| Creating your first Java Project [message #115519] |
Tue, 08 November 2005 09:21 |
Originally posted by: anirban_das7.yahoo.co.uk
Hi There
I am new to Eclipse and have been working through the 'Help', 'Getting
Started', 'Basic Tutorial'.
I have a problem following the help text in the section 'Creating your
first
Java project', it suggests I download the 'Sample Code Junit' . I have
followed the instructions to the letter and have also tried other download
sites. The version of Eclipse I am using is 3.0.
The problem occurs when I download the Zip file 'Example Plug-ins', I
download the correct file and then use Eclipse to open (import) the Zip
file. The help text says I should open the zip file and find
eclipse/plugins/org.eclipse.jdt.ui.examples.projects_3.0.0/a rchive/junit/junit381src.jar.
All of which I do, I then click Finish and return to Eclipse main display.
However, I am not getting the above, I am getting
eclipse-examples-3.0-win32
If I open the section I have just imported from the zip file I see the
following folders...
- eclipse
- eclipse.features
- eclipse.plugins
- JRE System Library [ j2re1.4.2_09 ]
The help text says I should see the following
- Awtui
- Extensions
- Framework
- Runner
- Samples
- Swingui
- Textui
I can not continue withthe tutorial as if refers to folders that should
have been downloaded.
Either I have made an error downloading the wrong Zip file, as mentioned I
or the zip file itself is incorrect, or the help text is wrong ?
I would be VERY grateful for some help and advice for which way to progress
from here.
Many thanks in advance for all your help.
Ani.
FUDForum. Page generated in 0.08818 seconds
