New FitNesse Instance - FitNesse plugin [message #1077261] |
Thu, 01 August 2013 13:00 |
Ben Pearse Messages: 1 Registered: August 2013 |
Hi All,
I'm trying to create a new fitnesse instance to run as a build step in my Hudson job. I have the plugin installed correctly, so that if I select 'FitNesse is already running' as opposed to creating a new instance, everything works beautifully. However, when I try to create a new instance, something fails and I can't work out what - I think I have all the paths set correctly, but I get this log:
Building remotely on FirefoxFitNesee
hudson.plugins.fitnesse.FitnesseBuilder: {fitnessePortLocal=8020, fitnesseTargetPage=MyFirstTestLocal, fitnesseTargetIsSuite=false, fitnessePathToJar=C:\Users\USERNAME\.hudson\firstTest\workspace\CompleteStartingFitNesse\fitnesse.jar, fitnesseJavaOpts=, fitnesseHttpTimeout=600000, fitnesseJavaWorkingDirectory=C:\Users\USERNAME\.hudson\firstTest\workspace\CompleteStartingFitNesse, fitnessePathToRoot=C:\Users\USERNAME\.hudson\firstTest\workspace\CompleteStartingFitNesse\FitNesseRoot, fitnesseStart=True, fitnessePathToXmlResultsOut=C:\Users\USERNAME\FitTests\Results\localtest-results.xml}
Starting new Fitnesse instance...
[CompleteStartingFitNesse] $ C:\FAST\DeveloperDesktop\tools\JDK\1.6.0_16\bin\java -jar C:\Users\USERNAME\.hudson\firstTest\workspace\CompleteStartingFitNesse\fitnesse.jar -d C:\Users\USERNAME\.hudson\firstTest\workspace\CompleteStartingFitNesse -r FitNesseRoot -p 8020
Waited 10000ms for fitnesse to start.
Finished: FAILURE
Any help would be much appreciated!
FUDForum. Page generated in 0.03597 seconds
