We want your inputs for the next release of Koneki! [message #893353] |
Tue, 03 July 2012 16:17 |
Hi there,
Now that Koneki 0.8 is out, it is time to discuss what we should put in our next release. The plan would be to release the 0.9 version somewhere around the end of the year.
I suggest that you guys use this thread to list what you think would be great enhancements to the tools, and we will then update this wiki page accordingly.
Of course, I know that most of the users of Koneki are using LDT, but if you are an user of the OMA-DM simulator, your inputs are also most welcome!
My blog: http://blog.benjamin-cabe.com
[Updated on: Tue, 03 July 2012 16:20] Report message to a moderator
Re: We want your inputs for the next release of Koneki! [message #894652 is a reply to message #893353] |
Tue, 10 July 2012 01:32 |
uiy uiy Messages: 56 Registered: May 2012 |
Member |
1. When the LDT is asking to update please have some sort of changelog or some way to know what the update is really about when it asks. I always update but it's nice to see what is changed.
2. Function collapsing.
3. Editor: Ability to tabify. I hate having to delete a bunch of white space to align things and the ability to convert all spaces into tabs would be nice(just scan document and any group of 4 spaces would be converted to a tab).
White space management. When one presses delete at the end of a line it should bring the line below it right up to current line with just a whitespace between them. Currently when this is done one has to delete all the whitespace by hand that was from the indentation of that line.
Similarly for backspace but it either moves the line down a tab or to the start of the line.
The goal here is to keep everything tab aligned. I almost never have the need to start a line that isn't aligned on a tab but I find myself having to delete spaces all the time to align along tabs. By simply making the backspace and del greedy, even tab aligned greedy, one can solve most of these problems.
4. Intellisense improvements. I'm used to visual studio's comprehensive intellisense and it would be very nice to have something similar for ldt. I know there was some discussion or something about intellisense for user functions and variables but the ability to simply scan for functions in all open files or project files and make them available for intellisense would be nice. (something that will just trigger the neurons)
5. Make it easier to setup, run, and debug projects. The run/debug configurations and everything seems like a mess(maybe my ignorance on eclipse).
With visual studio if I want to debug I hit F5 and if I want to run I hit ctrl-F5.. or set it up for F6. It also automatically saves the files and doesn't pop up a box asking me to save which just slows down everything on small projects.
[Updated on: Tue, 10 July 2012 05:02] Report message to a moderator
Re: We want your inputs for the next release of Koneki! [message #894769 is a reply to message #894652] |
Tue, 10 July 2012 13:02 |
Simon Bernard Messages: 345 Registered: July 2009 |
Hi uiy uiy,
Thx for your feedback.
1. You're right, we must have a more readable deliver process. We will thing about that.
2. It could be a nice improvement.
3. There are some interesting propositions. It seems our formatter could answer to your needs. Did you try it?
4. We plan to improve our auto-completion system. We are focused on a smart but not complete auto-completion support, but it could have sense to complete it with dummy auto-completion. Did you try, the execution environment feature ?
5. Currently, we have only one debug launch configuration : "Attach to Lua Application". It is not a very simple way to debug but it allows to support a lot of different use cases (different kind of VM, remote debugging, ...)
We plan to add other kinds of launch configuration to simplify some use cases (with standard eclipse shortcut Ctrl+F11 to run and F11 to debug)
FYI, The shortcut is configurable in eclipse : windows/preferences/general/keys, and you could configure if you want a prompt or not when you run an application : windows/preferences/Run-Debug/Launching.
Re: We want your inputs for the next release of Koneki! [message #1002876 is a reply to message #893353] |
Sat, 19 January 2013 18:22 |
Hey Marc!
Looks like it's simply a matter of not forgetting to indicate which comments in your code are actually documentation comments. This is done by starting your comment with a dash. Usually it'll mean you'll have comments like
or
--[[- this if you prefer block comments ... ]]
For your sample, the following should work just fine
-- some World of Warcraft specific stuff...
-- @module Seller
local Seller = vendor.Seller
-- some other code...
-- @function [parent=#Seller] OnInitialize
function Seller.OnInitialize(self)
end
FUDForum. Page generated in 0.04753 seconds
