Code Recommenders build errors - Extenders [message #1226989] |
Fri, 03 January 2014 08:29 |
Aman Singh Messages: 1 Registered: July 2012 |
Junior Member |
I'm trying to build code recommenders plugin from the source using maven build tool.
After importing the projects I'm getting these errors.
Some package declaration errors(screen shot attached). Package declaration in some classes are changed automatically. Am I supposed to rectify them ? or there's any mistake in my project import.
I tried to update projects through : maven > update projects (f5) and again got errors. Cleaning the projects also produce build errors.
Also I'm getting this error in repository-resources/pom.xml file :
maven-enforcer-plugin (goal "enforce") is ignored by m2e.
Plugin execution not covered by lifecycle configuration: org(dot)apache(dot)maven(dot)plugins:maven-remote-resources-plugin:1.5:bundle (execution: bundle-repository-resources, phase: generate-resources)
I would be thankful if someone could suggest a brief overview on how to get started with the projects. In what direction I should work to understand the code.
thanks !
Aman
FUDForum. Page generated in 0.03106 seconds
