eclipse, SuSe Linux 10.0 and *.jar files [message #154215] |
Sat, 27 May 2006 11:48 |
Originally posted by: obewaj.essex.ac.uk
I'm trying to make a switch from windows to linux, because of Windows'
memory issues. I've got everything working on Suse 10.0 on my IBM T22
Thinkpad 512mb.
java JDK 1.5.06 installed and working, JSci maths and JAS libraries work
fine on import command in java code, eclipse work perfectly much faster
than under windows.
The problem comes when I try to run the JAS executable jar file through
eclipse, using the jas.engine.Sim command to compile and run the code.
The running instructions are as follows:
____________________________________________________________ _________
Click on "run" on the toolbar. Then click on "run....". In the run window,
double click on "Java application". Give the "New_configuration" a name,
and under the main tab, insert the project name. For the main class,
insert "jas.engine.Sim". Where appropriate, check the boxes that follow,
otherwise leave them blank. After that, click on "Apply", and then on
"Run".
____________________________________________________________ ___________
This works fine under Windows but I can't get it to work under linux. I'm
sure its a problem with getting linux to automatically run *.jar files
with java.
if you want to try the JAS Libraries are at
http://prdownloads.sourceforge.net/jaslibrary/JAS-1.2.1.jar? download
and to use them in eclipse you need to use the "import external jars" part
of your java project
Your help will be greatly appriciated.
FUDForum. Page generated in 0.06989 seconds
