Can't use the editor under Mac OS [message #765991] |
Thu, 15 December 2011 03:15 |
Alexey Messages: 1 Registered: December 2011 |
Junior Member |
Hey everyone!
Looks like an awesome tool, I was really looking forward to using it. I've tried installing it to the latest eclipse, but ran into problems after the installation.
Specifically, when I try to open a lua file, the editor won't launch, and I get this stack trace printed in the editor:
java.lang.NoClassDefFoundError: com/naef/jnlua/LuaException
at org.eclipse.koneki.ldt.parser.LuaSourceParserFactory.createSourceParser(LuaSourceParserFactory.java:29)
at org.eclipse.dltk.ast.parser.SourceParserManager$SourceParserContribution.getSourceParser(SourceParserManager.java:106)
at org.eclipse.dltk.ast.parser.SourceParserManager.getSourceParser(SourceParserManager.java:83)
at org.eclipse.dltk.core.DLTKLanguageManager.getSourceParser(DLTKLanguageManager.java:280)
at org.eclipse.dltk.core.SourceParserUtil.parse(SourceParserUtil.java:97)
at org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration(SourceParserUtil.java:197)
at org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration(SourceParserUtil.java:183)
at org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration(SourceParserUtil.java:174)
at org.eclipse.dltk.core.AbstractSourceElementParser.parse(AbstractSourceElementParser.java:42)
at org.eclipse.dltk.core.AbstractSourceElementParser.parseSourceModule(AbstractSourceElementParser.java:26)
at org.eclipse.dltk.internal.core.AbstractSourceModule.buildStructure(AbstractSourceModule.java:526)
at org.eclipse.dltk.internal.core.Openable.generateInfos(Openable.java:193)
at org.eclipse.dltk.internal.core.ModelElement.openWhenClosed(ModelElement.java:184)
at org.eclipse.dltk.internal.core.BecomeWorkingCopyOperation.executeOperation(BecomeWorkingCopyOperation.java:45)
at org.eclipse.dltk.internal.core.ModelOperation.run(ModelOperation.java:698)
at org.eclipse.dltk.internal.core.ModelOperation.runOperation(ModelOperation.java:764)
at org.eclipse.dltk.internal.core.SourceModule.becomeWorkingCopy(SourceModule.java:68)
at org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProvider.createFileInfo(SourceModuleDocumentProvider.java:1274)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.connect(TextFileDocumentProvider.java:478)
at org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProvider.connect(SourceModuleDocumentProvider.java:1515)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4213)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:237)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1451)
at org.eclipse.dltk.internal.ui.editor.ScriptEditor.internalDoSetInput(ScriptEditor.java:827)
at org.eclipse.dltk.internal.ui.editor.ScriptEditor.doSetInput(ScriptEditor.java:1323)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3200)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2642)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3218)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3245)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:828)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4128)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3974)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3613)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.naef.jnlua (349).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:254)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:399)
at org.eclipse.dltk.internal.core.structure.StructureIndexer.indexDocument(StructureIndexer.java:139)
at org.eclipse.dltk.internal.core.structure.StructureProjectIndexer.doIndexing(StructureProjectIndexer.java:20)
at org.eclipse.dltk.core.search.indexing.core.AbstractProjectIndexer.indexSourceModule(AbstractProjectIndexer.java:138)
at org.eclipse.dltk.core.search.indexing.core.SourceModulesRequest.run(SourceModulesRequest.java:90)
at org.eclipse.dltk.core.search.indexing.AbstractJob.execute(AbstractJob.java:76)
at org.eclipse.dltk.internal.core.search.processing.JobManager.run(JobManager.java:467)
at java.lang.Thread.run(Thread.java:637)
Caused by: org.osgi.framework.BundleException: Exception in com.naef.jnlua.Activator.start() of bundle com.naef.jnlua.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 27 more
Caused by: java.lang.UnsatisfiedLinkError: no lua5.1 in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1809)
at java.lang.Runtime.loadLibrary0(Runtime.java:823)
at java.lang.System.loadLibrary(System.java:1045)
at com.naef.jnlua.Activator.start(Activator.java:37)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 33 more
Thanks for your time, really looking forward to checking out LDT!
(tried installing it both via the classing "help->install new software", and from the marketplace, to 2 different eclipse installations (classic/java) - same error. Using LuaEclipse for now, that seems to work...)
[Updated on: Thu, 15 December 2011 03:17] Report message to a moderator
FUDForum. Page generated in 0.03391 seconds
