[LDT1.0] link a dynamic library , Help ! [message #1083901] |
Sat, 10 August 2013 17:52 |
林 焰 Messages: 1 Registered: August 2013 |
I installed Lua for windows & iup module , and test iup::dialog success.
I tested this code in LDT , but only red word printed in console
Then I use LDT 1.0 , how to config and expand embedded Lua Execution Envirment ,
making it support more rocks or module
[the tips]
Exception in thread "main" com.naef.jnlua.LuaRuntimeException: G:\__proj\lua\lua5.1\src\main.lua:6: module 'iuplua' not found:
no field package.preload['iuplua']
no file 'E:\Lib\Lua51\'
no file '.\iuplua.dll'
no file '.\iuplua51.dll'
no file 'E:\Lib\java\jdk1.7.0_21\jre\bin\iuplua.dll'
no file 'E:\Lib\java\jdk1.7.0_21\jre\bin\iuplua51.dll'
no file 'E:\Lib\java\jdk1.7.0_21\jre\bin\clibs\iuplua.dll'
no file 'E:\Lib\java\jdk1.7.0_21\jre\bin\clibs\iuplua51.dll'
no file 'E:\Lib\java\jdk1.7.0_21\jre\bin\loadall.dll'
no file 'E:\Lib\java\jdk1.7.0_21\jre\bin\clibs\loadall.dll'
at com.naef.jnlua.LuaState.lua_pcall(Native Method)
at com.naef.jnlua.LuaState.call(LuaState.java:555)
at org.eclipse.koneki.ldt.support.lua51.internal.interpreter.JNLua51Launcher.run(JNLua51Launcher.java:122)
at org.eclipse.koneki.ldt.support.lua51.internal.interpreter.JNLua51Launcher.main(JNLua51Launcher.java:137)
[the Example ]
-- Example 37 -- External Libraries.
-- Lua has support for external modules using the 'require' function
-- INFO: A dialog will popup but it could get hidden behind the console.
require( "iuplua" )
ml = iup.multiline
expand="YES",
value="Quit this multiline edit app to continue Tutorial!",
border="YES"
dlg = iup.dialog{ml ; title="IupMultiline" , size="QUARTERxQUARTER" ,}
dlg:show()
print( "Exit GUI app to continue!")
iup.MainLoop()
-------- Output ------
--Exit GUI app to continue!
--Press 'Enter' key for next example
FUDForum. Page generated in 0.03349 seconds
