Home » Modeling » GMF (Graphical Modeling Framework) » Installing GMF M6 Stream Stable Build
Installing GMF M6 Stream Stable Build [message #119309] Sat, 14 April 2007 13:49 Go to next message
Originally posted by: lists1999.hotmail.com
Hi Everyone,
I have successfully installed Eclipse 3.3M6, EMF, GEF etc. However, when I
try to install GMF 2.0M6 it fails. The error message is "Error retrieving
"Error retrieving "plugins/org.eclipse.gmf.sdk_1.0.0.v20070403-1500.jar".
[Server returned HTTP response code: "404 Not Found" for URL:
http://www.gtlib.gatech.edu/pub/eclipse/releases/europa/plug ins/org.eclipse.gmf.sdk_1.0.0.v20070403-1500.jar.] "
This is from the Europa update site.
I have tried creating a new Update site only for GMF but I end up at the
same problem.
Any suggestions?
RS
Re: Installing GMF M6 Stream Stable Build [message #119322 is a reply to message #119309] Sat, 14 April 2007 21:04 Go to previous messageGo to next message
Richard Gronback is currently offline Richard GronbackFriend
Sorry, there is a known problem with the update sites for M6. It's been
fixed on the main Europa site (I haven't verified), but perhaps hasn't
propagated to all mirrors yet.
Try using our milestone site, or selecting the main Europa site and not a
mirror:
http://download.eclipse.org/modeling/gmf/update-site/milesto ne/site.xml
Rich
On 4/14/07 9:49 AM, in article evqm6c$3hq$1@build.eclipse.org, "RS"
<lists1999@hotmail.com> wrote:
> Hi Everyone,
> same problem.
> Any suggestions?
> Thanks
> RS
Re: Installing GMF M6 Stream Stable Build [message #119348 is a reply to message #119322] Sun, 15 April 2007 02:18 Go to previous messageGo to next message
I used the link that you provided and it worked!!
Thanks!
Rajan
"Richard Gronback" <richard.gronback@borland.com> wrote in message
news:C246BA0C.14DAB%richard.gronback@borland.com...
> mirror:
> Rich
>> Hi Everyone,
>> I
>> same problem.
>> Any suggestions?
>> Thanks
>> RS
Re: Installing GMF M6 Stream Stable Build [message #125737 is a reply to message #119322] Thu, 10 May 2007 16:51 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
> mirror:
I'm trying with the main Europa site, but the problem still persists...
Lorenzo Bettini, PhD in Computer Science, DSI, Univ. di Firenze
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Installing GMF M6 Stream Stable Build [message #125751 is a reply to message #125737] Thu, 10 May 2007 16:59 Go to previous messageGo to next message
It's only been fixed on the Europa staging site, afaiu. M7 will be out next
week, so the problem should go away with that update to the Europa site.
- Rich
On 5/10/07 12:51 PM, in article f1vij5$sbp$1@build.eclipse.org, "Lorenzo
>> mirror:
Re: Installing GMF M6 Stream Stable Build [message #125788 is a reply to message #125751] Thu, 10 May 2007 17:10 Go to previous message
OK, thanks
in the meanwhile I simply downloaded the milestone zip
Lorenzo
Previous Topic:mindmap.ecore for the GMF Tutorial
Next Topic:Remove GMF generated tool from palette
Current Time: Sat Dec 21 16:35:15 GMT 2024
Powered by FUDForum. Page generated in 0.04030 seconds
