Windows Koneki and Corona first steps setup [message #1059131] |
Thu, 16 May 2013 21:59 |
Linus Janson Messages: 6 Registered: May 2013 |
Junior Member |
I want to debug or at least edit and run Android apps in the Corona Simulator, from Eclipse.
I saw Benjamin's youtube video (can't link) of using Koneki once it is installed. Benjamin's version is Mac though and looks a little different.
I have XP 32-bit and Corona Simulator works fine. I will have to use just a text editor until I get Eclipse working.
I downloaded Koneki LDT standalone 1.0, created new project and tried run as Lua Application, but I get Exception in thread Main.
And code hinting doesn't work even for Lua, when I type "for" I get no suggestions.
1. What to download?
2. How to tell Corona Simulator and Eclipse so they can find each other?
3. What to install/set up to get Corona API look up code hinting in Eclipse?
EDIT:
With roaminggamer's help I've solved it now! The answer is not as good as it could be since I'm not allowed to link here yet...
Answers:
1. JDK6 SE, Eclipse Java EE Juno, LDT debugger script, and Koneki+Corona API plugins within Eclipse.
2. By creating a Debug Configuration for Lua Remote Application.
3. This works when you use normal Eclipse+plugins or the standalone, but I still don't understand how Benjamin (kartben) got the "for" hinting. Maybe he hit a special-hinting key that I don't know yet.
Android Developer
Free Thought Games
freethoughtgames.wordpress.com
[Updated on: Tue, 21 May 2013 20:39] Report message to a moderator
FUDForum. Page generated in 0.03633 seconds
