Why using new model instead of using the model generated by xsd file [message #1339263] |
Wed, 07 May 2014 15:48 |
becks m Messages: 59 Registered: June 2012 |
Member |
Did you make a new model manually instead of using the one generated by EMF from the xsd file ?
I noticed that you have a converter to convert the model generated from xsd filel to your model ..... am I right ?
if im right,, why did u do this ? is it only for model clarity as I see that the generated model by EMF from xsd lacks the hierarchy.. there's no inheritance in it.
[Updated on: Wed, 07 May 2014 15:54] Report message to a moderator
Re: Why using new model instead of using the model generated by xsd file [message #1352228 is a reply to message #1341058] |
Tue, 13 May 2014 11:07 |
Hello Becks,
> Is there a CMOF file for RIF ?
I am sure there is somewhere, but I couldn't find it online any more. Before the OMG got in charge, RIF was in the hands of ProSTEP and HIS (Herstellerinitiative Software). But they don't seem to have materials online any more.
Also, you could look whether it's stored in the RMF repository in the respective projects.
I hope that helps for now - I don't have the time to dig deeper, unfortunately. Good luck,
- Michael
FUDForum. Page generated in 0.03601 seconds
