Home » Eclipse Projects » Eclipse Platform » How-to extend JDT Package Explorer View for a new plugin
How-to extend JDT Package Explorer View for a new plugin [message #95432] Wed, 16 July 2003 22:58 Go to next message
I am in the process of writing a new plugin and I have a question about
how I should structure my plugin. It seems that the only way I can
implement my own domain model is to write my own view. However, what I
would like to do is some how extend the Package Exploer view and implement
my model, menus, actions, and wizards. The reason I would like to do this
is so the user has access to all of Package Explorer view as well as my
plugin. Tons of code has been written for this view and I do not want to
duplicate it if possible. Is there a way I can do this?
Re: How-to extend JDT Package Explorer View for a new plugin [message #95527 is a reply to message #95432] Thu, 17 July 2003 02:27 Go to previous messageGo to next message
Yes, if it should show more than just resources and/or Java elements.
There is currently a proposed item on the 3.0 plan which is targeted at
your needs: General Purpose Navigator.
> However, what I
You can
- use all the public API components which the Package Explorer itself uses
- contribute your filters to the Package Explorer
- adapt your model elements to Java elements or resources to let them
show up in the Package Explorer
HTH
Dani
Re: How-to extend JDT Package Explorer View for a new plugin [message #96031 is a reply to message #95527] Thu, 17 July 2003 20:37 Go to previous messageGo to next message
> > However, what I
> You can
> HTH
> Dani
Dani,
Re: How-to extend JDT Package Explorer View for a new plugin [message #96045 is a reply to message #95527] Thu, 17 July 2003 20:45 Go to previous messageGo to next message
> > However, what I
> You can
> HTH
> Dani
Daniel,
I appreciate your response. Are there any examples that I can
reference? I am new to developing with the Eclipse platform. To address
your first bullet would I create my own view and then extend the
PackageExplorerPart view or just contribute my plugin to the Package
Explorer in the plugin.xml. To address you last bullet how would I go
about adapting my model to Java elements or resources. I have read allot
of the articles online but none seem to address these types of questions.
Thank You,
Henry
Re: How-to extend JDT Package Explorer View for a new plugin [message #96191 is a reply to message #96045] Fri, 18 July 2003 02:27 Go to previous message
>>>However, what I
>>You can
>>HTH
>>Dani
>Daniel,
No, you should not extend it since it is internal and can change at any
time. But yes, create your own view.
Parts are contributed by a plug-in and not the other way around. Since
you have your own model elements you probably aready have a plug-in. You
can create a your own "Navigator" in your plug-in. Eventually you may
want to separate UI and model into different plug-ins.
See IAdaptable interface and for example code have a look at the adpter
factories in JDT UI plug-in.
HTH
Dani
> I have read allot
>Thank You,
>Henry
Previous Topic:How to make PropertySheetPage a listener in my EditorPart
Next Topic:Attaching CVS to previously checked-out files
Current Time: Mon Sep 15 11:59:49 EDT 2025
Powered by FUDForum. Page generated in 0.04871 seconds
