Home » Eclipse Projects » Eclipse Platform » eclipse startup problem....
eclipse startup problem.... [message #105166] Fri, 01 August 2003 21:59 Go to next message
Originally posted by: syedwasimali.hotmail.com
Trying to run eclipse-2.1.1-gtk build on RH7.3 linux platform and the
attempts to start the IDE initially failed with the following error:
org.apache.axis.util.ObjectFactory$ConfigurationError: Provider
org.apache.xerces.parsers.StandardParserConfiguration not found
at ....
added the xercesImpl.jar and xmlParserAPIs.jar (xerces_2_3_0) in the
classpath, but that only changed the error to:
java.lang.ExceptionInInitializerError
.......................RegistryLoader.processManifestFile(Re gistryLoader.javaA:89)
at ....
I have tried the following variations of commands to no avail:
$ eclipse
$ eclipse -vm /loc.../j2sdk_1_4_1/java
$ eclipse -vm /loc.../j2sdk_1_4_1/java -jvmargs -Djava.ext.dir=
It is hard for me to imagine that starting this IDE can be so difficult.
I *must* be missing something very very simple. Any ideas???
Many thanks in advance.
-Syed
Re: eclipse startup problem.... [message #109067 is a reply to message #105166] Fri, 08 August 2003 20:30 Go to previous message
Originally posted by: John_Arthorne.oti.com_
http://eclipsewiki.swiki.net/134#badXerces
> at ....
> at
> ......................RegistryLoader.processManifestFile(Reg istryLoader.javaA:89)
> at ....
> $ eclipse
> -Syed
Previous Topic:Eclipse without (file based) resources
Next Topic:Plugin dependencies
Current Time: Tue Feb 11 18:39:38 GMT 2025
Powered by FUDForum. Page generated in 0.03845 seconds
