Stardust 1.1 logon error [message #1250060] |
Tue, 18 February 2014 22:46 |
Gudrun Koko Messages: 20 Registered: January 2013 |
The following error is displayed upon first logon to Stardust 1.1.0 portal.
"The requested resource (/ipp-portal-9.9.9-SNAPSHOT/shell/desktop-index.html) is not available." Checking source retrieved shows that directory ./ui.web/orion-client/resources/META-INF/webapp/shell contains no .html file only a nls directory.
Need help. Has anyone encountered this error ?
.war file generation was completed successfully before for Stardust 1.0.0. However for 1.1.0 it runs into the above logon error. Yet I used git clone commands from Eclipse site but followed up with a git checkout for -b v1.1.0.20131218-0839-R in order to zero in on a stable release. In addition once source was generated for archetype tc7-ipp-portal-war and a .war file packaged, mySQL config changes were made by un-jaring the .war file and making relevant changes. MySQL schema was created using sysconsole. Build used the sysconsole-client archetype. Stardust 1.1.0 war file was successfully deployed according to tomcat log. For now deployed to tomcat 6 however.
OS used RH 6.5.
[Updated on: Wed, 19 February 2014 16:20] Report message to a moderator
FUDForum. Page generated in 0.02447 seconds
