Home » Archived » BIRT » Deply to Oracle 10g rel 2 ias
Deply to Oracle 10g rel 2 ias [message #90008] Thu, 10 November 2005 21:32
Deployment of Birt to JBOSS works with no problems
The same deployment to a Oracle 10g rel 2 ias OC4J returns an error.
Oracle 10g rel 2 ias works with java 1.4.2
JBOSS 4.0.2 is working with java 5.
The report was built with BIRT 2.0M2
Oracle OC4J reports this:
500 Internal Server Error
java.lang.IllegalArgumentException: Partial path must start with a /
at com.evermind[Oracle Application Server Containers for J2EE 10g
(10.1.2.0.0)].server.http.HttpApplication.getResourcePaths(H ttpApplication.java:8012)
org.eclipse.birt.core.framework.PlatformServletContext.hasCh ildren(PlatformServletContext.java:95)
org.eclipse.birt.core.framework.PlatformServletContext.getFi leList(PlatformServletContext.java:69)
org.eclipse.birt.core.framework.server.ServerPlatform.<init >(ServerPlatform.java:55)
at org.eclipse.birt.core.framework.Platform.initialize(Platform .java:85)
org.eclipse.birt.report.engine.api.ReportEngine.<init>(ReportEngine.java:79)
org.eclipse.birt.report.viewer.utilities.EngineAccessor.setE ngineContext(Unknown
Source)
at org.eclipse.birt.report.viewer.servlets.ViewerServlet.doPost (Unknown
Source)
at org.eclipse.birt.report.viewer.servlets.ViewerServlet.doGet( Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
(10.1.2.0.0)].server.http.ServletRequestDispatcher.invoke(Se rvletRequestDispatcher.java:810)
(10.1.2.0.0)].server.http.ServletRequestDispatcher.forwardIn ternal(ServletRequestDispatcher.java:322)
(10.1.2.0.0)].server.http.HttpRequestHandler.processRequest( HttpRequestHandler.java:790)
(10.1.2.0.0)].server.http.AJPRequestHandler.run(AJPRequestHa ndler.java:208)
(10.1.2.0.0)].server.http.AJPRequestHandler.run(AJPRequestHa ndler.java:125)
(10.1.2.0.0)].util.ReleasableResourcePooledExecutor$MyWorker .run(ReleasableResourcePooledExecutor.java:192)
at java.lang.Thread.run(Thread.java:534)
Is there a way to solve this problem? (I need to deply to OC4J).
Previous Topic:What version of Birt started supporting Total.percent?
Next Topic:Fop error messages
Current Time: Fri Apr 18 05:30:40 EDT 2025
Powered by FUDForum. Page generated in 0.02975 seconds
