Home » Language IDEs » ServerTools (WTP) » How to open the javascript editor with a non IFileEditorInput
How to open the javascript editor with a non IFileEditorInput [message #176792] Thu, 10 August 2006 14:46 Go to next message
sorry, but this is repost from:
"Integration of the Javascript Editor into a FormDialog"
I need to open the JavaScript editor with a non IFileEditorInput!
I have seen a lot of javascript text editors in eclipse
(BIRT, WorkflowEditor,.....).
Reason:
I implement a logic editor (like the GEF example) and want
implement the logic of the parts in javascript. So - the user
can change/create any parts in the library.
double click on a library element and edit the logic via javascript editor.
The javascript logic is a part of the element and isn't stored as
separat file.
Is there any solution available!!!!
greetings
Andreas
Re: How to open the javascript editor with a non IFileEditorInput [message #179730 is a reply to message #176792] Fri, 22 September 2006 23:42 Go to previous message
> Reason:
> separat file.
While we haven't tested any scenarios like that, I'd start by
looking at the IStorageEditorInput interface and how it can be used
to open an editor on a non-file. For editing without a full editor,
it's best to look into using a SourceViewer and the same setup as
the JavaScript Editor's text page
(org.eclipse.wst.javascript.ui.internal.editor.JSEditor). The
editor adds lifecycle management and other features, most of which
aren't really suited for putting into a dialog.
- Nitin
Previous Topic:Distinguish j2ee projects
Next Topic:refresh JSPs
Current Time: Sat Sep 13 05:47:33 EDT 2025
Powered by FUDForum. Page generated in 0.04123 seconds
