Re: Moving figures requires two steps?? [message #164384 is a reply to message #164144] |
Tue, 18 January 2005 18:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Pratik Shah![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ppshah%40us.ibm.com) Messages: 1077 Registered: July 2009 |
You shouldn't have to do anything for this to work (AbstractEditPart already
returns a DragEditPartsTracker in its getDragTracker() method).
My first guess is that you don't have a proper tool activated at that time.
Is the PanningSelectionTool your default tool? What should be happening is
that the event dispatcher should be forwarding the mouse down to the
SelectionTool (#mouseDown()), which in turn should be forwarding it to the
DragEditPartsTracker (#mousedown()) which selects the editpart you clicked
on in its handleButtonDown() method.
What happens when you just click on a previously unselected editpart and
start dragging? The part doesn't get selected?
"Sean Neeley" <sean.neeley@dbcsoftware.com> wrote in message
news:csgsql$l9i$1@www.eclipse.org...
> In my GEF application, to move an IFigure, a user must first click on
> the figure to select it, release the mouse, then click a second time to
> drag. I experimented with the Logic example, and moving a figure can be
> accomplished in one step, click and drag all at once. How do I make my
> application work like the Logic example? I cannot figure out what I
> have done differently. Does it have anything to do with the
> DragTracker? In my implementation of AbstractGraphicalEditPart, I am
> returning a DragEditPartsTracker in the getDragTracker(request) method.
> Does anyone know where I should look?
> - Sean
Re: Moving figures requires two steps?? [message #167621 is a reply to message #164384] |
Wed, 09 February 2005 21:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Sean Neeley![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=sean.neeley%40dbcsoftware.com) Messages: 22 Registered: July 2009 |
Junior Member |
I am using SelectionTool, not PanningSelectionTool. I revisited this
today and figured out the problem. I have a SWT control outside of GEF
which always has focus. If it loses focus, it steals it back. Anyway,
handleFocusLost() in SelectionTool was getting called during the
selection+drag process, which set the drag tracker to null... so by the
time mouseDrag was called in SelectionTool, I no longer had a valid drag
tracker. I fixed the problem by overriding handleFocusLost() to do nothing.
- Sean
>>Thanks,
>>- Sean
FUDForum. Page generated in 0.03735 seconds
