 82 more
... 88 more
Greeting Sascha
FUDForum. Page generated in 0.04080 seconds
