Re: Linking between two reqif files [message #1268277 is a reply to message #1267708] |
Mon, 10 March 2014 09:38 |
Hello Frank,
> My question: Is it possible to link from the lower level ReqIF files to the high level ReqIF file using ProR/RMF?
The standard supports this. However, we did not spend time yet on properly implementing this. As we use EMF, things *seem* to work. But this is just the default EMF magic doing its thing, which is the reason why things fail down the road.
This is currently relatively low on our todo list, to be honest with you. Nevertheless, you can indicate your interest in this topic by voting on this item:
https://formalmind.zendesk.com/entries/26725251-Allow-cross-Reqif-File-linking
If you have interest in helping with the implementation, then let me know.
- Michael
FUDForum. Page generated in 0.03652 seconds
