Home » Language IDEs » ServerTools (WTP) » Deploymentdescriptor works only with JBoss4.0
Deploymentdescriptor works only with JBoss4.0 [message #115996] Mon, 04 July 2005 16:23 Go to next message
the problem I posted to this group (ejb-jar.xml must define a valid
DOCTYPE)only appears in JBoss 3.x. If I deploy the jar-file of the
tutorial on jboss 4.0.0 everything is ok. It seems that JBoss 3.x cannot
handle xml-Schema-Definitions. But if It try to start JBoss 4.0.0 from
eclipse 3.1 the following error happens while starting the server:
22:00:37,765 ERROR [BasicMBeanRegistry] Cannot register MBean
java.lang.NoClassDefFoundError: org/dom4j/DocumentException
javax.management.modelmbean.ModelMBeanAttributeInfo.createDe faultDescriptor(ModelMBeanAttributeInfo.java:268)
javax.management.modelmbean.ModelMBeanAttributeInfo.<init>(ModelMBeanAttributeInfo.java:145)
org.jboss.mx.metadata.MBeanInfoConversion.toModelMBeanInfo(M BeanInfoConversion.java:80)
at org.jboss.mx.modelmbean.XMBean.<init>(XMBean.java:212)
org.jboss.mx.server.registry.BasicMBeanRegistry.registerMBea n(BasicMBeanRegistry.java:180)
at org.jboss.mx.server.MBeanServerImpl.<init>(MBeanServerImpl.java:200)
org.jboss.mx.server.MBeanServerBuilderImpl.newMBeanServer(MB eanServerBuilderImpl.java:56)
at javax.management.MBeanServerFactory$2.run(MBeanServerFactory .java:226)
javax.management.MBeanServerFactory.createMBeanServer(MBeanS erverFactory.java:221)
javax.management.MBeanServerFactory.createMBeanServer(MBeanS erverFactory.java:153)
at org.jboss.system.server.ServerImpl.doStart(ServerImpl.java:3 32)
at org.jboss.system.server.ServerImpl.start(ServerImpl.java:293 )
at org.jboss.Main.boot(Main.java:151)
at org.jboss.Main$1.run(Main.java:405)
at java.lang.Thread.run(Thread.java:534)
java.lang.NoClassDefFoundError: org/dom4j/Element
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 18)
at java.lang.Class.getConstructor0(Class.java:1930)
at java.lang.Class.newInstance0(Class.java:278)
at java.lang.Class.newInstance(Class.java:261)
org.jboss.mx.modelmbean.RequiredModelMBeanInstantiator.insta ntiate(RequiredModelMBeanInstantiator.java:37)
at org.jboss.mx.server.MBeanServerImpl.<init>(MBeanServerImpl.java:205)
Has anyone tried to deploy "ZooBeansProject.jar" from the tutorial
successfully on JBoss?
Re: Deploymentdescriptor works only with JBoss4.0 [message #116155 is a reply to message #115996] Tue, 05 July 2005 01:11 Go to previous messageGo to next message
This is due to the fact that J2EE 1.3 (JBoss 3.x) uses DTD to validate
the deployment descriptors and J2EE 1.4 (JBoss 4.x) uses schema
definitions. I think you should be able to control which (doctype or
scheme reference) gets generated by choosing the right JBoss version
from xdoclet settings.
Your're using Java 1.4.2 or Java 1.5.0? Does JBoss 4.x start ok when you
start it from command line outside Eclipse? I've some similar stack
traces with Java 1.5.0.
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
Re: Deploymentdescriptor works only with JBoss4.0 [message #116232 is a reply to message #116155] Tue, 05 July 2005 08:20 Go to previous message
I changed the settings in
Window->Preference->J2EEAnnotations->xdoclet->ejbDoclet. If I choose JBoss
3.x, ejb-jar ist generated with schema - reference, too. Please tell me
how I can get an ejb-jar with DOCTYPE like jboss 3.x needs.
yes, if I start jboss4.0 from outside eclipse, it uses java version 1.5 an
starts without problems.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:Can't debug JSP pages
Next Topic:Tomcat 5.0 on Gentoo with WTP
Current Time: Sat Apr 05 01:03:00 EDT 2025
Powered by FUDForum. Page generated in 0.02697 seconds
