Home » Language IDEs » Java Development Tools (JDT) » M8 Projects don't build, Problems don't show
M8 Projects don't build, Problems don't show [message #151934] Wed, 31 March 2004 23:04 Go to next message
Scott Palmer is currently offline Scott PalmerFriend
After trying M8 I find that Builds just don't happen when they are
supposed to, and they can't be
forced because the options are always grayed out.
I can select "Clean..." - which is apparently the new and improved
roundabout way to do a Build All,
though the Build All choice is still shown grayed out to tease me. But
then I will go and make a
change that should cause obvious errors. I will add a new method to an
interface for example, and
hope that the errors show me all the places where I need to implement that
new method. This worked
fine in M7. Now no problem show in the Problem view, and the code remains
broken.
Please, is there a way to get back to the old way of building? This new
way simply isn't working at all
for me. For now I've gone back to M7.
Re: M8 Projects don't build, Problems don't show [message #151944 is a reply to message #151934] Wed, 31 March 2004 23:50 Go to previous message
Darin Swanson is currently offline Darin SwansonFriend
You can bring back the "old" actions if needed.
Window>Preferences>Workbench>Work in progress>Restore 2.1 rebuild actions
for this session.
Darins
"Scott Palmer" <scott.palmer@2connected.org> wrote in message
news:c4fipi$es1$1@eclipse.org...
> broken.
Previous Topic:3.0 M8: Problems view doesn't pop up
Next Topic:how to use extended java family functionality in 3.0?
Current Time: Sat Dec 21 13:56:10 GMT 2024
Powered by FUDForum. Page generated in 0.02960 seconds
