Re: Importing ReqIf file into ProR [message #896921 is a reply to message #896913] |
Fri, 20 July 2012 12:47 |
Hi Bill,
You do not need to import a ReqIF file - you can simply open it. Either copy it into your workspace, or simply navigate to it by using File > Open.
Note that the file must end in .reqif.
Hope this helps!
- Michael
Re: Importing ReqIf file into ProR [message #896981 is a reply to message #896977] |
Fri, 20 July 2012 16:17 |
Hi Bill,
This error message indicates that something is wrong with the XML - there is nothing else you need to install.
Can you attach the file here? If it's proprietary, you can email it to me, or just post the first dozen lines.
Best,
- Michael
Re: Importing ReqIf file into ProR [message #897127 is a reply to message #897015] |
Sun, 22 July 2012 07:42 |
Hi Bill,
Glad that Keith could solve your problem!
> I will let IBM know about that issue.
Just curious: How is this IBM's problem? Considering that DOORS does not yet write ReqIF (am I mistaken?), I would assume that name space issue stems from the transformation scripts? I don't have DOORS available right now, so I cannot check this myself.
Best,
- Michael
FUDForum. Page generated in 0.03521 seconds
