Home » Archived » BIRT » XLS emitter 2.0.1
XLS emitter 2.0.1 [message #146472] Tue, 21 March 2006 13:49 Go to next message
Originally posted by: rebprotizer_2k3.hotmail.com
i have downloaded the xls emitter version 2.0.1 here :
http://qauck.blogspot.com/
The XLS preview icon appeared correctly, but when i click on it a file
run.xls is openning, but is a cleared file.
I have followed the installation of this emitter on the site, but it does
work.
Who can help me please. It's very important to me to do xls export, else i
will use the xls export of jasper and it is not very beautiful.
Luc LABBE
Re: XLS emitter 2.0.1 [message #146505 is a reply to message #146472] Tue, 21 March 2006 14:55 Go to previous messageGo to next message
Originally posted by: qauck.msn.com
Luc,
What version of BIRT are you using? This should work for the
birt-all-in-one-2.0.1 build. Did the PDF preview also work or not? And
please check the log file under the viewer plugin, more details would be
helpful to resolve the issue.
Shawn
> does work.
> i will use the xls export of jasper and it is not very beautiful.
> Luc LABBE
Re: XLS emitter 2.0.1 [message #146560 is a reply to message #146505] Tue, 21 March 2006 16:02 Go to previous message
It's working very well !!!!
In fact, i have forgiven the poi file in /lib, beacause i have change the
version.
The export working well.
Can I change the option of the export, because the XLS File created has
multi sheets corresponding to one page.
I keep an eye on it.
Thanks for your help.
Luc LABBE
Previous Topic:expression for X-AXIS label
Next Topic:dynamic parameters
Current Time: Fri Jan 31 21:02:38 GMT 2025
Powered by FUDForum. Page generated in 0.02086 seconds
