Re: Configuration artifacts management [message #1247958 is a reply to message #1246117] |
Sun, 16 February 2014 20:36 |
There are indeed already verbs available for this. They aren't documented as we just expose the MBeans from configAdmin over HTTP. You should have a look at the documentation for configAdmins JMX support and the current API calls being made by the admin console.
Also, when you make changes to the UI you should make it clear that changes will not be persisted across restarts. Adding support for changing config should be pretty straight forward and only require changes to the admin console but making those changes persist across restarts would require a lot more work.
Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
FUDForum. Page generated in 0.04192 seconds
