Home » Language IDEs » PHP Development Tools (PDT) » !MESSAGE A handler conflict occurred.(Bug related)
!MESSAGE A handler conflict occurred. [message #843574] |
Fri, 13 April 2012 06:57 |
Trond Husoe![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=trond%40trondhuso.no) Messages: 2 Registered: October 2011 |
Junior Member |
In Indigo I am getting this error:
!ENTRY org.eclipse.ui.workbench 2 0 2012-04-02 10:27:32.992
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2012-04-02 10:27:32.992
!MESSAGE Conflict for 'org.eclipse.ui.navigate.forwardHistory':
HandlerActivation(commandId=org.eclipse.ui.navigate.forwardHistory,
handler=ActionHandler(org.eclipse.ui.internal.NavigationHistoryAction@3d50475b),
expression=ActiveShellExpression(Shell {PHP - Eclipse SDK}),sourcePriority=17408)
handler=ActionHandler(org.eclipse.ui.internal.dialogs.PreferencePageHistory$2@617cc6cf),
expression=ActiveShellExpression(Shell {Preferences}),sourcePriority=17408)
!MESSAGE Conflict for 'org.eclipse.ui.navigate.backwardHistory':
HandlerActivation(commandId=org.eclipse.ui.navigate.backwardHistory,
handler=ActionHandler(org.eclipse.ui.internal.NavigationHistoryAction@46e07209),
handler=ActionHandler(org.eclipse.ui.internal.dialogs.PreferencePageHistory$1@395ed139),
!SESSION 2012-04-03 10:00:50.787 -----------------------------------------------
eclipse.buildId=M20120208-0800
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.ui.workbench 2 0 2012-04-03 10:01:34.872
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2012-04-03 10:01:34.872
!MESSAGE Conflict for 'org.eclipse.dltk.ui.edit.text.script.refactor.quickMenu':
HandlerActivation(commandId=org.eclipse.dltk.ui.edit.text.script.refactor.quickMenu,
handler=org.eclipse.dltk.internal.ui.actions.refactoring.RefactorActionGroup$3@139008b,
expression=AndExpression(ActivePartExpression(org.eclipse.php.internal.ui.explorer.PHPExplorerPart@576ba7f9),WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@7c0cbf92)),sourcePriority=1064960)
handler=org.eclipse.dltk.internal.ui.actions.refactoring.RefactorActionGroup$3@4552a64d,
!ENTRY org.eclipse.php.debug.core 4 10001 2012-04-03 10:23:02.306
!MESSAGE Can't determine version of the PHP executable
!ENTRY org.eclipse.php.core 4 10001 2012-04-03 10:28:43.361
!MESSAGE PHPCore plugin internal error
!STACK 1
org.eclipse.dltk.core.ModelException: $con [in module_doping_list.php [in www/admin/modules/case [in <project root> [in www.dopinglist.com]]]] does not exist
at org.eclipse.dltk.internal.core.ModelElement.newNotPresentException(ModelElement.java:258)
at org.eclipse.dltk.internal.core.ModelElement.openWhenClosed(ModelElement.java:196)
at org.eclipse.dltk.internal.core.ModelElement.getElementInfo(ModelElement.java:171)
at org.eclipse.dltk.internal.core.ModelElement.getElementInfo(ModelElement.java:153)
at org.eclipse.dltk.internal.core.Member.getFlags(Member.java:50)
at org.eclipse.php.internal.core.codeassist.PHPCompletionEngine.reportField(PHPCompletionEngine.java:177)
at org.eclipse.php.internal.core.codeassist.strategies.GlobalVariablesStrategy.apply(GlobalVariablesStrategy.java:91)
at org.eclipse.php.internal.core.codeassist.strategies.GlobalElementsCompositeStrategy.apply(GlobalElementsCompositeStrategy.java:43)
at org.eclipse.php.internal.core.codeassist.PHPCompletionEngine.complete(PHPCompletionEngine.java:112)
at org.eclipse.php.internal.core.codeassist.PHPCompletionEngine.complete(PHPCompletionEngine.java:66)
at org.eclipse.dltk.internal.core.Openable$CompletionThread.run(Openable.java:501)
at org.eclipse.dltk.internal.core.Openable$CompletionThread.run(Openable.java:482)
!SUBENTRY 1 org.eclipse.dltk.core 4 969 2012-04-03 10:28:43.362
!MESSAGE $con [in module_doping_list.php [in www/admin/modules/case [in <project root> [in www.dopinglist.com]]]] does not exist
!ENTRY org.eclipse.dltk.core 2 0 2012-04-03 11:08:30.840
!MESSAGE Error decoding problem idenfier "1073741824"
!SESSION 2012-04-03 19:51:20.831 -----------------------------------------------
!ENTRY org.eclipse.ui.workbench 2 0 2012-04-03 19:51:44.246
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2012-04-03 19:51:44.246
handler=org.eclipse.dltk.internal.ui.actions.refactoring.RefactorActionGroup$3@402fbd59,
expression=AndExpression(ActivePartExpression(org.eclipse.php.internal.ui.explorer.PHPExplorerPart@8cff5ed),WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@5e725967)),sourcePriority=1064960)
handler=org.eclipse.dltk.internal.ui.actions.refactoring.RefactorActionGroup$3@7e383efa,
!ENTRY org.eclipse.php.debug.core 4 10001 2012-04-03 20:07:33.167
!SESSION 2012-04-08 09:19:51.030 -----------------------------------------------
!ENTRY org.eclipse.ui.workbench 2 0 2012-04-08 09:20:12.933
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2012-04-08 09:20:12.933
handler=org.eclipse.dltk.internal.ui.actions.refactoring.RefactorActionGroup$3@593be416,
expression=AndExpression(ActivePartExpression(org.eclipse.php.internal.ui.explorer.PHPExplorerPart@73f378c8),WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@50152643)),sourcePriority=1064960)
handler=org.eclipse.dltk.internal.ui.actions.refactoring.RefactorActionGroup$3@6afb8e1e,
!ENTRY org.eclipse.osgi 2 0 2012-04-08 09:20:21.956
!MESSAGE While loading class "org.vcs.bazaar.eclipse.core.listeners.FileModificationManager$1", thread "Thread[Worker-8,5,main]" timed out waiting (5010ms) for thread "Thread[Worker-4,5,main]" to finish starting bundle "org.vcs.bazaar.eclipse.core_1.1.1.210 [432]". To avoid deadlock, thread "Thread[Worker-8,5,main]" is proceeding but "org.vcs.bazaar.eclipse.core.listeners.FileModificationManager$1" may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle "reference:file:plugins/org.vcs.bazaar.eclipse.core_1.1.1.210.jar" by thread "Worker-4".
at org.eclipse.osgi.framework.internal.core.AbstractBundle.beginStateChange(AbstractBundle.java:1087)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:297)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:463)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at org.vcs.bazaar.eclipse.core.listeners.FileModificationManager.resourceChanged(FileModificationManager.java:53)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:395)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1530)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2353)
at org.eclipse.core.internal.events.NotificationManager$NotifyJob.run(NotificationManager.java:40)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$BundleStatusException
... 23 more
Root exception:
!ENTRY org.vcs.bazaar.eclipse.core 4 0 2012-04-08 11:18:14.087
!MESSAGE A unexpected error ocurred
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.649
!MESSAGE A network error occurred.
!STACK 0
org.vcs.bazaar.client.xmlrpc.XmlRpcCommandException: A network error occurred.
at redstone.xmlrpc.XmlRpcClient.endCall(Unknown Source)
at redstone.xmlrpc.XmlRpcClient.invoke(Unknown Source)
at org.vcs.bazaar.client.xmlrpc.internal.XMLRPCCommandRunner.runCommand(XMLRPCCommandRunner.java:41)
at org.vcs.bazaar.client.xmlrpc.internal.XMLRPCCommandRunner.access$100(XMLRPCCommandRunner.java:28)
at org.vcs.bazaar.client.xmlrpc.internal.XMLRPCCommandRunner$1.internalExecute(XMLRPCCommandRunner.java:129)
at org.vcs.bazaar.client.xmlrpc.internal.XMLRPCCommandRunner$1.internalExecute(XMLRPCCommandRunner.java:128)
at org.vcs.bazaar.client.xmlrpc.internal.XMLRPCCommandRunner$SafeXmlRPCCall.execute(XMLRPCCommandRunner.java:185)
at org.vcs.bazaar.client.xmlrpc.internal.XMLRPCCommandRunner.runCommand(XMLRPCCommandRunner.java:126)
at org.vcs.bazaar.client.commandline.internal.Command.execute(Command.java:82)
at org.vcs.bazaar.client.commandline.CommandLineClient.run(CommandLineClient.java:623)
at org.vcs.bazaar.client.commandline.CommandLineClient.run(CommandLineClient.java:617)
at org.vcs.bazaar.client.commandline.CommandLineClient.log(CommandLineClient.java:316)
at org.vcs.bazaar.client.commandline.CommandLineClient.log(CommandLineClient.java:214)
at org.vcs.bazaar.eclipse.core.commands.LogCommand.run(LogCommand.java:84)
at org.vcs.bazaar.eclipse.core.log.LogUpdater.fetchLog(LogUpdater.java:19)
at org.vcs.bazaar.eclipse.core.log.LogUpdater.fetchLog(LogUpdater.java:24)
at org.vcs.bazaar.eclipse.core.log.LogCacheManager.basicGetLog(LogCacheManager.java:142)
at org.vcs.bazaar.eclipse.core.log.LogCacheManager.getLogs(LogCacheManager.java:112)
at org.vcs.bazaar.eclipse.core.log.LogCacheManager.getLogs(LogCacheManager.java:97)
at org.vcs.bazaar.eclipse.core.log.LogCacheManager.getLogs(LogCacheManager.java:75)
at org.vcs.bazaar.eclipse.ui.decorator.BazaarLightweightDecorator.getLastLogMessage(BazaarLightweightDecorator.java:191)
at org.vcs.bazaar.eclipse.ui.decorator.BazaarLightweightDecorator.decorateByType(BazaarLightweightDecorator.java:140)
at org.vcs.bazaar.eclipse.ui.decorator.BazaarLightweightDecorator.decorate(BazaarLightweightDecorator.java:94)
at org.vcs.bazaar.eclipse.ui.decorator.BazaarLightweightDecorator.decorate(BazaarLightweightDecorator.java:83)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefinition.decorate(LightweightDecoratorDefinition.java:263)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager$LightweightRunnable.run(LightweightDecoratorManager.java:81)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.decorate(LightweightDecoratorManager.java:365)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.getDecorations(LightweightDecoratorManager.java:347)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.ensureResultCached(DecorationScheduler.java:370)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run(DecorationScheduler.java:330)
Caused by: redstone.xmlrpc.XmlRpcException: A network error occurred.
... 32 more
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:351)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:213)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:200)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at java.net.Socket.connect(Socket.java:478)
at sun.net.NetworkClient.doConnect(NetworkClient.java:163)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:394)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:529)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:233)
at sun.net.www.http.HttpClient.New(HttpClient.java:306)
at sun.net.www.http.HttpClient.New(HttpClient.java:323)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:970)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:911)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:836)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1014)
... 32 more
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.656
!STACK 0
... 32 more
... 32 more
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.661
!STACK 0
... 32 more
... 32 more
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.667
!STACK 0
... 32 more
... 32 more
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.671
!STACK 0
... 32 more
... 32 more
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.675
!STACK 0
... 32 more
... 32 more
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.679
!STACK 0
... 32 more
... 32 more
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.683
!STACK 0
... 32 more
... 32 more
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.687
!STACK 0
... 32 more
... 32 more
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.691
!STACK 0
... 32 more
... 32 more
!ENTRY org.vcs.bazaar.eclipse.core 4 -6 2012-04-09 00:34:30.694
!STACK 0
Current Time: Wed Jul 03 07:29:30 GMT 2024
Powered by FUDForum. Page generated in 0.03307 seconds
